Made some parts on a CNC machine for the Z
Old Dec 14, 2011 | 06:57 PM
SJAEGER88's Avatar
SJAEGER88
Default Made some parts on a CNC machine for the Z
So I work at a machine shop and when I have down time I mess around and attempt to make parts for my Z. So far I made a heat shield for my intake, a nitrous gauge pod for the cubby (and it still is able to close) and a shift ****. Let me know what you think, future parts will be some wheels spacers and if anyone knows dimensions of a fuel tap I would appreciate it or detailed pictures with a scale hahaha
Attached Thumbnails Made some parts on a CNC machine for the Z-photo-1.jpg   Made some parts on a CNC machine for the Z-photo-2.jpg   Made some parts on a CNC machine for the Z-photo-3.jpg   Made some parts on a CNC machine for the Z-photo-4.jpg   Made some parts on a CNC machine for the Z-photo-5.jpg
Old Dec 14, 2011 | 07:29 PM
JasonZ-YA's Avatar
JasonZ-YA
nice...
do solid rear diff bushings and subframe bushings..
-J
Old Dec 14, 2011 | 07:45 PM
350zion's Avatar
350zion
Professional
Originally Posted by JasonZ-YA
nice...
-J
+1 on these....
Old Dec 14, 2011 | 08:01 PM
Italianjoe1's Avatar
Italianjoe1
Fuel tap for what? I made one myself on the lathe at the shop, to put between the line and rail assembly, o-ringed just like stock.
Old Dec 14, 2011 | 08:46 PM
SJAEGER88's Avatar
SJAEGER88
Thanks guys definetly will do the bushings. And yea thats the one Joe can you fill me in on some of the steps you took to make it on the lathe I work with a hurco that has windows software
Old Dec 15, 2011 | 12:24 AM
SammyC350's Avatar
SammyC350
Nice work!
Old Dec 15, 2011 | 12:46 AM
m3a5g0's Avatar
m3a5g0
man, if i only had access and the skill to do this stuff...i'd def. be making some big brake mounting brackets. On that same note, make some and sell me a set
Old Dec 15, 2011 | 02:43 AM
350zion's Avatar
350zion
Professional
Also could use a set of solid motor mounts designed better than Wats currently on the market....
Old Dec 15, 2011 | 03:34 AM
Italianjoe1
I did it on a manual lathe, was easier since I had to kinda guess at the right clearance I needed since I was using non-oem o-rings. Once I got a package of oem size o-rings for the final design, I just adjusted the bore sizing. Simple, internal bore the same size as the rail section of the car, and duplicate the o-ring groove and diameter of the hard line portion. Make it tall enough to fit whatever size tap you are looking to put (I used 1/8 npt) and it looks very oem.
It's a 12mm o-ring btw. Can buy a pack off mcmaster-carr for cheap as ****. Dealer charges way too much.
Old Dec 15, 2011 | 03:36 AM
Italianjoe1
For what, the Z? That doesn't make sense. The work needed for custom parts like that is pointless on a car with factory brembos and a lot of aftermarket BBK options.
I've made adapters to run Evo Brembos on a 90's tacoma, but unless on an application with no support there is no reason.
Old Dec 15, 2011 | 03:38 AM
Italianjoe1
I would tackle this if someone wanted to donate a set of mounts for me to take measurements off of. I could prototype a set and setup for cnc reproduction as long as there are a couple people willing to buy.
Old Dec 15, 2011 | 03:57 AM
350zion's Avatar
350zion
Professional
I destroyed a set of injected performance solid mounts due to some wicked lateral movement during a spin out.. The IP's work well but I'd like something a little beefier if possible... Made out of 1 piece of milled steel a instead of having welding points....
I'm about to pull my motor, wen I do I can get back to either one of u guys with the measurements of Wat I want done....
Old Dec 15, 2011 | 04:51 AM
VQ35deMax's Avatar
VQ35deMax
Glad to see somebody else has access to a CNC machine. I have been making parts as well for the Z and other nissans for a while now.
Old Dec 15, 2011 | 08:07 AM
SJAEGER88's Avatar
SJAEGER88
Sweet what have you made? And I'll give it a shot joe I'll let you know how it comes out
Old Dec 15, 2011 | 08:45 AM
graffkid732's Avatar
graffkid732
Awesome. I have access to some machines at work as well. Never used them but wouldn't mind to learn. Cool stuff for sure though. Just be careful if you make parts for people. Don't want to be held reliable in anyway if a part happens to fail. As well as getting in trouble on the forum for advertising with out a vendor sponsorship. Keep up the good work. And you are 100% correct on the BBK brackets.
Old Dec 15, 2011 | 10:47 AM
SJAEGER88's Avatar
SJAEGER88
Thanks buddy
Old Dec 15, 2011 | 12:29 PM
Italianjoe1
If you can send me a set of stock mounts, i'll make up some solid ones that will work and offer them up for a group buy.
Old Dec 15, 2011 | 03:23 PM
350zion's Avatar
350zion
Professional
Yea I can look around n see if I still got the old ones somewhere...
Basically the aftermarket solid mounts are either a welded tube with a flat top n bottom n a bolt welded in each end... They are approx 1 7/8 round at the base n top...
I think they can be made bigger with more surface area... Mine broke at the welds both at a bolt n on the top plate of the other...
Solid mounts made from a single piece of billet have about the same surface area n have a single bolt thru the middle...
Again I am looking for something with more surface area and really strong bolts/ fasteners....
I'll look around n see Wat I have...
_bit
Oct 2, 2015 07:49 AM
