Aftermaket hood letting water into the Belts
like i said done correctly, and i know for a fact our clu's(javelin launchers) is definitly wet layup vacuum bagged. resin left on it is still a bit too thick to be prepreg. but yah like i said the seibon and vis stuff is absolute crap. vacuum bagging can be done pretty good as well, i might try vacuum infusion down the road.
The CF on exotics, military, true race cars, planes etc are aerospace prepreg dry carbon with minimal resin and completely carbon all the way through the entire part. The aftermarket crap out there for our Zs is made of fiberglass with one aesthetic layer of carbon and too much brushed in resin.
i think the reason its catching on more is the affordability factor, price has really dropped i can get a 50" by 1 yard piece for 25 bucks 3k 2x2 twill, 10 years ago or so the price was triple that or more.
is it a fad for alot of people? sure but that wasnt the original intent i know alot of our military equipment uses it now for lighter carry weight, while maintaining strength.
Hmmm you might need to get that looked at OP
Tons of people have run aftermarket hoods without issues for years:
https://my350z.com/forum/exterior-an...ain-water.html
https://my350z.com/forum/exterior-an...ly-driver.html
https://my350z.com/forum/exterior-an...drip-tray.html
trust me thats a myth
they had the opportunity to get new squad automatic weapons that drop the saw gunners load from ~56 lbs for weapon + 1000 round combat load down to ~23 lbs and dint do it because the caseless ammo "cant be used in m4's" yah you will never see soldiers delinking saw ammo to put in a m4.
but yah some stuff i imagine is prepreg carbon fiber but its nothing the average soldier will see most is wet layup with vacuum bag, or at best vacuum infusion its always the lowest bidder that wins.
is not a tension problem, i had the belt set to the correct tension and i know that because it doesn't make any noise unless it rains, the car is usually garage keep and it never makes the noise. the few times i have taken it out and it rains... you can hear it slipping and then after a few seconds once the water gets pushed off.. it comes back to normal.
but i think im just going to fill the wholes with fiberglass and call it a day.
Thanks,
Thanks,
Thanks,
Thanks,
to be completely honest the reason why man manufacturers are switching to carbon is absolutely for weight savings, however in large decreases in weight that you see in super cars due to the use of carbon is largely because they are using carbon (and aramid) composite materials to replace structural members of the cars underlying chassis. the cars that are experienceing the most signifcant reduction in mass are the ones where you are seeing the chassis being built of carbon rather than the heavier thick aluminum and high strength steel traditionally used in these areas of cars.
the most useful aspect of carbon composite materials is not really their low mass alone, it has more to do with their low mass to weight ratio. you can use carbon with a much lower mass and get rigidity similar to aluminum or steel in a much lighter form factor.
even if it's done properly this is why you won't see a terribly dramatic weight savings by replacing most (not all) body panels. for example if you take the factory front fenders off of the z they are very thin aluminum and as a result they are very light and also quite flimsy, you could easily bend them in half with your hands. if you replace this part with carbon you won't see much weight reduction at all however an equal mass carbon replacement part should be more rigid than the oem part.
As for the military, I wish they would have invested some money in making the M240B a little lighter, carbon buttstock and furnature perhalps.
Thanks,
Thanks,
Trust me, I have had my hood on for about 5 years now, just tighten it up a little.
Makes sense. When the belt and pulley are dry the coefficient of friction between them is relatively high and you wont notice any problems. When the surfaces are wet, the coeficient between them goes down and the same force that was produced in the dry is now capable of exceeding the (now reduced) max static friction force produced between the pulley and belt. Belt friction from a mathematical stand point is quite different than friction over a flat surface as it is actually exponential so a very small difference in the tension can make a large difference in friction.
So if you tighten the belt just a little bit, it will probably go away.
a little off topic but on the note of 240B im guessing you havnt seen much of the 240L? we have a couple also they just replaced the butt stocks on em with a super lightweight buttstock, collapsible like our m249's already had but even smaller and lighter now. the 240L now is about 10 lbs lighter then the 240B, also the new buttstock+buffer tube only weighs mayby a .25 lb at most.
sorry on the OT
sorry on the OT
