the "bmccann101s car gets a new look/ watch me suffer bodywork hell" thread
Old Mar 6, 2024 | 11:21 AM
  #2121
bmccann101's Avatar
bmccann101
much appreciated on the kind words.
Im stil having issues w the TPS Auto set, so i have 2 plans, either keep working on the software to try and get the Nissan pedal sweep dialed in.. or have a braceklt welded to install the GM pedal onto the firewall, using the nissan pedal and stalk.
First start up engine Oil has been added to the dry sump tank, and i added an interrupt switch so the main fuel pumps stay inactive, allowing some cranking over, building oil pressure etc.
My buddy is coming by during spring break week to assist in bleeding brakes, adding and bleeding clutch fluid, and getting the clutch pedal throw and pedal stoppers all set up.
Other than that, it will be time to have him remote in and start doing my ecu set up, first start work.
Old Mar 11, 2024 | 01:06 PM
  #2122
bmccann101's Avatar
bmccann101
gas pedal issues fixed, some pins were lose in the tb connector.
Nissan pedal is set to the gm tb now...
Clutch fluid in and bled, rjm pedal bracket set up with stoppers for proper throw.
Needs the radiator drain petcock flexible extension plumbed in, water added, and some more fuel..
start time.
Old Mar 25, 2024 | 09:02 AM
  #2123
bmccann101's Avatar
bmccann101
welp.... Cant make this kinda sht up.
/ thread.
Jk. But to those who already follow my social media accounts ..... You already know that my built, forged and finally "fixed" engine popped on the dyno yesterday.
We say popped ....because it was majorly down on power form last time ( 547whp down to 474whp), sprayed coolant out of the rad cap.. And is now makin a very scary rattle noise a bit off the deck idle, 1500-1800 rpms.
Head gasket? Rod bearings?
Quick fix or total rebuild?
Dont know yet as i'm leaving everything as is until i can get someone over to the house to listen briefly and give me a solid opinion before we start tearing down the engine ..yet again.
I had my emotional moment; disbelief.... Then total " of course this would happen" belief.
Can i give up? Lol.. No. I am way too far into this thing.
Can i afford this? Absolutely not .... And im really hoping its caught before anything is too bad to save.
If i have to rebuild, i will most likely part out the nearly brand new turbo and fuel system, and move over to an ls2 with ls# heads and call it a day for now.
My hp will drop in half, but it will be easy to build back up, and will be an engine that can afford me far less headache.
Id much rather keep what i have and fix it and be done however.
I am way past burnt out on wrenching right now, yet it looks like my hand is forced back into it, yet again.
So i will continue to finish the body , finish the carbon door swap, the wrap etc etc..
I will post pics as usual, but know that the car is going nowhere this summer after all.
^^ that was my post here on 5/28/2020 lol....
four years, folks.
The stuff in my life ive lost over this stupid car is unfathomable...
On 3/24/24, this last sunday, after several attempts to pull fuel out of the base calibration. And get more than a second of run time..
.. the engine swap grumbled to life and ran on its own.
plenty yet to do, need to vacuum bleed the coolant due to horrific air bubbles and heat issues from a bad fill job.. Clean up the tune and do some street pulls etc...
But yeah.
IT RUNS.
IT IS ALSO WILDY LOUD LOL.. BUT YEAH MAN.... THANKS FOR STICKING AROUND.
GD.. I DID IT.
I WILL OF COURSE POST MORE SOON AND GIVE SOME UPDATED PICS AND VIDEO LINKS.
Old Mar 25, 2024 | 09:09 AM
  #2124
e30cabrio's Avatar
e30cabrio
Is it OK? Was that from years ago when it popped? (Hopeso)
I'm having one issue after another with a Z3 BMW since November and feel like it's a nightmare. Can't imagine over a decade.
Hang in there!
Old Mar 25, 2024 | 01:22 PM
  #2125
bmccann101's Avatar
bmccann101
yeah my s class is a constant fight now too, but.. things do need to be replaced w age, its inevitable.. it just sucks when that snowball starts to roll down the hill.. it doesnt stop :/
Yep fours years ago, that was my post .. it has taken me THAT long :/
Old Mar 25, 2024 | 01:43 PM
  #2126
e30cabrio's Avatar
e30cabrio
Whew, glad it is not new.
Old May 18, 2024 | 08:47 PM
  #2127
djnekkon's Avatar
djnekkon
Glad to see you back at it. One of the most amazing 350z I've seen since I joined this forum.
Old May 23, 2024 | 07:40 AM
  #2128
bmccann101's Avatar
bmccann101
View this post on Instagram
Here's the first week's ig clip of it running.
Old Jun 18, 2024 | 08:06 AM
  #2129
bmccann101's Avatar
bmccann101
Old Jun 18, 2024 | 08:12 AM
  #2130
bmccann101's Avatar
bmccann101
Used my template decal and slowly drilled my holes for the Cartek rain light.
Need to clean up from the backside and then prime and paint them, then they will be smooth and the wrap will stick.
Added heat wrap to protect diffuser from exhaust heat.
Old Jun 18, 2024 | 10:10 AM
  #2131
e30cabrio's Avatar
e30cabrio
Can't believe I missed the first start video. CONGRATULATIONS!!!!!
Old Sep 21, 2024 | 03:42 PM
  #2132
bmccann101's Avatar
bmccann101
Non pictorial update lol
Car runs, car was driven, and I actually have to relearn how to drive a manual it seems lol.. Was not expecting to be THIS rusty.
Immediately discovered a big issue..
The csc was set up incorrectly by myself... And everything underneath the car has to be removed to drop the trans.
Water lines.. Sways, exhaust braces etc..
I have clutch fluid all over my tilton clutch.. So discs may need to be replaced, not the worst case.
Need to pull clutch, clean everything.. Fix up the discs and then reinstall.. And lastly have someone who knows what they're doing come and adjust my csc throw out so this doesnt happen again
Dropping the trans is gna be sketchy af w the engine in the car and no lift.
I am not excited by any means
Old Sep 22, 2024 | 01:37 AM
  #2133
e30cabrio's Avatar
e30cabrio
No fun. Sorry.
Old Sep 23, 2024 | 11:03 AM
  #2134
bmccann101's Avatar
bmccann101
ah no big deal.. things happen, and for thsi being the only issue w the swap thus far, i cant really complain.
I have a mobile alignment guy coming by 9/29, and then i can go nuts on taking the trans out and getting that sorted. Once that's handled, i can literally start driving the car and shaking everything down on day one.
All in due time.
Old Nov 9, 2024 | 07:12 AM
  #2135
i8acobra's Avatar
i8acobra
Overextended the CSC and it blew out? Common mistake. You need to take some measurement and buy the correct thickness spacer to go behind it.
Old Nov 12, 2024 | 05:35 AM
  #2136
bmccann101's Avatar
bmccann101
no spacer on this one, the tilton is threaded .. but what i think happeneed is that i actually set it correctly, but my buddy ste up my clutch pedal incorrectly.. it had tension on it all the time, so when the clutch was "out", it was still being slightly depressed. Then the overall throw was set in correctly as well/ stoppers etc.. who knows, will find out soon once i can get helping hands to come take the trans down.. its sitting unbolted and waiting :/
Old Nov 12, 2024 | 08:32 AM
  #2137
i8acobra's Avatar
i8acobra
Yeah, that'll also overextend it.
Old Jan 25, 2025 | 07:28 AM
  #2138
fullvietFX's Avatar
fullvietFX
Did you ever finish this?
Old Jan 28, 2025 | 08:10 AM
  #2139
bmccann101's Avatar
bmccann101
for the most part? yes I did.
Old Mar 19, 2025 | 09:03 AM
  #2140
bmccann101's Avatar
bmccann101
oh hai.. well after 15 years i finally moved to a new place.. 3 car garage now, but a very quiet neighborhood so i havent driven my car yet lmao.
We fixed the transmission and shifter issue before i had to pack and move.. and now i had my buddy fix the bolt holes in the flares so iu need to re-drill a few and re-rattle can the flares so the wrap will stick better.
Been busy as hell w the move and am slowly getting the garage together again.. its getting hot again next week, and will need my ac lines created soon, asa well as a heat sheild and catch can, integrated together around the air intake filter. Buddy is coming by top make welding templates next week.
