the "bmccann101s car gets a new look/ watch me suffer bodywork hell" thread
Old Apr 30, 2018 | 05:41 PM
  #1881
DarkZ03's Avatar
DarkZ03
Nice carbon, how redicously priced are those if you don't mind me asking?
Old May 1, 2018 | 08:35 AM
  #1882
bmccann101's Avatar
bmccann101
The work done to the waterfall pieces was around 500 in labor.
Old May 1, 2018 | 12:47 PM
  #1883
boamedt's Avatar
boamedt
Everything is looking nice. Thats not bad for the carbon waterfall. I really like that front bumper and how you filled the lines and badge area. Hows the fitment on it? I have been thinking about getting one. I really like the martini stripes. Good job
Old May 1, 2018 | 01:10 PM
  #1884
Row2K's Avatar
Row2K
Very nice, curious to see how your tablet setup will work. Are you having any custom integration done ie. bags/ride height via tablet?
Old May 2, 2018 | 02:40 PM
  #1885
CK_32's Avatar
CK_32
As river as that front bumper should be, it’s actually not at all haha
I almost want that for my Z now. I remember seeing this car on YT when you first uploaded the first wide body kit. Cool to see you haven’t just sold or left it as is. Always growing.
You got any pics of that bumper with out that front splitter on the car?
Also does anyone make that in poly. Had a FG bumper in the past and hated it. Every week it would have a new chip.
Old May 3, 2018 | 01:50 PM
  #1886
bmccann101's Avatar
bmccann101
As far as tablet integration... I don't use air bags... So luckily the integration of the air cup lift is just a latched switch.. Yes all my lighting and accessories will be handled by the tablet using an arduino board and a relay group module. He's working on that stuff now as a favor to me.. Everything will work from a widget on the tablet screen.. And I can operate anything I choose to program on the tablet thru my steering wheel.. Inc audio controls and also any other sequence .. It allows differing functions for long holds, so a lkg hold of volume will still do volume.. But a long hold of the mode button can easily be programed to latch the front end lift switch.
As far as bumper fitment, there's plenty of pics of it on my Instagram acct @bmccann101 . The fit is perfect
We don't offer it in poly but kbd is still working on that.. I actually have a large group buy on the nsm kit w vis .. I'm still the exclusive seller for that kit for a bit longer.. Dm me or contact me on fb or ig.. The icons are next to my username.
I'm not a site sponsors here.. Can't post sale details
Old May 7, 2018 | 09:55 AM
  #1887
bmccann101's Avatar
bmccann101
I do have a question.. I've posted it in various other threads.. But no help so far..
Does anyone have the ability to read the Fsm wiring differences between a 2005 clock spring harness and a 2006 clock spring harness?
I need to know two things :
1-For all of the wires that are the same between the two years.. And the pin locations for each the same?
2-for the additional three wires used for lighting and audio controls... Which position are they and what signal do they require? +/- etc..
Out of everything I'm. Doing, no one seems to be able to help me w the full retrofit of this 06 st wheel and clock spring.
Old May 7, 2018 | 05:30 PM
  #1888
DarkZ03's Avatar
DarkZ03
I may be able to do a write up about the process when I do it but it may be a month or so before then. IIRC the 3 wires for that side are one illumination, one control and one dimmer. So the illumination is + the dimmer would go to the dimmer circuit if wanted and the control is just a signal wire to head unit. Power and ground are shared so those pins will be in the the same location, horn should also be in the same position.
Old May 7, 2018 | 05:38 PM
  #1889
bmccann101's Avatar
bmccann101
Any idea which is which? And where I should locate the dimmer ground at?
Old May 7, 2018 | 10:42 PM
  #1890
Skyfer_lt's Avatar
Skyfer_lt
Should be able to help. However, I only have access to 08 and 03 manuals.
These are the clock spring connectors:
M203 goes to steering wheel switches and M23 to main body harness
M23
corresponding M203 pins
Pin 26 Illumination +
Pin 18
Pin 27 Illumination -
Pin 21
Pin 31 Sw Gnd
Pin 17
Pin 32 Remote Control B
Pin 16
Pin 24 Remote Control A
Pin 20
On M203 connector Pin 19 should be the horn wire and pins 14 and 15 should be cruise control switches.
Illumination positive comes from the tail lamp relay through a resistor.
Illumination ground should connect to a wire that goes to Combination meter Pin 18 (M19 connector).
Also, steering wheel control switches connect to tel adapter unit or audio unit directly.
Old May 7, 2018 | 10:44 PM
  #1891
bmccann101's Avatar
bmccann101
Oh thank God.. Huge thank u.
Old May 7, 2018 | 10:59 PM
  #1892
Skyfer_lt's Avatar
Skyfer_lt
No worries, if you have any other questions, let me know.
Old May 9, 2018 | 04:46 PM
  #1893
bmccann101's Avatar
bmccann101
The carbon waterfall turned out great.. The weave is perfect.. Thanks to Fab Vilches.. Forum OG.
Old May 17, 2018 | 11:03 AM
  #1894
bmccann101's Avatar
bmccann101
Hooray for China.. Smh.. Sometimes you win, sometimes you lose.
The carbon on this diffuser is total dog *****.. Hopefully I get a healthy refund at least.. I'll just paint it black.. The 1*1 carbon wasn't so hot anyway..
So yes.. I did measure and even use a protractor before I bought this.. And the end result will be reasonable to body work into the bumper
It hasn't been cut out yet, so yes this is hovering a bit, but u get the idea..
Sadly, The differential hole is smaller than anticipated . So I can use even two 4" tips that I bought.. So those are all now for sale. 50 bucks each..and already had them ceramic coated lol.. Lmk and we can chat elsewhere...
Old May 17, 2018 | 11:05 AM
  #1895
bmccann101's Avatar
bmccann101
Flares will be done this weekend though. I think they turned out pretty great.
Old May 17, 2018 | 11:55 AM
  #1896
Row2K's Avatar
Row2K
that's a shame about the diffuser, but if you are painting it, then what's to stop you from going to town on it with some fiberglass and reshaping the differential hole to fit the 3 exhaust outlets?
Old May 17, 2018 | 04:24 PM
  #1897
bmccann101's Avatar
bmccann101
Still wouldn't be feasible . and I'd like the diffuser to be a bolt on part as is.. In case it needs to be replaced from damage later.
Old May 21, 2018 | 10:13 AM
  #1898
bmccann101's Avatar
bmccann101
Oh hai.. Flares are done
The general idea on what will come after :
Old May 29, 2018 | 10:09 AM
  #1899
bmccann101's Avatar
bmccann101
First progress shot of the tablet dash bezel in silver carbon fiber :
Test positioning front fender vents
Tecnocraft seat install. These are an absolute DREAM.
Ordered panamera switch back projector shrouds.. Will test fit on a broken dummy light I have here.
Rear bumper cut out :
And the test fit.. It will sit lower and farther in.. Didn't have the proper sized box to shim it with..
Old May 29, 2018 | 02:58 PM
  #1900
DarkZ03's Avatar
DarkZ03
Hey did you get those switches wired in? I'm in the process of doing that and apparently the rear of the clockspring is different which means you have to get the newer steering angle sensor which costs almost as much as my steering wheel. Did you replace the sensor too or found a way around it?
