Brighter backup/reverse lights?
Old Mar 21, 2004 | 02:06 AM
jreiter's Avatar
jreiter
Question Brighter backup/reverse lights?
Did a search for this, but didn't turn up much info. Has anyone tried increasing the brightness of the backup lights in any way? I'm finding that they aren't really sufficient when backing up in very dark places, and it can only get worse when I tint my windows come summer time.
I figure I could probably drop in a higher wattage bulb, but I've always been a bit hesitant to do things like that. Don't want to burn anything up. Anyone else tried this or have any good solutions? If you've simply replaced the bulb, what are the bulb types? (I haven't looked up that info yet.)
Old Mar 21, 2004 | 06:54 AM
IsatteliteI's Avatar
IsatteliteI
Default This might help...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468105516
Thinking of getting them myself.
Old Mar 21, 2004 | 07:58 AM
ares's Avatar
ares
Veteran
those wont be brighter than stock, actually dimmer.
they are 21watts which is the same as the stock bulb, but the tinted blue lens will lower the output.
also I find blue bulbs like that kinda funny looking in the day when their off. you see the blue in the lens just like you see the amber on the turnsignal bulb.
Old Mar 21, 2004 | 08:05 AM
SmO69's Avatar
SmO69
yeah those are just cheap ricer bulbs. worse than regular lights.
Old Mar 21, 2004 | 06:21 PM
jreiter's Avatar
jreiter
Yeah, I definitely don't want a standard 21 watt bulb that simply has a tint on it. A tint doesn't get you anything but dimmer. I figure a 25w or maybe a 30w bulb would be the ticket. Since the backup lights are only on for very brief periods of time, I figure the extra heat from a few extra watts shouldn't be a problem. Sound reasonable?
Old Mar 21, 2004 | 06:47 PM
ares's Avatar
ares
Veteran
reasonable, but bulbs heat up fast. so be careful or you might have trouble.
keep it under 30seconds or so, and should be ok.
Old Mar 21, 2004 | 11:14 PM
jreiter's Avatar
jreiter
Ugh, 30 seconds, eh? Not sure I'm up for that. Heck... I might have to see if I can rig something else, then. I'll have to think about it a while... once my car gets out of the audio shop that is. (I've been without it for a week!)
Old Mar 22, 2004 | 07:45 AM
afr0puff's Avatar
afr0puff
<--- Patiently waits for ares to invent a better bulb.
Old Mar 22, 2004 | 08:18 AM
ares's Avatar
ares
Veteran
hahahaha.
I have my thoughts about the reasons they arent very bright. I mean 21w is pretty bright, and should be on par with most any other car.
my feeling is that the cause is the housing. where the bulbs light isnt focused behind the car. of course no way to fix that.
luxeon has brighter leds I can use, but they cost too much and get too hot. they just released new amber and red bulbs though, they are 2x as bright as the old ones on the same current draw. just no sign of such an improvement for white.
(but you better beleive Im planning to use them for turnsignals and brake lights )
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
