Kinetix SSV Dyno Results
Old Jun 16, 2005 | 02:33 PM
Lorca@Z1's Avatar
Lorca@Z1
Default Kinetix SSV Dyno Results
Installed the Kinetix SSV today and did a set of 3 dyno runs before and after. I threw out the highest and lowest runs of each set and the chart below shows the results. Red is before and blue is after.
Installed pics
Old Jun 16, 2005 | 02:34 PM
MIAPLAYA's Avatar
MIAPLAYA
Well it sure did lean out the A/F curve...
Old Jun 16, 2005 | 02:36 PM
Lorca@Z1's Avatar
Lorca@Z1
Red is BEFORE, blue is AFTER. It actually made it richer
Old Jun 16, 2005 | 02:39 PM
MIAPLAYA's Avatar
MIAPLAYA
Oh crap...well I'm dumb.... wow thats interesting....
Old Jun 16, 2005 | 02:40 PM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
So did you tune it after the runs?
Old Jun 16, 2005 | 02:44 PM
Lorca@Z1's Avatar
Lorca@Z1
No tuning has been done. I'm not sure that this is an accurate comparison though because the car is having trouble holding boost after 5k RPM. Boost peaks at .65 bar and then drops off to around .55 bar, so I think the numbers are a little skewed.
Old Jun 16, 2005 | 02:59 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
When swapping plenums, richness usually is a sign of decreased air volume, increased turbulence, or decreased velocity. Typically, we like to see leanness, which is a good sign that the plenum is flowing more higher velocity air...then we can richen it up via the tune. This is what happened when I went from stock to Crawford.
I'd like to see more testing on these plenums. It looks like a very interesting design. It's interesting that your plenum richened up the mixture, but you still gained about 10whp at the peak. Maybe your setup likes a slightly richer mix for more power. Typically, peak power is acheived at between 11.7 and 12.5:1, as a general rule.
Lorca, did you have boost issues between these two runs? Or was your boost issue consistent between the various dyno runs.
Old Jun 16, 2005 | 03:00 PM
THX723's Avatar
THX723
So no significant gain up until 6300 rpm from this plenum?
I just finished testing one for NA use and had more or less the same finding. Our AF did not change one bit however (one sign that little impact was made by the mod).
Old Jun 16, 2005 | 03:02 PM
Sharif@Forged
Forged Performance
Can someone refresh my memory on Kinetix's power claims with this plenum on an F/I car. I recall is was nearly a 75whp increase...but I think there was tuning and other things involved.
Old Jun 16, 2005 | 03:08 PM
tonio's Avatar
tonio
damn, suddenly $700-$800 doesn't look so good any more. Sorry to hear about the boost problems.
Old Jun 16, 2005 | 03:10 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yeah, certainly did look too good to be true. Mine is still sitting in the box ready to install. But even if it doesn't give me a ton of HP gain, it really does look BEAUTIFUL!
That's a lot of cash for mere cosmetics though!
I'm waiting to see Jeremy's dyno results.
Old Jun 16, 2005 | 03:18 PM
sentry65's Avatar
sentry65
the burninator
can we get the graph to be more normalized?
This was comparing the OEM plenum to the SSV?
You can always lean out the A/F more and probably get even more power... That's what I wanna see. After you tune for the SSV, let's see what power you get
You obviously were tuned pretty well before the SSV
this manifold still has some nice advantages over OEM or crawford or probably the APS tall boy
weighs 10-12 lbs less
less heat soak
capable of direct port nitrous
looks nice
Old Jun 16, 2005 | 03:22 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Hmmmm, glad I decided to wait
Old Jun 16, 2005 | 03:37 PM
booger's Avatar
booger
If he lost boost . You would think that , that alone would make the A/F richen up quite a bit .And it stll made the same or a little more hp . To me it looks real promissing with his normal boost range and a retune
Old Jun 16, 2005 | 03:42 PM
sentry65's Avatar
sentry65
the burninator
I agree
RedLeader's Avatar
RedLeader
subscribing
Old Jun 16, 2005 | 03:43 PM
Sharif@Forged
Forged Performance
My thoughts exactly. I need to understand if the boost problem was constant amoung the varies runs, or it occured in the middle of the dyno runs. With more tuning, this looks like a decent plenum. No loss in power or trq at the bottom, and more power near the top...where the VQ really starts to get winded.
Old Jun 16, 2005 | 03:52 PM
westpak's Avatar
westpak
SFZCC
I think this is the first TT that has done dynos with this plenum the others were SC which is why I backed out not knowing what the results would be for 800 bucks.
Boost issues aside considering that if it lost boost the same on all runs then the gains should still be similar to what they would be if boost held, similar not the same. But maybe the design doesn't like the sudden rush of air coming in and backs up causing turbulence and bad flow, since the TT will flow differently than the SC or NA which build up flow on a steady basis.
Old Jun 16, 2005 | 04:12 PM
SungNamZ's Avatar
SungNamZ
Old Jun 16, 2005 | 04:19 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by SungNamZ
Further proof the number was in the tuning..
