rpm lead for zeitronix?
Old Jul 9, 2005 | 08:20 AM
tig488's Avatar
tig488
Default rpm lead for zeitronix?
i installed my zeitronix but the rpms must not be hooked up right, its not a big deal, just cool to have it on the data logger. i tied into the ECU harness at what i thought was the right wire, but there were 2 wires described in another post, does anybody know exactly which wire it is. right not the rpms dont get over 1k even when i punch it.
Old Jul 9, 2005 | 01:07 PM
SungNamZ's Avatar
SungNamZ
Wish I was at home and could give you the pin and wire color. However, do a search using: SungNamZ Then look for threads: Zeitronix
Old Jul 9, 2005 | 01:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What do they recommend tapping? One of the ignition wires, or the crank angle wire?
Old Jul 9, 2005 | 02:14 PM
SungNamZ's Avatar
SungNamZ
They recommend tapping into #1 coil of ECU harness. I am sure Sharif can give you the pin and wire color.
Old Jul 9, 2005 | 02:23 PM
booger's Avatar
booger
You probably have it on the crank wire now , reading all 6 cyl. thats why it doesnt go over 1K rpm . Got to tap one cyl. You Might want to check your settings first . Select [ 1 ] cyl. instead of 6
Old Jul 9, 2005 | 02:55 PM
tig488's Avatar
tig488
thats possible boog, the settings on the software was set to 4, i changed it to 1, im gonna search for sungnamz post and see if ive used the same wire.
after looking at that info sungnamz, i read tha before installing mine, i hooked to the yellow/red wire right next to the one i used for the tps.
Old Jul 9, 2005 | 03:23 PM
SungNamZ's Avatar
SungNamZ
Terminal #62: RPM Signal Yellow/Red
Terminal #50: Throttle position sensor Green
Old Jul 9, 2005 | 03:29 PM
booger's Avatar
booger
Looks like it may have been just your settings then
Old Jul 9, 2005 | 10:46 PM
Sharif@Forged
Forged Performance
yellow/red pin#62....
Wait...I guess I am too late.
Old Jul 10, 2005 | 07:40 AM
Madelinot's Avatar
Madelinot
I used #62. After adjusting the software setting, it seems to work just fine.
Old Jul 10, 2005 | 07:42 AM
tig488's Avatar
tig488
actually my #50 was white with a green stripe. anybody elses like that?
Old Jul 11, 2005 | 09:50 AM
BrianLG35C's Avatar
BrianLG35C
Tig,
I understand the Z-Tronic will also display fuel pressure. Is this true?
Old Jul 11, 2005 | 01:23 PM
tig488's Avatar
tig488
no, it doesnt display fuel pressure. it displays lambda, afr, boost, TPS, RPM, EGT, i believe thats all.
Old Jul 11, 2005 | 02:06 PM
booger's Avatar
booger
Dont remember , but some one was trying to hook it up to read fuel preasure . Think he was going to do it to read volts and see if they could convert it or some thing
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
torchkc
Sep 11, 2015 08:26 PM
