APS ST SES light on..help please
Old Aug 10, 2005 | 05:54 AM
zman1910's Avatar
zman1910
Default APS ST SES light on..help please
Anyone know what it could possibly be and where I can take it to see what it is exactly. Did someone say autozone can check it for free? or are there any other places that wont charge an arm and a leg. I wonder if its due to the deletion of the cats.... Thanks for any help guys
Also if it helps the light came one when I didnt have any gas in my car. I just filled up and now it still wont go off but I'll have to check again in a few hours.
Old Aug 10, 2005 | 06:14 AM
taurran's Avatar
taurran
Yeah, you can go to Autozone, Advance Auto, etc, and they should be able to plug it in and check the code for free.
The plug is down and to the left of the wheel, right below your hood release.
Old Aug 10, 2005 | 06:20 AM
theking's Avatar
theking
Unfortunately you are probably going to get this on and off because of the ST. Anytime you scale for injectors it is going to throw these codes intermitently(p0300 - random misfire). I just bought a $125 scanner and leave it under my passenger seat. It's much easier than doing the throttle pedal hastle. Hasn't happened to me much but I like having the scanner anyways in case something else weird happens. I will probably throw the code more than you though due to my cams and port & polish. If this is the code(p0300) according to other people on this board it does not effect performance. Hope I help.
Alan
Old Aug 10, 2005 | 06:37 AM
taurran's Avatar
taurran
Alan
I have had the multiple missfire code about four times since I had the turbo in. It's been very random, and happens on startup but doesn't effect performance at all. Come to think of it, I was pretty low on gas the other day when it happened.
I'm running 1 step colder plugs and a shielded CAS wire. We've been trying to determine what might cause it, and I'm starting to think it's a crank angle sensor issue. My car was produced in Aug 02 and others in the VIN range had a CAS recall. For some strange reason, mine did not get recalled.
I don't think there's an actual problem to be concerned with unless it repeatedly throws the code whilst under boost. It's just kind of annoying, that's all.
Old Aug 10, 2005 | 06:55 AM
xxlbeerZ's Avatar
xxlbeerZ
If you have a laptop you can get a scanner/datalogger plus a plug for like $60-100.
Old Aug 10, 2005 | 07:46 AM
xsmallpaulx's Avatar
xsmallpaulx
yeah i get the same codes every once in a while. i hope its not a big deal
Old Aug 10, 2005 | 07:47 AM
zman1910's Avatar
zman1910
What setup are you running?
Old Aug 10, 2005 | 07:55 AM
Madelinot's Avatar
Madelinot
I installed the APS TT about a month ago, almost 2000 miles since then. I was expecting some codes to be thrown off, especially at first. I never got any, nothing, nada. I have a reader and can reset them if I need to.
I know that doesn't help your situation, but good luck and let us know....
Later,
Old Aug 10, 2005 | 09:32 AM
taurran's Avatar
taurran
Is this something that's isolated to 2003 models? Anyone get this on an 04-05?
Old Aug 10, 2005 | 10:15 AM
zman1910's Avatar
zman1910
My car is an 04 model......and I just reset the code...it was multiple cylinder misfires so I'm not worried. I now have about 3k miles on the turbo so I'm racking up miles quickly. Everything seems to be holding up nicely...even after my little accident.. Thanks for all the help guys...
Old Aug 10, 2005 | 07:03 PM
xsmallpaulx
greddy twin turbo built bottom end, aam fuelsystem, rc 650 injectors, technosquarereflash,still using my emanage (530whp pumpgas)
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
