Blew My Motor On A Aps Tt
Old Oct 13, 2005 | 09:18 AM
  #101
captj3's Avatar
captj3
Originally Posted by 350zDCalb
the dipstick reading is difficult on these motors because of the channel that the dipstick is threaded through before it dips into the lower oil pan. Oil will splash up into the dipstick "canal" and cover much of the bottom half of the dipstick with oil, making it very difficult to decifer where the oil line begins and where the oil splash ends...the easiest way to see what is going on is to allow the oil to settle and drip back into the lower oil pan...
the reason that one could not be 3 quarts low if they saw any sort of reading on the dipstick, is because at about 1.5-2 quarts low, the dipstick will not have any oil present!!! at 3 quarts low, the oil level is well below that of the lowest point on the dipstick
hope that explains the why...
I agree the dipstick is a pain to read. The best reading is when cold. I have the aps oil pan my next change I check the level with 2.5 - 3qts in the motor. They may not have checked the oil in a long time or didn't put in the right amount at the last change.
Old Oct 13, 2005 | 09:30 AM
  #102
Alberto's Avatar
Alberto
Cranky FI Owner
Jimmy sorry to hear of your troubles, stay with it, things can only get better. As far as the tune goes, I wouldnt have left AA(or if you werent there I would have sent somebody more knowledgable) if they gave me a TT Z with a/f around 13.1, I dont care if it was at 3000rpm's or redline imo thats too lean for FI. Who knows what the hell they did with the timing. Seeing as how your in Jersey why didnt you take the car where Jason @ MRC tuned his 11 sec APS beast? Did you think that tune was ok when you saw those dyno numbers? I would have not been happy with those a/f's. Good luck to you in the future.
Old Oct 13, 2005 | 10:59 AM
  #103
Nealoc187's Avatar
Nealoc187
That tune is jacked. The lower number on there is TOTALLY F'd up, and even after you had it tuned it's still pretty damn bad. 13:1 when you are boosting through 3000rpm? That's retarded. Whoever tuned your car at AA needs to go back to EFI Tuning 101 I think...
Sorry to hear about your car.
Old Oct 13, 2005 | 11:12 AM
  #104
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Gman2004
By blown I think he was referring to Z's and G's that are FI with no problems.
ah...that makes a lot more sense..
Old Oct 13, 2005 | 11:40 AM
  #105
Aquineas's Avatar
Aquineas
Sorry to hear about your loss. This is interesting though because I *believe* this is the first 300hp failure that's been widely publicized. The "oil was low" rumors that seem to be flying about are confusing the issue a bit. I wonder how the rods themselves held up? Those were supposed to be beefed up...
Also, how long had the car been sitting while you were in Iraq?
Old Oct 13, 2005 | 11:47 AM
  #106
ThetunerFestNJ's Avatar
ThetunerFestNJ
They had to add 3 qts to get the oil level to reach the LOW level on the dipstick.On an APS car the LOW mark on the dipstick represents a full oil level.
So just to clarify, JIMMY's CAR WAS ALOMST 3QT's OF OIL LOW On top of that the oil was REALY filthy,and he said he was about 1000 miles overdue for a change.
Old Oct 13, 2005 | 01:22 PM
  #107
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
i just want my car running strong again... whats done is done...im not blaming anyone except myself.. i knew what i was getting into when i went FI.. im not the first to blow an engine and im not gonna be the last.
Old Oct 13, 2005 | 01:27 PM
  #108
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
and just to clarify i wasnt at full boost it was probably at 2 or 3 psi when it blew.. but not getting on it hard at all.. just slightly acceling to pass a car
Old Oct 13, 2005 | 01:46 PM
  #109
Mike@Altered's Avatar
Mike@Altered
Originally Posted by Phatmitzu
...I just had my Tnetics ST installed last Saturday. Standard reflash with some leftover N/A mods. I sit at 15.x a/f at idle and 10.x at wot. Am I okay? 15.x at idle is not too lean? I had 14.5 at idle when I was N/A...
Hey everyone this is Mike from Atlered Atmosphere, where Jimmy's car was last tuned.
With the Tnetics ST it is normal to see high 14's/low 15's at idle (this is normal and safe with any 350Z/G35 na & turbocharged setup). 10.x at wot is more than sufficient fuel to keep the engine happy.
After looking at the dyno graph Jimmy scanned it is very easy to mistake the APS Baseline run (the first run we made before changing any tuning) which is leaner low-mid rpms than his tune from us on the same chart (our tune is the very light line). On the note of a/f tuning, if you look at other recent graphs of tuned Tnetics & turbo setups on the forum you will see our a/f is very similar to those.
After the 109th 350Z/G35 we've dynoed Jimmy's G was setup right. My personal 350Z twin turbo has a less concervative tune than Jimmy, makes 450rwhp @ 9psi, and doesn't skip a beat.
When I am done with the final tune on the dyno I make slight fuel adjustments (enrichments) I've learned over the past 10 years tuning vehicles to ensure best relaibility. So the final a/f is .2 to .3 a/f richer than displayed on the dyno graph.
Why do we do this? Because off the dyno most vehicles will need additonal fuel to help compensate for factors such as the intercooler working more efficiently / cooler denser air.
I called & left a message and e-mailed Jimmy to see if there is anything we can do to help him out with his unfortunate circusmstances. I'll write an update (and more elaborate post if Jimmy gives me the okay) when I get intouch with him.
Old Oct 13, 2005 | 02:35 PM
  #110
neffster's Avatar
neffster
Sorry to hear of your misfortune Jimmy. Here's to hoping your block is 100% intact and everything will go smoothly with your engine build.
Old Oct 13, 2005 | 02:54 PM
  #111
Fairlady_z33's Avatar
Fairlady_z33
Guys im sorry to be a little behind but What is The stock ocatane setup from the APS TT. Becouse i use 93 since the first day.
Old Oct 13, 2005 | 03:08 PM
  #112
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
They are preset to 91 octane fuel.
Old Oct 13, 2005 | 03:10 PM
  #113
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The rods aren't the issue here. 287 or 300hp motor wise. It's become the general consensus that since we have more people that ever boosted and less failures than ever, that 95% of these motor failures are tuning, install or upkeep issues. No one knows the strength of the stock rods yet because we don't have a consistant high power level that motors "pop". When you start seeing guys reaching a power limit where half or more of them blow up if they go any higher, that's when we'll know that we've reached the limits of the stock rods or pistons.
Old Oct 13, 2005 | 03:16 PM
  #114
Sharif@Forged
Forged Performance
sorry if I missed this, but do we know what broke on this motor?
Old Oct 13, 2005 | 03:19 PM
  #115
Fairlady_z33
Is it ok to use 93 octane with the stock engine with the out of the box tune
Old Oct 13, 2005 | 03:25 PM
  #116
Sharif@Forged
Forged Performance
Absolutely....you will be even safer.
Old Oct 13, 2005 | 03:29 PM
  #117
Fairlady_z33
no to be anoying but why does it make it safer And thanks
Old Oct 13, 2005 | 04:05 PM
  #118
freezeg35's Avatar
freezeg35
I belieive higher octane is harder to burn, which means less chance of pre detonation.
Old Oct 13, 2005 | 04:24 PM
  #119
Fairlady_z33
Ok thanks alot for all ur help
Old Oct 13, 2005 | 05:43 PM
  #120
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
No...it burns more slowly. Detonation is an "explosion" in the cylinder. Higher octane fights off this explosion tendency more effectively.
