Torque
Old Nov 16, 2005 | 06:26 PM
charged's Avatar
charged
Default Torque
I have a Vortec supercharger and my rwhp is at 376 but my torque number is at 309. Why so low. What will increase it?
Old Nov 16, 2005 | 06:29 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
superchargers are belt/pulley driven....you scarifice torque because you have to drive the supercharger from the engine whereas a turbo setup uses exhaust pressure.
Old Nov 16, 2005 | 06:54 PM
booger's Avatar
booger
The SC's boost increases with rpm . So when we are at 4500 rpm , your boost is only 1 to 3 psi and a TT car has full boost at 4500rpm . So you will not see the same trq increase as you do hp , over a stock car
Old Nov 16, 2005 | 07:39 PM
sentry65's Avatar
sentry65
the burninator
charged, how's your traction? Do you easily spin out your tires or not really?
If you had ton more tq like the ST or TT people do, you might have traction problems
Old Nov 16, 2005 | 08:00 PM
phunk's Avatar
phunk
CJ Motorsports
what someone else posted in correct, the centrifugal superchargers do not make enough boost low enough in the RPM for the bad *** peak torque numbers that the TT's make... but that doesnt mean they cant haul ***!
Old Nov 16, 2005 | 09:25 PM
luanda's Avatar
luanda
Still, that number is a bit on the low side...I would have thought it be closer to 330...did you have your setup tuned on the dyno?/ What's your A/F like??
Old Nov 17, 2005 | 02:38 AM
Barzten1's Avatar
Barzten1
I wouldn't mind my torque #'s being in the 350 range
Old Nov 22, 2005 | 01:50 PM
charged's Avatar
charged
My Rear wheels do spin a little and i have Toyo Proxi 275's. The car was Dynod twice. Air fuel is at 14psi.
Old Nov 22, 2005 | 06:35 PM
overZealous1's Avatar
overZealous1
air fuel is at 14psi? well thats your problem right there. pump that up to like 20 and you will be golden, sir!! hahaha
Old Nov 24, 2005 | 03:06 PM
g35twinturbo's Avatar
g35twinturbo
hahahahahhahahah
EnjukuRacing
Sep 30, 2015 06:55 AM
RWDBajan
Sep 17, 2015 04:52 PM
raceboy
Jan 15, 2003 10:18 PM
atcga
Nov 10, 2002 10:45 AM
N4Spd
Jul 4, 2002 10:22 PM
