S/C vs ST take# 1,000,001
Old Dec 25, 2005 | 12:19 PM
  #141
Oleg's Avatar
Oleg
Originally Posted by MRC Motorsports
Im just curious, what swayed you towards HKS?You seem to be quite aware that they are way overpriced...
Oleg...
Seriously, there are cons in every set up,including the TT's..However for what your planning on doing you are going WAAAAAY overboard..
I am not swayed towards the HKS kit per se...
But having determined that the centrifugal blower is the direction I'd like to take with the FI, I liked Rotrex for 2 reasons: it's quieter and more efficient then other units, and it has a fully independent, most complete (filter, cooler, etc) lubrication system from the car's stock one.
BTW, I had no clue that the custom braket is such a hassle....
I can wait on IllZ to finish his and see what he spends and what he achieves. He'll be doing it through AAM and I am sure that they wound not mind replicating that setup on my Z.
Now that I am thinking about it, the HKS-spec bracket will only fit the HKS-spec blower. Anything else will cause issues with the headunit size and pulleys being misalligned, etc etc, a few milimeters of a difference will at least eat up the belt... It will probably be about 10 brackets to make and discrad for not working until the 11th one fits... Doing a custom one will cost me as much as it costs a company to develop a full kit, all in all it will be the Dreamworkes Supercharger redux...
It's not even that much of a money issue, it's more like after spening a crapload of cash, will I have the desired drivability. So either way you go, some compromise will have to be made...
Alright, jeeneyus at MRC. Now that you have shot down in flames all of my theories/speculations/proclamations/expectations about FI, give me an idea. From this thread you have seen my goal in power/drivability. How would YOU achieve it? I don't care if it's an SC, single, twin, triplet turbo, engine swap, whatever as long as there is no nitrous involved, I keep my bumper support and the maintainance is not too much for someone with absolutely zero mechanical aptitude (ME!!!)... And see if you can keep it under 10 grand (including the gauges).
Old Dec 25, 2005 | 01:19 PM
  #142
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
But the Vortec instructions tell you to tap the upper oil pan..Not sure if it makes a difference or not.But tapping a spacer would be something I am more comfortable with..
Yup, works fine. Actually, the TN kit also requires you to tap the upper oil pan. The only reason they suggest this, is because there is no flat surface to safely tap the lower pan. A lot of customers will purchase the oil pan spacers, to avoid touching the OEM upper oil pan, and the oil drains just fine. It's a much cleaner install, and avoids the potential of introducing metal shavings into the oil, as you mentioned.
Old Dec 25, 2005 | 01:22 PM
  #143
Sharif@Forged
Forged Performance
Hey Oleg, you've been doing research on your FI kit for months now. You are certainly, already well informed on the various options; you and I have had numerous phone conversations on this too.
I think its about time to bite the bullet and make a decision. You will find that none of these kits are going to meet every single one of your needs, and none of them are perfect. You can put yourself in all off these kits for $10K or less. If you are looking for a set-it-and-forget-it kit, quite frankey, they do not exist. Even the venerable APS kits have their share of issues to tackle, and periodic tweaking to keep everything running correctly.
Old Dec 25, 2005 | 02:08 PM
  #144
illZ's Avatar
illZ
I don't believe this is the case. The "HKS" blower is simply a C30-94. If anything it has a custom spec trim. Not housing. I have studied the drawings and I don't believe there to be any difference.
Old Dec 25, 2005 | 02:16 PM
  #145
illZ's Avatar
illZ
I have not spoke at length with AAM creating a custom bracket. They will be doing the tuning. That's all I stated.
I have three companies interested in doing CNC work for me. One being a local machine shop that I used to get my builds done at.
Old Dec 25, 2005 | 02:19 PM
  #146
Oleg's Avatar
Oleg
Month, try OVER A YEAR!!!
I was using my condo project to rationalize my reluctance to make a desicion, but not that I live in it, after this winter I have absolutely ZERO excuses.
Old Dec 25, 2005 | 08:26 PM
  #147
Sharif@Forged
Forged Performance
A'men to that brotha!
Old Dec 26, 2005 | 09:33 AM
  #148
Julian@MRC's Avatar
Julian@MRC
You need to be the ultimate judge of what will satisfy you and your driving habbits, not me or anyone on this forum..What I was simply trying to bring to light was the fact that, as Shariff stated, there are not "set it and forget it" applications on the market.In fact F/I basically doubles your maintainance schedule, regardless of what application is selected..All to often people think that the F/I kit bolts onand they can beat the crap out of the car and when something goes wrong they blame and flame the installer or the manufacturere of the kit.. I am simply trying to help you answer your original post..SC VS TT and bring to light the CONS of both systems as well as the pros...You will hardly find a salesman be honest enough to tell you up front that each and every kit, including the ones they sell has issues on its own that need to be addressed..
At this point based on your expectations you can either get the HKS kit and leave it as it is, it will work fine...Or get an ATI or Vortec kit and add good enginemanagement and fuel system and be done with it...You seemed to already have made your choice from TT to SC, now its just a matter of narrowing your choice down to what kit you can live with and maintain properly...
Old Dec 26, 2005 | 10:25 AM
  #149
LOU's Avatar
LOU
Agreed. Anytime you force a car to do more than it was built for, things can and will go wrong and regular maintenance is definitely increased. But in the end, it is always worth it.
Old Dec 26, 2005 | 04:29 PM
  #150
Oleg's Avatar
Oleg
I am acting like a 16 year old virgin before a senior prom. It's only a car, what's the worst that could happen...
Old Dec 26, 2005 | 06:58 PM
  #151
sentry65's Avatar
sentry65
the burninator
boom, $5k down the drain
Old Dec 26, 2005 | 07:00 PM
  #152
failsafe306's Avatar
failsafe306
Gee Oleg, I sure hope that whatever kit you decide on doesn't put a window or two in your block! You gotta be careful with these things! One little tiny f-up will cost you your whole motor!
Old Dec 26, 2005 | 07:39 PM
  #153
Julian@MRC's Avatar
Julian@MRC
Gee...I wonder what could go wrong...
Old Dec 26, 2005 | 09:05 PM
  #154
LOU's Avatar
LOU
Or this...
http://pg.photos.yahoo.com/ph/omfgti...&.dnm=6f6b.jpg
Old Dec 27, 2005 | 05:42 AM
  #155
Oleg's Avatar
Oleg
Great...
Let me stall the desicion making process for another year or so, just long enough for the dealerships beginning to take pre-orders on the GT-R...
Old Dec 27, 2005 | 05:58 AM
  #156
WA2GOOD's Avatar
WA2GOOD
Great...
From what I know about the timing of the release of the GT-R................HAA!....try a couple more years.
Old Dec 27, 2005 | 08:37 AM
  #157
sentry65's Avatar
sentry65
the burninator
I would so never buy a 1st year car during it's crazy introduction period
you pay a lot more and go thru the stress of getting on waiting lists etc for a version of the car that's more buggy vs waiting a couple years later and getting the car lightly used for 2/3 the price.
Old Dec 27, 2005 | 09:07 AM
  #158
Oleg's Avatar
Oleg
If I started my project all over, I would have bought a used 2003 (base) in mid 2004 and built the living hell out of it...
Old Dec 27, 2005 | 09:53 AM
  #159
LOU's Avatar
LOU
I too wish that I had purchased a Base model. Stupid alluring Touring features. But then again when I bought the car, I wasn't planning on changing everything.
Old Dec 27, 2005 | 10:24 AM
  #160
Oleg's Avatar
Oleg
This was supposed to be the car I would buy and not have to change anything with...
Sometimes I do regret not buying a white '99 Supra I was looking at when I was buying the sportcar...
aron
Jul 23, 2004 03:24 PM
mmorris
Australia/New Zealand
May 4, 2004 01:59 AM
Chebosto
Sep 2, 2003 11:42 AM
3rdpower
Nov 7, 2002 05:47 PM
