Just started my Turbonetics Install !!
Old Jan 11, 2006 | 10:43 AM
  #221
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Alberto
So it coud be a TPS? Hmmm how much is a TPS anybody know? I may just purchase one and try....
I have no idea how much that sensor would costs but if its a ridiculous amount of money PM me and I'll hook you up with my parts guy here and see if he can cut you a deal...
Old Jan 11, 2006 | 10:51 AM
  #222
Alberto's Avatar
Alberto
Cranky FI Owner
Omfg You cannot just replace the sensor-its part of the TB. Which is $663.55 + 7.14 for the gasket. Well I am SOL, thats wayyy more than I was hoping for. I will order an OBDII reader and verify this before even thinking of doing that, just my luck-f*ck me
Old Jan 11, 2006 | 10:52 AM
  #223
35ounces's Avatar
35ounces
03 CS Track 6MT
Can't get Nissan to replace it for you?
Old Jan 11, 2006 | 10:58 AM
  #224
Alberto's Avatar
Alberto
Cranky FI Owner
Dont have a mod friendly dealer, and I cant even drive my car there....
Old Jan 11, 2006 | 11:08 AM
  #225
97supratt's Avatar
97supratt
Try finding a used TB, it'll save you a few hundred... Good luck
Old Jan 11, 2006 | 11:09 AM
  #226
BobbyRitz's Avatar
BobbyRitz
You prolly know this, but I've heard Frederick Nissan is mod friendly.
Sorry to hear about your problems.
Old Jan 11, 2006 | 11:14 AM
  #227
Alberto's Avatar
Alberto
Cranky FI Owner
Lol, yeah right. They install mods and sell $hit for OUTRAGEOUS prices, I wouldnt consider them mod friendly. I called for a clutch/fw install quote just labor-they said $1000 That place should be burned down. Thanks for the suggestion though.
So will any used TB work on my car? Or does it have to be year specific?
Old Jan 11, 2006 | 11:18 AM
  #228
chimmike's Avatar
chimmike
a few suggestions.
based on my past experience with boosted cars, here's a couple scenarios.
the surging on throttle could be leaky pipes on the turbine inlet. So somewhere between the headers and the turbo might be a leak.
As for the stalling, the bov is recirc'd, isn't it? with the tnetics kit? I'm not positive, just asking, as the MAF can flip out sometimes and stall (but it's draw through, so this shouldn't be the case)....or perhaps there's a leak in the throttle body itself or gaskets or the plenum somewhere, which would allow metered air to escape and therefore the MAF would go all whacky and cause the car to stall.
Just from my experience those are a couple possible causes. I had the surging before, and that was from a leak in the turbo manifold/head bolt up. A simple gasket replacement made it 100% better.......and on the stalling, a new clamp (or possibly in your case, new gaskets) might fix it. Or checking the torque of the plenum as you had to remove it for the injectors.
did you put on new gaskets when you reassembled the plenum?
just some suggestions to prevent you having to buy a new tb.
Old Jan 11, 2006 | 11:20 AM
  #229
Zivman's Avatar
Zivman
Call Jim at proflow www.proflowdesign 425-255-9706
he should be able to find you one for about 250 bucks
Leave a message if he doesn't answer
Old Jan 11, 2006 | 11:27 AM
  #230
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by chimmike
a few suggestions.
I torqued everything down correctly, and I dont have any vacuum leaks so I doubt it would be the plenum. Its not a stalling like you would get from a car with a vacum leak its a complete engine turn off, or drop to idle with loss of throttle control. We dont remove the exhaust manifolds on the TN install so Id be doubtful that the head/exhaust manifold gasket would be bad, but I will double check everything. And no I didnt put on a new gasket when I did the plenum, but I do have one now, and Ill replace next time the plenum is off. I guess I can always get a used TB, I REALLY appreciate all the advise and suggestions guys.
Thanks for the suggestion man, very helpful. I have already had offers from people with used TB's, if things fall through Ill contact him. Thanks again
Old Jan 11, 2006 | 11:32 AM
  #231
chimmike's Avatar
chimmike
no not the header gaskets, but the gaskets of the tn pipes to the turbine inlet, maybe there's a leak there?
Old Jan 11, 2006 | 11:37 AM
  #232
Alberto's Avatar
Alberto
Cranky FI Owner
Oh, no leaks there. I do have 1 small leak between downpipe 2 and 3 way out back, other than that Im leak free....but I will def double check. Thanks
Old Jan 11, 2006 | 11:38 AM
  #233
Alberto's Avatar
Alberto
Cranky FI Owner
BTW was looking up used TB's on www.car-parts.com As cheap as $150 and up....so thats an alternative. Im waiting on Jims call back to see if you can use any year TB with any year Z. I may just go ahead and buy a bored TB.
Old Jan 11, 2006 | 11:59 AM
  #234
Zivman's Avatar
Zivman
being how sensitive these TB are, try to find one with a record attached to it. Jim found me one off a low milage 05. I believe you can use any yr TB on any yr car
Old Jan 11, 2006 | 03:33 PM
  #235
twodown's Avatar
twodown
This could be your lucky day. There is a guy selling one on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...Pr2_PcY_BID_IT
good luck
Old Jan 11, 2006 | 03:55 PM
  #236
Alberto's Avatar
Alberto
Cranky FI Owner
If something like the TB chamber/TPS inside fails wouldnt it stay like that? I reset the ecu by leaving the battery unplugged, and now it seems fine. I know the problem will return though, so I guess I have to go drive it.....btw thanks for the link twodown
Old Jan 11, 2006 | 04:01 PM
  #237
35ounces's Avatar
35ounces
03 CS Track 6MT
well FWIW I think Sully said that he was able to turn the car off and get it to run again also. It could be that it needs calibration???
Old Jan 11, 2006 | 04:12 PM
  #238
chimmike's Avatar
chimmike
yeah, if you reset the battery and the problem isn't still there, it doesn't sound like it's a permanent thing....if the part was bad the problem would always be there.......
Old Jan 11, 2006 | 04:33 PM
  #239
Zivman's Avatar
Zivman
are you getting SES code? I thought you were?
Old Jan 11, 2006 | 05:23 PM
  #240
Alberto's Avatar
Alberto
Cranky FI Owner
I was getting a CEL, but after res-setting the ECU, I figured the problem would come back immediately but I guess not. Last time it took about 3 miles of driving to get the car to drop to idle and make me lose throttle input. And that was after I did the TB resets....I think its weird it wont automatically throw a CEL even after resetting the ecu. Tomorrow Im ordering an OBDII reader/software from www.digimoto.com Ill pull the codes before purchasing another TB
