nismo cams w/ Vortech SC
Old Mar 8, 2006 | 08:49 AM
chris'smax's Avatar
chris'smax
Default nismo cams w/ Vortech SC
When running the nismo cams(262 duration 10.8mm lift) w/ a Vortech SC, would it be necessary to raise the rev-limiter to see the power gains? I know that aftermarket cams shift the power curve further to the right on a dyno graph and have seen some dyno's w/ this setup, but i can't remember if they had raised the rev limiter.
Old Mar 8, 2006 | 10:52 AM
sentry65's Avatar
sentry65
the burninator
the nismo cams actually just gain power all around
more aggressive cams will start to gain more power up high, and less down low
Old Mar 8, 2006 | 11:11 AM
booger's Avatar
booger
I have them with my Vortech SC . You can really feel them kick in at 3000rpm . Even when I have the cog belt off and not running the SC
Old Mar 8, 2006 | 11:34 AM
chris'smax's Avatar
chris'smax
Do you think that is becuase of the vct or just the specific grind of the cam? The reason i ask is because i am installing this motor in my maxima(FWD 3.5L) and in order to bolt my SC on i have to remove the vtc and install my 3.0L timming chain cover. So therefore i will not have the vct.
Old Mar 8, 2006 | 12:14 PM
booger's Avatar
booger
VCT or VTC ? not getting either . If your talking about variable timing control . My 03 doesnt have it
Old Mar 8, 2006 | 01:10 PM
chris'smax's Avatar
chris'smax
yes the variable timming control. Why doesn't yours have it?
Old Mar 8, 2006 | 01:26 PM
booger's Avatar
booger
I think just the new motors have it..05...06 ?
Old Mar 9, 2006 | 02:25 AM
S12 driver's Avatar
S12 driver
I think the pre-06 motors do have VTC, but it's just on the intake cam, the 06+ have it on both intake and exhaust cams.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
chris'smax
Oct 9, 2007 04:47 AM
Alang
Jul 22, 2006 09:23 AM
chris'smax
Mar 10, 2006 01:38 PM
LOU
Oct 10, 2004 03:44 PM
