Will G35 vortech kit work on a 350z?
Old May 24, 2006 | 01:17 PM
RA11325's Avatar
RA11325
Default Will G35 vortech kit work on a 350z?
Hey guys,
Im talking to a guy right now that has a sweet deal on a vortech kit here in FL but it is off of a G35, what is the difference between the 350Z and G35 kits? If it is something small could i modify it to make it work?
Thanks in advance.
Old May 24, 2006 | 02:39 PM
THE TECH's Avatar
THE TECH
You can call Vortech and they can tell you the difference or check their site which has parts lists for both kits. The FMU is definitely different, but something easy to change.
Old May 24, 2006 | 04:00 PM
Forced's Avatar
Forced
The Split Second box also has a different calibration in it...
Old May 24, 2006 | 04:48 PM
booger's Avatar
booger
why would that be any different Forced ?
Old May 24, 2006 | 05:09 PM
RA11325's Avatar
RA11325
So would the Split Second box work if i took it and got it tuned at a local shop? Or do i need to purchase a 350z specific vortech box?
Old May 24, 2006 | 05:10 PM
RA11325's Avatar
RA11325
Lemme rephrase this, exactly what all would need to be changed to make a G35 kit work on a Z?
Old May 24, 2006 | 08:19 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Nothing, except for retuning the split second box (Vortech might have changed this recently). Everything will work. :thumbup
Old May 25, 2006 | 06:03 AM
THE TECH's Avatar
THE TECH
Well you will also need to deal with changing the disks in the FMU as the Vortech manual states.
Old May 25, 2006 | 06:06 AM
chimmike's Avatar
chimmike
uh oh! He's looking at FI now!
lol. must be stemming from when I dyno'd within 1whp of you at z-fever
Old May 25, 2006 | 06:38 AM
Sharif@Forged
Forged Performance
THe manuals are often outdated. The user should always confirm with Vortech.
Old May 25, 2006 | 06:40 AM
THE TECH's Avatar
THE TECH
Always a good idea.
Old May 25, 2006 | 11:10 AM
Forced's Avatar
Forced
OK here's the situation...
The only difference between
4NZ218-010SQ (03-04 350Z)
4NZ218-020SQ (04 G35)
4NZ218-030SQ (03 G35)
...is the program installed on the Split Second box. These three systems all have an 8:1 FMU. The 05 systems have a 7:1 FMU.
Old May 25, 2006 | 01:53 PM
RA11325's Avatar
RA11325
Thanks for the help guys.
Old May 29, 2006 | 09:05 AM
buffmanjeff's Avatar
buffmanjeff
I actually can attest to this and sharif is correct, if its an 05' model they changed the some things so its used for both g35 and Z. I was suspicious when i ordered the kit and when i was checking parts alot of parts (such as the ss box) said g35 on them. I called up vortech and they confirmed. Looks like u are running an 04' but for 05' should be the same. The manual IS outdated!!! All they did pretty much was change the date rate on the coversheet.
Old May 29, 2006 | 09:13 AM
Sharif@Forged
Forged Performance
Originally Posted by buffmanjeff
I actually can attest to this and sharif is correct.
Buffman, THANK YOU for spelling my name correctly.
JjL
East Canada
Jun 12, 2019 03:04 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Shane86
Sep 17, 2015 05:33 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
