Tn + Ssv
Old May 30, 2006 | 08:44 AM
VipeR-Rt10's Avatar
VipeR-Rt10
Question Tn + Ssv
what are you guys using for tuning? i'm looking into a utec but don't know any place to tune it. is there a preset program for this mod w/tn? My setup is Tn w/ just exhaust. I don't want to buy unnecessary stuff. Also when my car hits 6400rpm the motor pings and it starts losing power. why is that? i thought the power was atleast up to 7k rpm. thanks
Old May 30, 2006 | 08:50 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
You are pinging probably because the TN's ECU flash isn't really suited for your set up. You shouldn't boost it until you get UTEC and get it tuned.
Old May 30, 2006 | 08:53 AM
MIAPLAYA's Avatar
MIAPLAYA
I would like to know what your AFR is. Fuel pressure? boost pressure? etc. I don't recall anyone running the SSV without some sort of tuning
Old May 30, 2006 | 09:03 AM
chimmike's Avatar
chimmike
i'd like to know if your rod bolts are upgraded, and if not how long you expect the stock rod bolts to hold up to the high rpm use?
Old May 30, 2006 | 09:25 AM
mojo powered's Avatar
mojo powered
Please don't take it as if I'm being sarcastic I am not.
Are you sure you're not hitting the rev limiter as you call it "pinging"? What year is your car? 2005 non-revup and older have their rev limiter set at 6600rpm.
Old May 30, 2006 | 10:30 AM
VipeR-Rt10's Avatar
VipeR-Rt10
it could be my rev limiter. i thought tn reflash raised it. i have an 03'.
mia: i have not installed the ssv yet until i get everything needed for tuning and such.
the reflash is fine so far, My a/f is between 11.5/12 397rwhp. just would like to know what is the easiest tuning method before i spend a sh$t load of money for nothing. thanks
Old May 30, 2006 | 10:31 AM
MIAPLAYA's Avatar
MIAPLAYA
Unless you have a 5AT kit your rev limiter is set to stock. If you have a 6MT and are trying to hit 7000 you are DEFINITELY bouncing off the revlimiter...
Old May 30, 2006 | 11:11 AM
taurran's Avatar
taurran
Yeah, sounds like you're jsut bouncing off the rev limiter. If you really want to, you can raise it once you get the UTEC installed. Other than that, I'll just say that I'm not a fan of the SSV and prefer my plenum spacer/powdercoated plenum any day of the week.
Old May 30, 2006 | 11:54 AM
chimmike's Avatar
chimmike
it's usually a good idea to be sure of what they do before trying to rev to 7krpm and NOT REALIZING YOU'RE HITTING THE REV LIMITER!
btw: revving to 7k on stock rod bolts on your motor is going to put it at risk of throwing a rod. If you want to rev higher, put on some ARP rod bolts, get some cams (stock cams don't make much power higher up) and valvesprings.
Old May 30, 2006 | 12:59 PM
VipeR-Rt10's Avatar
VipeR-Rt10
thanks for all the inputs. so how about the tuning? i have the 5/16 spacer right now and it's running fine.
Old May 30, 2006 | 01:59 PM
MIAPLAYA's Avatar
MIAPLAYA
Don't really need to tune the car for that mod that I have seen. If your afr is at 11.7:1 you are fine. Just stop hitting the revlimiter.
Old May 30, 2006 | 02:58 PM
VipeR-Rt10's Avatar
VipeR-Rt10
Actually I'm going to install the SSV so the spacer is coming out.
Old May 30, 2006 | 03:46 PM
chimmike's Avatar
chimmike
11.7 seems a little lean for the spacer......I've been running 10.8-11.2 but no leaner than that.
Old May 30, 2006 | 05:00 PM
MIAPLAYA's Avatar
MIAPLAYA
You also have 93 octance. Not sure what this guy has..
Old May 30, 2006 | 05:51 PM
VipeR-Rt10's Avatar
VipeR-Rt10
CA, 91 octane. Is there anyone in LA who can tune the utec or E-manage Ult.?
Old May 30, 2006 | 06:03 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
I rev to 7K all day long!!! Love rev-up!
Old May 30, 2006 | 07:26 PM
MIAPLAYA's Avatar
MIAPLAYA
You can check Danzio Performance in Lake Eslinore. They can tune just about anything. www.danzioperformance.com Them or GT Motorsports in Rancho Cucomanga.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
Orlando333
Jan 9, 2006 06:08 AM
Rizlam
Dec 24, 2005 09:46 AM
350zlove
Sep 26, 2005 12:00 PM
SungNamZ
May 31, 2005 12:03 PM
