Pistons and rods
Old Dec 13, 2006 | 12:34 PM
KempieZ's Avatar
KempieZ
Default Pistons and rods
If my 350z aps tt has more than 450whp on a stock block, what would you change on the inside? I am going to install a stroker kit within the next two years, but for now, is it good enough to just install stronger rods and pistons?
Arias 9.0:1 Extreme Duty Pistons -20 Over
Old Dec 13, 2006 | 01:35 PM
dutchboy's Avatar
dutchboy
Are you doing the work yourself? If you're having it done by a shop, it could save you alot of money to do it all at once. The labor is pretty expensive.
Old Dec 13, 2006 | 01:50 PM
roncfpz's Avatar
roncfpz
The answer depends upon your HP goal. Do you plan on keeping it at 450whp or go higher?
Old Dec 13, 2006 | 03:20 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I wish it were that simple. Changing rods and pistons entails an entire shortblock rebuild and the associated labor. So doing this now, and then doing a stroker kit later will result in a pretty heavy bill.
Like Ron mentioned, define your goals, and then start planning and saving. Do everything at once to maximize your dollars.
Old Dec 14, 2006 | 09:28 AM
KempieZ's Avatar
KempieZ
The kit is being installed on week after newyear. I am hoping that it will reach 450whp(more than possible). 480whp is my goal. Next year in march brakes and springs and wheels. 2008 stroker.
So can my standard block survive for 1 or two years on 450whp? ( I drive it only in the weekends on low boost. Drag racing once a month on high boost)
Old Dec 14, 2006 | 10:17 AM
roncfpz's Avatar
roncfpz
It may or may not; you can only do some things to help reduce the risk of blowing it. It also depends on how much you want to do to reduce the risk and how much you're willing to spend. At a minimum, make sure you get a good install and tune. I'll let the tuners chime in on other things you can do to help. Good luck!
Old Dec 14, 2006 | 08:10 PM
Cannysage's Avatar
Cannysage
you don't need a stoker kit for massive power.
Old Feb 13, 2007 | 12:14 PM
DanielW's Avatar
DanielW
So If I have a raised rev limiter (7200) and want stronger rods would it be as simple as just buying a set and having a shop install them, or would it be more detailed than that? How much would this cost?
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
