power to beak axel?stop in here
Old Dec 16, 2006 | 05:46 AM
Chas350Z's Avatar
Chas350Z
Default power to beak axel?stop in here
so i just got my engine finished from SGP racing and it was on a very safe tune of 540rwhp and went to the baytown raceway on a friday. there was barley anyone there wen i got there, i get up to the burnout box and heat up my new BFG drag radials, k so i get then nioce n sticky and i go stage up. yellow....green!...had the engine stalled up to around 4g and started to slip the clutch and B O o M. heard a lout pop from the rear. get the car off the track and found i had snapped both axels in to two pieces.
Old Dec 16, 2006 | 06:47 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
that blows!
Old Dec 16, 2006 | 06:51 AM
brooke's Avatar
brooke
Horsepower Freaks sells upgraded Axles....
http://www.horsepowerfreaks.com/pric...ivetrain/Axles
brooke
Old Dec 16, 2006 | 06:54 AM
Jay'Z's Avatar
Jay'Z
ouch!! Why did you take off so high?? I found that to be my mistake too..
Old Dec 16, 2006 | 02:36 PM
meatbag's Avatar
meatbag
Ive got a set of stock axles that you can buy. If you need something cheaper and to get you back on the road.
Old Dec 17, 2006 | 12:09 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Not always how much power but how you launch your car. I have 7000rpm launches NA, 6000rpm launches with TN and about the same with a built Greddy TT, all on stock axles...I suggest you preload the drivetrain a little more, or run a little more air in your tires.
Old Dec 18, 2006 | 06:36 AM
clemlover15's Avatar
clemlover15
wow both axles sorry to hear that, but I will be sure to upgrade my axles after hearing that. Thanks for the post it saves others from experiencing the same.
Old Dec 18, 2006 | 10:03 AM
EM-EFER's Avatar
EM-EFER
You beaked both axles?
Old Dec 18, 2006 | 10:14 AM
BamBam's Avatar
BamBam
Sounds familiar.... Another option for upgraded axles is DriveShaftShop.. They make some good stuff, Level2 or Level5 will set you straight for your power levels. But like Berto said, the launch is key. Good luck and be careful next time your at the strip..
--B
Old Dec 18, 2006 | 12:57 PM
Zilvia's Avatar
Zilvia
Sharif also sells upgraded axels
both lv2(500hp) and lv5(800hp)
http://www.forgedinternals.com/store/home.php?cat=261
Old Dec 18, 2006 | 01:02 PM
Cannysage's Avatar
Cannysage
you know the weight difference between stock and level 5?
Old Dec 19, 2006 | 10:38 AM
Chas350Z's Avatar
Chas350Z
yea just installed the dss level 5, ill post my times next time i go to the strip, ill wrk on a smoother launch too
Old Dec 19, 2006 | 10:43 AM
ACEMAN's Avatar
ACEMAN
Master
I know how you feel, i snapped the driver side. Like Alberto said, you need to preload the drivetrain alittle more. My snappage was from driver error, popped the clutch and BOOOM!!
Its not so much the axles as it is the driving. Look a Audiblemayhem, he is still on stock Axles running 10's.
Practice practice practice
Later
Todd
Old Dec 19, 2006 | 12:54 PM
Zilvia's Avatar
Zilvia
nope...........
Old Dec 19, 2006 | 01:11 PM
Cannysage's Avatar
Cannysage
running 500whp+ on stock axel is totally crazy.. stock holds 450, if you're lucky.
Old Dec 19, 2006 | 01:12 PM
sentry65's Avatar
sentry65
the burninator
i think it has more to do with launching and the level of torque the car has as well as the type of tires more than peak hp
you could probably drive on stock axels with 800whp all day long if you had normal street tires and weren't launching hard
Old Dec 19, 2006 | 01:15 PM
Cannysage's Avatar
Cannysage
^ actually that's true. you put the most stress on your axel on hard launches.
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
