tapping oil pan
Old Jan 14, 2007 | 09:24 AM
Sisith's Avatar
Sisith
Default tapping oil pan
Hey guys the used vortech kit I got didnt come with the tool or the parts to tap the oil return line. What all do I need to buy in order to do this? Is it just a tap with the fitting screwed into the tap?
Old Jan 14, 2007 | 01:37 PM
kevinapex's Avatar
kevinapex
I did it with a step drill bit, you just don't want to drill too big!
Use the step bit to drill a hole, smaller than the fitting. Use the tap to finish the hole and cut the threads.
When you run the tap in and it starts, go approx.. 1/2 turn in back out 1/4 turn, in 1/2 turn out 1/4 turn and so on, just to clear the cut thread materials out of the taps way.
Take your time!
Kevin
Old Jan 14, 2007 | 01:43 PM
kevinapex's Avatar
kevinapex
Sounds like you will need the tap, and the brass oil return fitting. The fitting is hose barb on one side and male thread on the other, off the top of my head I don't know the male thread size?
Old Jan 14, 2007 | 01:47 PM
Eazzy's Avatar
Eazzy
Take your time!
Kevin
And the tap is a 3/8 NPT-----Of course , as is , the Male side of the fitting
Old Jan 14, 2007 | 01:49 PM
kevinapex's Avatar
kevinapex
ya,,,thats it thanks bro!
Old Jan 14, 2007 | 02:32 PM
Sisith's Avatar
Sisith
Thanks a bunch guys
VIZAGE's Avatar
VIZAGE
I'll sell you these two things that you need. I never used them. There from my TN kit. PM me if your interested.
Old Jan 15, 2007 | 10:35 AM
shushikiary's Avatar
shushikiary
Just out of curiosity, and ignorance on my part... but why would you tap the oil pan when you could use a T or other split fitting on one of the oil lines that goes to the oil filter? I mean, they are already rubber hoses and they come right out of the oil pan anyways...
Old Jan 15, 2007 | 10:39 AM
Eazzy's Avatar
Eazzy
It needs to be a free flow oil dump
Old Jan 15, 2007 | 10:40 AM
Eazzy's Avatar
Eazzy
And he is (I hope) refering to the upper oilpan above the oil level in the lower pan
Old Jan 15, 2007 | 10:55 AM
shushikiary
oh, free oil dump, ok that makes sense then... thanks.
Old Jan 15, 2007 | 10:58 AM
Eazzy's Avatar
Eazzy
Are u being Sarcastic ? Or does that answer ur question ?
Old Jan 15, 2007 | 11:01 AM
shushikiary
nono, it answered the question, I didnt think it would need a totally free flow dump like that, but now that I know it needs that it makes sense that you have to tap it.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
