Alcohol/Methanol/Water Injection Q&A...
Old Apr 22, 2008 | 06:05 PM
  #221
frankie945's Avatar
frankie945
Install pic's of snow performance stage II kit I did in the DIY section
Old Apr 22, 2008 | 07:19 PM
  #222
jmcmorante's Avatar
jmcmorante
Originally Posted by athenG
You won't see much of an WHP increase unless you raise your boost or add more timing on your tune. Meth allows you to boost a littler higher or have an aggressive tune (Just like running race gas without the cooling effect). Yes, meth will lower your IAT, EGT and increase resistance to detonation so that is the safety part. I think if you have a stock motor then it is nice to have, it is going to help you more to be on the safe side just in case you get some Bad Gas or in a Hot Summer days. Just my 02.
So I guess not raising the boost or adding timing, just retuning for the meth on the stock block is a good idea for cooling purposes than? For safety? Sounds good. I think I will have this done. I wonder how many hours labor this would take so I can guesstimate a rate for install in addition to the new tune.
Thanx a bunch athenG!!
Old Sep 28, 2008 | 08:12 AM
  #223
chopperman's Avatar
chopperman
Bumping an old thread
For those in colder climates how do you keep the water in the tank and lines in a liquid state? Is there somthing that you can wrap them in?
Old Sep 28, 2008 | 08:25 AM
  #224
Ultimate CC's Avatar
Ultimate CC
Typically you would want to run a meth mix that way you will avoid freezing all together, I would not risk straight water injection in the winter months...
Old Sep 28, 2008 | 01:27 PM
  #225
chopperman's Avatar
chopperman
Im a little confused with how the pump can be controlled.
I have the F con Pro, I want to have a progressive system that will flow more as the boost builds. Do I need a seperate controller, or can the F con do that? How do you connect the F con to the pump? Thanks.
Old Sep 28, 2008 | 01:41 PM
  #226
Ultimate CC
I am not familiar with the F con Pro engine management but with a snow stage2 you would have your progressive control of the kit, but if you there is an option on the f con pro to progressive control via boost then you could wire it up to the pump fairly easily. I know people do this with the UTEC.
Old Sep 28, 2008 | 02:30 PM
  #227
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Fcon can fully control the water injection.
Who is your tuner?
They should be able to hook it all up for you.
Tony
Old Sep 28, 2008 | 02:51 PM
  #228
Ultimate CC
awesome, glad to know that...
Old Feb 25, 2009 | 10:24 AM
  #229
Barzten1's Avatar
Barzten1
subscribed
Old Feb 25, 2009 | 10:29 AM
  #230
Cass007's Avatar
Cass007
- Not a lot of updates since September of '08
Old Feb 25, 2009 | 10:30 AM
  #231
GTM's Avatar
GTM
Vendor - Former Vendor
I am selling my HFS-5 in the private classifieds if anyone is looking to install a W/I kit
Old Feb 25, 2009 | 10:34 AM
  #232
Cass007's Avatar
Cass007
Changing that too? I thought this was the best kit out there.... something better come along?
Old Feb 25, 2009 | 10:42 AM
  #233
frankie945's Avatar
frankie945
I am selling my snow performance stage 2 kit if anyone is interested 340 shipped. will post it on the market place.
Old Feb 25, 2009 | 01:08 PM
  #234
Ultimate CC
great price...
Old Feb 25, 2009 | 04:13 PM
  #235
zerosec's Avatar
zerosec
so if the UTEC can control the WI there's no need to buy snow perf stage II right ? basic one will do the job... (correct me if im wrong.)
10x
Old Feb 25, 2009 | 04:35 PM
  #236
athenG's Avatar
athenG
No, at most the Utec can only control the on/off the meth controller so you still need the controller to control the spray pattern.
Old Feb 25, 2009 | 04:43 PM
  #237
Ultimate CC
if you are running a fast spooling setup though the on/off style works great, if you have something thats laggy you definitely want a progressive controller for it.
Old Nov 30, 2009 | 03:53 AM
  #238
catcapt's Avatar
catcapt
Default aem stage II
Found an AEM stage II for 295 delivered on ebay. Also, hear good things about using walmart super tech -20 with a couple of bottles of heet/ walmart brand gasline antifreeze to bring it up to 50/50. Says uctane goes up to about 115 + cooling effects. Can't imagine installing my Vortech without it.
Old Nov 30, 2009 | 04:17 AM
  #239
Ultimate CC
yea if your boosted no reason not to run meth...you will love it
Old Dec 1, 2009 | 01:54 PM
  #240
MethTech's Avatar
MethTech
Riiiissse from youuuuuurrrrr graaaaaaave.......
Seriously though, the -20 is a good fluid to start with, as it is about 1/3rd methanol and cheap. Adding 3bottles of Heet (the 80Z bottles) will actually get you to about 55% methanol or so.
