vortech FAQ: read this before asking vortech questions
Old Dec 28, 2009 | 09:12 AM
  #661
binder's Avatar
binder
Originally Posted by Chef-J
^track a car and hot weather, don't even need to ask question. Just put that on your list. Ok I see about t-trim kit. I don't think vortech list for upgrade blower kit price(like you looking for t-trim vortech kit for 350z or g), I think its like you pay for the kit and pay extra for upgrade to t-trim blower.
yes, the t-trim blower has to be purchased separate.
Old Dec 28, 2009 | 10:33 AM
  #662
maXmood's Avatar
maXmood
Under Boost!
Chef, i'm taking ur advice on heat and cooling....
about the t-trim, now that makes more sense..
i'm so excited about this project and at the same time scared of taking such a step on my only car.. hope things go well and safe.
i will open up a thread when the project starts..
and of course, i'll still come back here to clear any doubts .. you guys rock!
thnx for the input again..
Old Dec 28, 2009 | 01:19 PM
  #663
Chef-J's Avatar
Chef-J
Booooosstt!!
^focus on tune. Just that you have to focus abot, other than that, its pretty simple install. I will shoot pm...
Old Dec 28, 2009 | 01:40 PM
  #664
maXmood's Avatar
maXmood
Under Boost!
tuning would probably be the biggest challenge, as i'll have to drive across the country to do it.
Old Dec 28, 2009 | 02:47 PM
  #665
Z_ology's Avatar
Z_ology
You can actually buy the kit with the t-trim blower. Instead of buying a kit AND another blower
Old Dec 28, 2009 | 03:46 PM
  #666
maXmood's Avatar
maXmood
Under Boost!
that's what the vendor is exactly offering me..
Old Dec 28, 2009 | 04:22 PM
  #667
Chef-J's Avatar
Chef-J
Booooosstt!!
Btw, i don't think vortech ahs V3 t-trim...And i dont know about if they still makes V2 version for T-trim. Can not go thru their website via my phone...
Old Dec 28, 2009 | 04:27 PM
  #668
Chef-J's Avatar
Chef-J
Booooosstt!!
I'm sure it is just samething " upgrade blower ", instead you getting a sci trim, just pay extra for Ttrim.
Old Dec 29, 2009 | 12:29 AM
  #669
maXmood's Avatar
maXmood
Under Boost!
well, that's confusing now..
among those kits offered (by the vendor), the T-Trim is less expensive than the SC-Trim.. *i'd rather keep the prices off*
Vortech Tuner Kit, 2003-2006 350Z/G35 w/ V2 or V3 SQ SC-Trim & Charge Cooler, Satin
Vortech Tuner Kit, 2003-2006 350Z/G35 w/ V2 or V3 SQ T-Trim (no Charge Cooler), Satin (less expensive than the above ^^)
Vortech Tuner Kit, 2003-2006 350Z/G35 w/ V2 or V3 SQ SC-Trim & Charge Cooler, Polished
Vortech Tuner Kit, 2003-2006 350Z/G35 w/ V2 or V3 SQ T-Trim (no Charge Cooler), Polished (less expensive than the above ^^ )
i thought maybe the price is lower on the T-Trim because they're not including the intercooler, but even if you add the price of an intercooler, the price would match the SC-Trim and a little less even...
Old Dec 29, 2009 | 09:55 AM
  #670
Quamen's Avatar
Quamen
The price would be higher. The T-trim is a slightly more expensive blower than the SC-trim. However, I would bet you could buy a different intercooler and the T-trim tuner kit and make your own piping for less.
Old Dec 29, 2009 | 10:31 AM
  #671
Chef-J's Avatar
Chef-J
Booooosstt!!
I just looked over vortech's website. they do not have V3 T-trim for sure. I know they have a V2 T-trim, i don't know why they did not list on their website. But if you can get a T-trim for same price, it is good deal. Also, i asked one of my friend that who had vortech, he said if you want a upgrade T-trim kit, they might not include IC, it's because T-trim is heavy duty. which may require bigger IC for better result. So it make sense to me.
Old Dec 29, 2009 | 02:12 PM
  #672
maXmood's Avatar
maXmood
Under Boost!
^very possible...
i'm finalizing the list now. ..
Old Dec 31, 2009 | 05:06 AM
  #673
scenehouser's Avatar
scenehouser
i have about the same plans as these below with the only difference being i'm in the netherland where we have ron98 fuel.
will the utec still be the be a good choice for me for 400whp?
i think i will be doing all the tuning myself as there are no real 350z experts here..
the pretuned ecu in the normal vortech will not work on ron98 fuel will it?
Originally Posted by TimeAttkZ
My FI plans are finally being put into motion:
HKS true dual exhaust (already have)
UTR resonated test pipes (already have)
Motordyne 5/16th iso-thermal spacer (already have)
Utec
Vortech tuner kit
upgraded 3.12 pully/belt
rc 550 injectors
walboro fuel pump
oil catch can
oil pan spacer and tap (not sure)??
1 step colder snpark plugs
Defi gauges - A/f, boost, oil temp
This set-up should be good for 400whp and pretty reliable for a daily driver yea ??
Maybe slim koyo radiator and JWT clutch and flywheel later on down the road.
Old Dec 31, 2009 | 06:18 AM
  #674
Mr_pharmD's Avatar
Mr_pharmD
Wow, more and more ppl are doing the t trim setup. I can wait to see the final #s.
Old Dec 31, 2009 | 07:39 AM
  #675
Quamen's Avatar
Quamen
While the UTEC is not the best ECU, it will be more than capable of supporting between 400-500whp. I ran it for a year at 414whp on an SC-Trim Vortech.
Old Jan 6, 2010 | 09:11 AM
  #676
maXmood's Avatar
maXmood
Under Boost!
a little update...
i've changed my mind about the T-Trim, going with the SC-Trim
"Vortech Tuner Kit, 2003-2006 350Z/G35 w/ V2 or V3 SQ SC-Trim & Charge Cooler, Satin"
and i'll be getting the 3.12 pulley at first. i just need to get used to the power, and upgrade later if needed..
just waiting for the vendor to get me the shipping charges, and i'll be ready to go..
Old Jan 6, 2010 | 01:59 PM
  #677
Chef-J's Avatar
Chef-J
Booooosstt!!
a little update...
Good choice man, you can simply replace 2.87 and you can replace the blower whenever you ready to build motor in future. Good luck again.
Old Jan 6, 2010 | 08:17 PM
  #678
maXmood's Avatar
maXmood
Under Boost!
^ true that.. thanks!
Old Jan 6, 2010 | 08:33 PM
  #679
binder's Avatar
binder
a little update...
good choice but i'm going to stray you from that 3.12 pulley. Just go to the 2.87 with 440cc injectors and get it over with. It will save you from having to do multiple tunes down the road. I only kept the 3.12 pulley on for about a week. I did a few tuning pulls and got it setup decent and decided it was never going to be enough.
Old Jan 6, 2010 | 11:38 PM
  #680
maXmood's Avatar
maXmood
Under Boost!
i've decided on the 3.12 for 2 reasons:
1- i want to see the basic power i can get with it.
2- dont feel like pushing it from the begining.
and i thought upgrading to 2.87 voids vortech's warranty.
and i'm going with 550cc injectors..
