vortech FAQ: read this before asking vortech questions
Old Apr 25, 2010 | 09:04 PM
  #1081
binder's Avatar
binder
Originally Posted by Forged_G
Sorry about your car binder... at least you can do the work yourself though.
i'm sorry about it too but that's life i guess. i never let anyone touch my car so i figured i could trust a certified tuner.....guess not.
anyways, water under the bridge. It's all buttoned up and ready to go. I get to fire it up tomorrow. hopefully i don't have any oil leaks. i can't deal with re-doing that timing cover again! lol
Old Apr 25, 2010 | 10:55 PM
  #1082
Synjn's Avatar
Synjn
Originally Posted by binder
Originally Posted by Synjn
My rev limiter cuts at 7300. You should be right about the samel.
I bought this car done already. My second Z. So excuse my lack of knowledge. I have uprev engine management controlling my ecu. I think you have the same.
The license obviously has already been paid for. So what else do I need to plug my laptop in to start loggin and learning some things. You use a laptop with osiris interface right?
Also you doing the over or under "revised setup"
tylerfox is selling me an extra cog pulley he had. Now that you say, maybe i had that belt too tight which caused the pulley to seize.
Finally, when you say a 1/4 in slack. A 1/4 in what direction? I'm a little confused
oh, if you're reving to 7300 then your drive pulley is slipping for sure.
i'm using the gtm over the top pulley mod. that's the standard: 1 pulley.
If you have an osiris flash then you need to purchase the cipher cable and the osiris "TUNER" upgrade. Tuner upgrade allows you to modify things yourself with a laptop. You can datalog with just the cipher cable if you want but it doens't record boost pressure and if you're 03-04 it won't record wideband.
when someoen says 1/4" slack or "xx slack" in a belt you grab the belt in the middle of the longest section of belt (on the cog pulley this would be the bottom section that the tensioner is not touching) and you move it up and down. it should move back and forth "1/4").
again, do this when it's hot because it will tighten like crazy after it warms up and 1/4" cold is way too tight.
Should the serpentine belt be "1/4" slack also?
and you are running this setup right?
Good luck on the startup!!!
Old Apr 26, 2010 | 04:56 AM
  #1083
binder's Avatar
binder
lol, i actually haven't tried that method i made up yet. i'm using the original "revised" belt layout from vortech with a standard gtm pulley mod.
for tightness of the serpintine: with belts warm find the longest straight stretch of belt and try to twist the belt upside down. With 2 fingers you should be able to twist the belt 90-180 degrees. I keep mine so i can only twist is 90 degrees. That should be plenty tight.
Then clean off all the belt dust and go drive for a few days and get into boost. Occassionally check to see if you have belt dust. You'll have a little dust, but if you noticed a lot of dust collecting the belt is slipping more than it should.
Old Apr 26, 2010 | 10:47 AM
  #1084
BoomerZ33's Avatar
BoomerZ33
awesome right up. awesome thread so far. i'm definitely considering picking up a vortech kit. don't know which trim yet tho
Old Apr 26, 2010 | 12:57 PM
  #1085
binder's Avatar
binder
my car is running and so far leak free!
Old Apr 26, 2010 | 01:34 PM
  #1086
- bigc -'s Avatar
- bigc -
congrats bro!
Old Apr 27, 2010 | 08:59 AM
  #1087
lil_will's Avatar
lil_will
I got a reply back from Rob at Zcargarage... apparently they are not willing to ship the filter for the BPV.
Is anybody close to Zcargarage that would be willing to pick one up and ship it? I would be willing to compensate you for your time!
Old Apr 27, 2010 | 09:31 AM
  #1088
whitez33350ztt's Avatar
whitez33350ztt
+1 ^ i need that filter as well.. bc its annoying having that whistle at idle.
Old Apr 27, 2010 | 09:32 AM
  #1089
Hexxum001's Avatar
Hexxum001
Believe it or not, you get used to it after a while. I thought it was really loud at first also. Now I don't even notice it at all.
Old Apr 27, 2010 | 09:40 AM
  #1090
binder's Avatar
binder
eh, coolant issue now. i got a mile down the road and it started overheating. I pulled the thermostat and it worked fine when i boiled it but i still don't trust the parts store thermostat. I'm putting my old oem nissan one back in and i ordered a spill free funnel to bleed. I think i had an air pocket keeping the thermostat from opening even though i bled it for over an hour.
this car is killing me
Old Apr 27, 2010 | 12:39 PM
  #1091
4SHIZZIL's Avatar
4SHIZZIL
i have some 440 sitting in a box too if someone wants a set
Old Apr 27, 2010 | 12:45 PM
  #1092
iStan's Avatar
iStan
ZR
Liar.
Old Apr 27, 2010 | 12:57 PM
  #1093
lil_will's Avatar
lil_will
FALSE!
I actually went the opposite way. At first it didn't really bother me but the longer I have been SC'ed the more annoying it gets!
Old Apr 27, 2010 | 01:00 PM
  #1094
Hexxum001's Avatar
Hexxum001
Really? I seriously don't even notice it anymore. Maybe I am just going deaf.
Old Apr 27, 2010 | 01:07 PM
  #1095
Forged_G's Avatar
Forged_G
Have any of you guys tried the filter made by Vortech? Vortech says it drops the sound 3 disciples which is pretty good. I have mine but car is in for heads and high flows today so i dont yet know how effective it is.
Next week after tune i will chime and let u guys know what i think.
Old Apr 27, 2010 | 01:10 PM
  #1096
lil_will's Avatar
lil_will
I just emailed him back. One last ditch effort hopefully enticing him to ship! I will keep you guys updated.
Old Apr 27, 2010 | 01:12 PM
  #1097
iStan's Avatar
iStan
ZR
I'm actually going to try rerouting mine into the intake as a recirc.
Hex- probably doesn't help I have a roadster and it's top down season.
Old Apr 27, 2010 | 01:13 PM
  #1098
lil_will's Avatar
lil_will
I purchased the filter. Have not tried it out yet. The new engine goes in this week so I will have the filter put on then. I will update you guys with my results.
From what I have read I am not as optimistic about the filter from Vortech. But hopefully I will be proven wrong.
Old Apr 27, 2010 | 01:17 PM
  #1099
Hexxum001's Avatar
Hexxum001
That's true Stan. Having a roadster with the top down probably does make it a bit louder.
Old Apr 27, 2010 | 01:19 PM
  #1100
iStan's Avatar
iStan
ZR
I've got a fantastic welder here in Vegas now, so I am going to meet up with him soon to get this all done. Shouldn't be too difficult...
