vortech FAQ: read this before asking vortech questions
Old May 5, 2010 | 05:54 PM
  #1121
Patsfan83's Avatar
Patsfan83
How hard is the install for the vortech SC for a complete noob? Also does it make that high pitched whining noise like other superchargers? Thanks
Old May 5, 2010 | 06:11 PM
  #1122
binder's Avatar
binder
no whine like a stillen. just air bypass noise at low speeds and idle.
how mechanically inclined are you? if you've never worked on cars then it's not going to be easy.
Old May 5, 2010 | 06:24 PM
  #1123
Vas_Z33's Avatar
Vas_Z33
+1
jeff, my best friend alex called me today, told me he found a clutch and tranny for sale!... hook em up
Old May 5, 2010 | 06:48 PM
  #1124
binder's Avatar
binder
Originally Posted by Vas_Z33
+1
yep, i'm hooking him up. about 300$ off a clutch that was only used slightly past break in.
Old May 5, 2010 | 06:52 PM
  #1125
Vas_Z33's Avatar
Vas_Z33
haha yep I heard.. he is excited
Old May 6, 2010 | 05:15 AM
  #1126
Erdem's Avatar
Erdem
I need someone to confirm that I'm going to loose my headlight-washers??
thanks
Old May 6, 2010 | 06:06 AM
  #1127
binder's Avatar
binder
thanks
yep, you'll lose them since our cars dont have them
Old May 6, 2010 | 06:08 AM
  #1128
Erdem's Avatar
Erdem
darn
Old May 6, 2010 | 06:13 AM
  #1129
Erdem's Avatar
Erdem
and thanks BTW
Old May 6, 2010 | 10:58 AM
  #1130
Forged_G's Avatar
Forged_G
Old May 6, 2010 | 11:01 AM
  #1131
the3kgt2's Avatar
the3kgt2
He's from Denmark. All European cars have headlight washers. It's a mandated law.
Old May 6, 2010 | 11:43 AM
  #1132
Erdem's Avatar
Erdem
^^ thanks.. Attachment 286589
it's right under the headlight
Old May 6, 2010 | 12:09 PM
  #1133
Erdem's Avatar
Erdem
Guys... I just got my Vortech on today.. please check this video out and tell me if it sounds normal or not, I thought of compressor surge.. but don't know for sure http://www.bilgalleri.dk/vid_vis.aspx?VideoID=35629
thanks
Old May 6, 2010 | 12:12 PM
  #1134
the3kgt2's Avatar
the3kgt2
No I don't think that's normal at all. How tight are the belts?
Old May 6, 2010 | 12:16 PM
  #1135
Erdem's Avatar
Erdem
my tuner just sent me the vid.. I'll visit him tomorow.
Old May 6, 2010 | 12:21 PM
  #1136
350z006's Avatar
350z006
wow...that sounds awful...like either you bearings/blower is shot and/or your bpv is messed up because that's what the the bpv sounds like when its releasing max boost...
Old May 6, 2010 | 03:35 PM
  #1137
Erdem's Avatar
Erdem
here's the video again.. comon wiseguys..
thanks in advance
Old May 6, 2010 | 03:49 PM
  #1138
- bigc -'s Avatar
- bigc -
- at what RPM is your idle set to? vortechs can sound really bad at the stock idle which is 650 RPM if I remember correctly. try bumping yours to 800+ and see if it sounds the same.
- ask your installer to double check the vacuum line that goes from the BPV to the FMU (or directly to the plenum if you have a tuner kit). my BPV fluttered like that when one of my cats burned a hole in the vacuum line.
Old May 6, 2010 | 07:05 PM
  #1139
binder's Avatar
binder
ya, that high pitch whine isn't normal. mine doesn't whine at all. that sounds like a roots supercharger whine.
like someone said above, to me it sounds like bearings with no oil.
Old May 7, 2010 | 11:59 AM
  #1140
iStan's Avatar
iStan
ZR
Where's sentry been?
