vortech FAQ: read this before asking vortech questions
Old May 20, 2010 | 05:51 AM
  #1221
GT-ER's Avatar
GT-ER
I had a 79" belt with my 3.12" pulley and even that slipped eventually when it stretched. Now I have a 79" + and extra idler pulley to give it more wrap around the pulley.
Old May 20, 2010 | 06:29 AM
  #1222
maXmood's Avatar
maXmood
Under Boost!
hmmmm......
does GTM pulley requires drilling the bracket/plate? because that's gonna be one big headache for me.
Old May 20, 2010 | 07:13 AM
  #1223
GT-ER's Avatar
GT-ER
Originally Posted by maXmood
hmmmm......
Yup, I had to drill mine as well. 10 minute job.
Old May 20, 2010 | 08:24 AM
  #1224
05Z33's Avatar
05Z33
Drilling it is not hard at all really. The bracket is aluminum so its soft enough to do with any drill. Just put blue painters tape on the front, mark your spot, and drill slow and straight. You can thread the hole by hand. takes a few minutes.
Old May 20, 2010 | 08:53 AM
  #1225
maXmood's Avatar
maXmood
Under Boost!
it's gonna be headache for me cuz i'll have to take the bracket off!
the rest is a piece of cake.
Old May 20, 2010 | 09:33 AM
  #1226
- bigc -'s Avatar
- bigc -
^ you can tap the bracket while its on the car.
Originally Posted by nurrishd
Some advice needed
Currently running a 2.87 pulley which makes me 420whp @n 12psi on orisis. The tuner is holding the power back too as my car just wants to keep making power. I am running Str8dum1's old kit which is an SI trim impeller and 600cc injectors with a return to tank fuel system
So having lived with the car for about 1 month in its current state i am looking to get a bigger pulley and reduce the boost to get better fuel consumption and less power to achieve a more reliable car.
Do i keep my belt and get a 3.12 pulley or do i get a new belt and a 3.33 pulley?
I am pretty sure if i dropped to a 3.33 pulley my tuner could still get me 380whp which would be perfect. But if you guys think that's not achievable then maybe i should go for a 3.12 pulley
go with the 3.12 pulley. i just went through this with my tuner.
Old May 20, 2010 | 09:56 AM
  #1227
05Z33's Avatar
05Z33
Did mine with the bracket on as well.
Old May 20, 2010 | 10:02 AM
  #1228
str8dum1's Avatar
str8dum1
i used a 79.5" belt with just my 2.87 and it was perfect, zero belt slip. weird you guys have to use over 1/2" longer belts
Old May 20, 2010 | 10:18 AM
  #1229
Erdem's Avatar
Erdem
Hey str8dum1 what was your setup with the vortech?
Utec as far as I remember? What ems and injectors??
And also how many hp did u have?
Old May 20, 2010 | 10:39 AM
  #1230
maXmood's Avatar
maXmood
Under Boost!
the belt that came with the kit was 80 1/8"... the tensioner at it's max.
so defo i'll need 1" short belt, not longer.
Old May 20, 2010 | 11:04 AM
  #1231
binder's Avatar
binder
i'm wondering tho, why i wasn't supplied with the correct belt when i ordered my kit?
i mean, is it usually an 80 1/8" belt for the 2.87 pulley, and with that you'll have enough threads to tighten it more in if required??
because the kit is stock with a 3.33 pulley, not 2.87. You'll get a belt to fit the STOCK pulley only.
My kit was an older kit that still had the 90"+ belt and i switched to the new vortech kit. I was never supplied with a short belt so i had to purchase one. I purchased the 79.5" belt beacuse everyone told me to and it never fit so i went back and purchased the next size up (80 1/8") and it's worked perfectly since. I have plenty of adjustment left in my tensioner also.
everyone else says they use a 79.5 but i tried to even PRY that belt on and it wasn't going to work. I'm certain it wasn't an error on my part. I can build an engine so a small serpentine belt isn't going to kick my butt. I tried for 2 days since everyone said it "should" fit before i realized there was no way in hell and went to get a new belt.
I have no idea why there would be differences in belt sizes for cars unless a g35 has more tensioner adjustment than a 350z. That would make any sense though because str8 used his kit on a g35 with a 79.5"
  #1232
str8dum1's Avatar
str8dum1
UTEC, 600cc DW injectors, CJM stage 2 FRS. made 460/405 on the dynodynamics @15psi. Pretty far cry from my 898/690 DD at 38psi
Old May 20, 2010 | 11:11 AM
  #1233
Erdem's Avatar
Erdem
can you help me out on this one then??
my tuner told me that the 600cc's are too big for my 350ish hp..
and that he can't controle them under 3k rpm.. either they spray too much or too little..
Binder told me that 600cc's are fine with my setup..
but it would be better for me, to get some advice from you who has tried the same.
thanks
Old May 20, 2010 | 11:36 AM
  #1234
str8dum1's Avatar
str8dum1
There's no reason they cant be controlled under 3000 rpms. My car idled perfectly stoich with the 600s. Now my 1200s idle rich because you start getting very low on injector pulse width and its hard to control. If I had better injectors like injector dynamics, i would have better control.
BUT, thats only at idle. Once the car is moving, injector size is more or less irrelevant with current tuning solutions
Old May 20, 2010 | 11:43 AM
  #1235
Erdem's Avatar
Erdem
Binder told me that I needed to get some info about the 600cc's, from DW's homepage, that I needed to upload to my UTEC..
I just couldn't see any info about the 600cc's in their homepage, and I also don't know wich numbers I'm looking for..
Old May 20, 2010 | 12:10 PM
  #1236
- bigc -'s Avatar
- bigc -
i think ppl are confusing the Gates part number with the actual size of the belt. the vortech kits with the revised belt layout come with a 3.33" pulley and a gates 060795 belt. this belt is 80-1/8" long, not 79.5". the 79.5" long Gates belt is 060790. there's no difference in belt length between Zs & Gs.
Old May 20, 2010 | 12:31 PM
  #1237
str8dum1's Avatar
str8dum1
ahh good to know. i never actually measured the belt. I just went by the common rule each pulley drop is 0.5 inches shorter on the belt.
So i guess if it came with a 795, I was using a 785.
When I had to resize my serp belt for my new setup with idler delete, I just bought like 6 belts and used the one that fit best.
Old May 20, 2010 | 12:35 PM
  #1238
Erdem's Avatar
Erdem
any help on this?
thanks
Old May 20, 2010 | 01:25 PM
  #1239
str8dum1's Avatar
str8dum1
u dont need any info. UTEC doesnt adjust for latency etc....
honestly, your tuner sounds very inexperienced. a supercharged UTEC tune is about as easy as it comes. The only column where you'd actually have to scale the injectors (negative numbers) is in the 0% load column. And even then a -12 or so should give you ~14ish AFR at idle.
If you can get 14ish at idle, you can get it anywhere else
Old May 20, 2010 | 01:42 PM
  #1240
Erdem's Avatar
Erdem
anyways.. I am bored, so let me post a pic
can't wait to ride her lol
EDIT: Faawk it.. I can't figure how to post a pic... lol, nice..
