vortech FAQ: read this before asking vortech questions
Old May 20, 2010 | 02:26 PM
  #1241
binder's Avatar
binder
Originally Posted by str8dum1
u dont need any info. UTEC doesnt adjust for latency etc....
honestly, your tuner sounds very inexperienced. a supercharged UTEC tune is about as easy as it comes. The only column where you'd actually have to scale the injectors (negative numbers) is in the 0% load column. And even then a -12 or so should give you ~14ish AFR at idle.
If you can get 14ish at idle, you can get it anywhere else
there ya go erdem!
lol, like i said i don't know jack about the utec. I assumed since people throw out "the utec will scale up to 600cc injectors" that meant that you had to input the latency values for the injectors and adjust for them. I guess they just use the 0% column like rich said.
Old May 21, 2010 | 03:48 AM
  #1242
Chef-J's Avatar
Chef-J
Booooosstt!!
How he is not sure if it spray too much/too less?
Your best bet is let him email to turboxs about the issue that you having. They will help your issue, just that they taking long time to reply email tho.
Originally Posted by Erdem
and that he can't controle them under 3k rpm.. either they spray too much or too little..
Old May 21, 2010 | 11:37 AM
  #1243
binder's Avatar
binder
i was thinking that also chef. under 3 k should be closed loop so if the trims are going crazy then just adjust the values to get the trims in spec. I'm not sure why that is a hard thing to do....
Old May 23, 2010 | 10:44 PM
  #1244
Synjn's Avatar
Synjn
Ok question fellas: I'm trying to take off my jackshaft pulley because I want to have it sandblasted for a little more belt grip. I was using a 14 mm wrench on the cog pulley side and a 14 mm socket on the jackshaft pulley side. Now these threads are not reversed are they because I couldn't get them to budge. Can anyone offer a little input?
Old May 23, 2010 | 11:02 PM
  #1245
350z006's Avatar
350z006
I used your method too to remove my jackshaft pulley, the clockwise = tighten and anti-clockwise = loosen works as long as the bolt head is facing you...
Old May 23, 2010 | 11:10 PM
  #1246
Synjn's Avatar
Synjn
Originally Posted by - bigc -
i just swapped from a 2.87" pulley to a 3.12" pulley and had to play around with belts. some more data points:
new 79.5" belt works for 2.87 with GTM pulley
used (ie. stretched) 79.5" belt works for 3.12 with GTM pulley (just barely though)
new 80-1/8" to 80-3/8" belts work for 3.12 with GTM pulley
Can I get a link where to buy the: "new 79.5" belt works for 2.87 with GTM pulley"
I am running the revised setup with the GTM pulley.
Binder says 80-1/8"
You say 79.5"
Where should I start?
Old May 24, 2010 | 12:04 AM
  #1247
Synjn's Avatar
Synjn
Guess I need to put a lil more power into it. Bolt is on there tight.
Old May 24, 2010 | 02:39 AM
  #1248
maXmood's Avatar
maXmood
Under Boost!
^about the belt, it really depends..i'm running the 80 1/8" and the tensioner at its max. so i've order Gates 79".others have the same belt and still have enough threads to tighten it.i'm not running GTM pulley tho.
Old May 24, 2010 | 03:09 AM
  #1249
05Z33's Avatar
05Z33
I used a strap wrench on the pulley and 14mm socket. Works great.
Binder says 80-1/8"
You say 79.5"
Part number is K060795. That's what I use with the revised belt setup and GTM pulley.
Old May 24, 2010 | 03:57 AM
  #1250
maXmood's Avatar
maXmood
Under Boost!
Quick one..
is the HPX MAF a direct replacement to stock MAF on a Vortech setup? or do i have to do some modifications?
thanks!
Old May 24, 2010 | 05:38 AM
  #1251
GT-ER's Avatar
GT-ER
Originally Posted by maXmood
Quick one..
thanks!
You have to reprogram your ecu.
Old May 24, 2010 | 07:02 AM
  #1252
maXmood's Avatar
maXmood
Under Boost!
that's gonna be done with Osiris.. what i actually meant is modifications to the pipe/housing.
are you running one?
Old May 24, 2010 | 07:16 AM
  #1253
GT-ER's Avatar
GT-ER
Yeah, I'm running one. It's just an oem maf that was modified by pmass. It fits with no modifications.
Old May 24, 2010 | 08:06 AM
  #1254
maXmood's Avatar
maXmood
Under Boost!
thanks a bunch for the info.
Old May 24, 2010 | 08:30 AM
  #1255
- bigc -'s Avatar
- bigc -
Binder says 80-1/8"
You say 79.5"
i've used both belts and both have worked with the 2.87 & GTM tensioner.
google search for the belts
79.5" belt is K060790
80-1/8" belt is K060795
Old May 24, 2010 | 08:32 AM
  #1256
maXmood's Avatar
maXmood
Under Boost!
Just posting an info for anyone interested.
79.034" belt is K060785
just ordered that.
Old May 24, 2010 | 09:24 AM
  #1257
Synjn's Avatar
Synjn
You mean use the strap wrench on the cog'd pulley and a 14mm socket on the jackshaft pulley bolt right? The jackshaft pulley is the one that i'm getting sand blasted.
I'm going out there to try again. Be right back.
Old May 24, 2010 | 09:33 AM
  #1258
Synjn's Avatar
Synjn
Yup I need a strap wrench. Don't have one here. grrrr.... Tried it my way, with 1 socket and 1 wrench and the cog bolt is the one that came loose. Not the one I wanted.
Old May 24, 2010 | 09:51 AM
  #1259
binder's Avatar
binder
take your cog belt and wrap it tightly around the cog pulley. The teeth will hold it in place.
Hit the jackshaft pulley bolt with an impact. it will break loose. you have to use an impact and not a wrench because it provides a quick snap of torque to break the stiff bolt loose. WIth a wrench you'll appyl the same pressure and it won't have the same effect.
Old May 24, 2010 | 10:49 AM
  #1260
Synjn's Avatar
Synjn
Wrap it as you said, and hold it with my hand?
