tn reflash running quite rich in boost.....
Old Jun 14, 2007 | 07:09 PM
freezeg35's Avatar
freezeg35
Default tn reflash running quite rich in boost.....
Really enjoying the new boost, but was wondering if the rich condition in full boost all the time is harmful. My aem wideband goes flatline rich so its under 11 af, but i dont know if thats 10.9 or much less.
When i get my aftermarket exhaust, will this help lean it out or just give me sooner boost.
Sure wish there was a tuner locally that knew how to tune the utec, maybe a 2 day road trip to cali to see sam in my summer vacation plans.
Thanks again.
Old Jun 14, 2007 | 07:42 PM
IIQuickSilverII's Avatar
IIQuickSilverII
1) check that your connected well you boost gauge
2) if youa re runing 11.0 10.8
thats jsut conservative... its still ok....
Old Jun 14, 2007 | 08:03 PM
freezeg35's Avatar
freezeg35
Boost gauge is fine, 8.5 psi, rock solid.
I dont know if its 10.8, the aem only goes down to 11.
What about aftermarket exhaust, will this help?
Old Jun 14, 2007 | 08:06 PM
IIQuickSilverII
lol...might lean it a lil... psi might go close to 9
when you dont boost...what doesr your A:F read?
Old Jun 14, 2007 | 08:55 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes an aftermarket exhaust might help a bit. I would double check the fuel pressure to though. Just make sure you aren't running to rich because the fuel pressure is too high.
Old Jun 14, 2007 | 08:57 PM
Mike@IOS's Avatar
Mike@IOS
IOS Performance
The LED only goes to 11 but the digital read out goes to 10.0 I believe.
Old Jun 14, 2007 | 09:32 PM
freezeg35's Avatar
freezeg35
Hmmm, thanks ill check that,..........That would mean im less than 10.
Old Jun 14, 2007 | 09:45 PM
GTM's Avatar
GTM
Vendor - Former Vendor
If you have the means I would swap out to a Innovate LC-1 XD-16 combo since it is more accurate and gives you the ability to calibrate from in the car.
Also if it is in the mid to high 10's during WOT only it won't hurt anything.
HTH,
-George
GT Motorsports
Old Jun 14, 2007 | 10:02 PM
freezeg35's Avatar
freezeg35
HTH,
-George
GT Motorsports
My concern is it may be mid to high 9s if the wideband doesnt flatline till less than 10.
Im pretty sure thats the case too.
What would cause an increase in fuel pressure?
Thanks.
Old Jun 15, 2007 | 04:12 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
usually when people install their own kits with the reflash and it is running rich, there is usually an exhaust leak going to the turbo or a boost leak in the piping somewhere...
Old Jun 15, 2007 | 06:36 AM
MIAPLAYA's Avatar
MIAPLAYA
Thanks.
So the digital readout goes to ---- also?
Old Jun 15, 2007 | 07:14 AM
freezeg35's Avatar
freezeg35
I had it put in by a turbonetics retailer.
http://www.kineticmotorsport.com/
I dont hear any exhaust leaks, that car is so damn quiet now.
If it was a boost leak, would i still get 8.5lbs all the time?
Thanks.
freezeg35's Avatar
freezeg35
Yup.
Old Jun 15, 2007 | 08:22 AM
MIAPLAYA's Avatar
MIAPLAYA
Yup.
Interesting. In that case I would definitely verify you have the correct fuel pressure. This same thing was happening to Peking WAY back in the day. He had his kit installed by a retailer too but they failed to alter the stock fuel pressure regulator as outlined in the instructions when they installed the Walbro 255 lph. As a result his base fuel pressure was something like 73 PSI at idle. That is WAYYYYYYYY to high and caused his car to also run off the scale rich. Once this was corrected the car immediately made more power and his AFR went to normal.
Old Jun 15, 2007 | 01:17 PM
freezeg35's Avatar
freezeg35
Update, i drove the car for a couple of hours today and would go wot, feather the throttle in boost etc all in order to see if the digital readout would go into the 10's, which it didnt.
The lowest i would see in the digital readout was 11.1, so maybe the aem only leds and digital readouts to 11.0 afterall.
Mia, with 73 psi at idle, was his car running really rich idling as well or only in boost.
When im at idle its 14-16ish jumping around, just like when i had the vortech on.
Old Jun 15, 2007 | 03:07 PM
MIAPLAYA's Avatar
MIAPLAYA
Oh his car was WAY rich at idle too. Based on your last update it doesn't sound like you have an issue. I was going under the assumption that the AEM gauge lower threshold was 10.0. I think the new AEM gauge does that. The older ones I think you are correct stop at 11:1. Honestly to be 100% put the car on a dyno and check the AFR with their sniffer.
Old Jun 15, 2007 | 03:38 PM
freezeg35's Avatar
freezeg35
Funny you should suggest that, i just went by the shop that did the install and they have a wideband dyno. 100.00 for 3 pulls.
Should i worry about the rich conditon and not enjoy the power till I get a dyno run? What is the lowest documented a/f on the reflash been?
If anyone can recommend a tuner in the pacifc northwest preferably, that can dyno tune the utec like sam at GT does, please chime in.
P.S: ordered the apexi ws2 today will get it in 2 weeks, then dyno.
Thanks.
Old Jun 15, 2007 | 03:44 PM
freezeg35's Avatar
freezeg35
How had is it to hear exhaust leaks, everything is well heatwrapped.
Thanks.
Old Jun 16, 2007 | 09:16 AM
MIAPLAYA's Avatar
MIAPLAYA
I think you are fine dude. Being a little rich isn't that big of a deal. Conservative yes but on a stock motor thats not always a bad thing.
Old Jun 16, 2007 | 12:09 PM
IIQuickSilverII
+100000000000
apex locator
Jul 23, 2021 02:27 AM
