Kinetix V+ and Turbo Install Issue
Old Jun 23, 2007 | 06:39 PM
nosurf2day's Avatar
nosurf2day
Default Kinetix V+ and Turbo Install Issue
I am installing my Kinetix V+ along with my Turbonetics Kit. On the stock plenumn there is a nipple that you can use in the front of the plenumn for your boost gauge. With the Kinetix V+ there isnt one.
Has anyone installed a Turbo Kit with this plenumn and where did you hook up your boost line?
Not sure what I should do?
Old Jun 23, 2007 | 06:45 PM
Jtrain's Avatar
Jtrain
You just gotta tap it.-- I have one for boost, one for bov etc etc
Old Jun 23, 2007 | 06:59 PM
05zissan's Avatar
05zissan
how much are you selling your kinetix for?
Old Jun 23, 2007 | 07:12 PM
nosurf2day's Avatar
nosurf2day
I am not selling my plenumn.
Taping it? it won't damage it at all?
Old Jun 23, 2007 | 07:24 PM
VIZAGE's Avatar
VIZAGE
NO, not at all. Just have to do it right. Tap a hole, thread it, and put a port in it with thread sealant tape.
Old Jun 23, 2007 | 07:53 PM
nosurf2day's Avatar
nosurf2day
Lightbulb
Where did you tap yours? next to the side nipple or in front like the stock one.
Old Jun 23, 2007 | 09:53 PM
TENGAI's Avatar
TENGAI
Check this out if you don't want to tap the plenum:
http://www.alteredatmosphere.com/mm5...de=350Z_INTAKE
Good luck...
Old Jun 24, 2007 | 05:09 AM
QuadCam's Avatar
QuadCam
you'll probably want to use either a 1/8" NPT or 3/8" NPT tap. You'll need need the appropriate sized drill bit.
check with a good hardware store on where to get the drill, tap, and tap handle.
Old Jun 24, 2007 | 05:54 AM
nosurf2day's Avatar
nosurf2day
Damn, this is exactly what I need!
Old Jun 24, 2007 | 08:09 AM
Zivman's Avatar
Zivman
I wouldn't trust that plastic POS under boost. A local to me called me up.... hey, I am not making boost, can you look at my car? Sure enough, that POS crapnetix plenum was warping and was not sealing properly on the gasket -> and this was the V+ on an APS single turbo running about 9-9.5 psi. Do yourself a favor and put the stocker back in and sell the V+ to some sucker that doesn't know any better
Old Jun 24, 2007 | 10:36 AM
VIZAGE's Avatar
VIZAGE
I didn't have to tap one. I have the Crawford intake. I just know what has to be done. You just need the proper size bits to do, like QuadCam said. Look to do it in the left side of the intake, like all the others.
Old Jun 25, 2007 | 03:12 AM
nosurf2day's Avatar
nosurf2day
I did it yesterday, got a 3/8 thread nipple a 22/34 bit and a 3/8 tap. Drilled into the left side (drivers side) of the plenumn tapped it and threaded in the nipple, it looks just as good as the nipple that came with it installed. Thanks guys!
Old Jun 25, 2007 | 09:27 AM
Triple8Sol's Avatar
Triple8Sol
So the Crawford plenums don't have this problem then? They already have the port/nozzle?
Old Jun 25, 2007 | 10:35 AM
Zivman's Avatar
Zivman
No, they don't have that issue, nor are they made from plastic that warps and cracks
Old Jun 26, 2007 | 05:42 AM
nosurf2day's Avatar
nosurf2day
I havent had a problem with my kinetix v4 plenum. I had that for about 9 months, of course it wasnt under boost but it treated me great, best part was 0 heat soak. I could drive all day and put my hand right on the plenumn. Now that is sweet, less heat more HP.
I havent had a chance to run the V+ yet. Feelings to be determined.
Old Jun 26, 2007 | 08:51 AM
Triple8Sol's Avatar
Triple8Sol
Boost changes the equation dramatically, so I can see how that would stress/warp the plastic. One of the reasons I didn't get a spacer for my upcoming Vortech install.
Old Nov 11, 2007 | 08:49 AM
jaspendlove's Avatar
jaspendlove
This is a good thread. Just what I was looking for.
Old Nov 12, 2007 | 01:17 AM
Jay'Z's Avatar
Jay'Z
I have been running 14-16psi daily.. No warps in my V+ ........
Sponge
Jul 18, 2004 06:51 PM
jreiter
Jul 3, 2004 02:10 PM
Static
Jun 10, 2004 05:21 PM
350Z 2+2 ???
Apr 4, 2004 09:23 AM
FLY BY Z
Mar 1, 2004 02:16 PM
