Official STS Rear Mount Turbo Discussion Thread
Old May 18, 2009 | 07:04 AM
  #1961
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by Boozt
Yep....5k for the Hinson stuff plus motor and trans.
How much should I ask for my STS?
I meant that much for the kit.
Old May 18, 2009 | 07:55 AM
  #1962
Boozt's Avatar
Boozt
Wow...Really. I was thinking of putting it up 3 to 4K....I wasn't sure.
Know anybody looking for the STS right now?
Old May 18, 2009 | 09:41 AM
  #1963
DudeMan's Avatar
DudeMan
im actually doing an lq4/9 build on my g soon and going with an 88mm turbo... i heard bad things about the hinson stuff not fitting correctly so i talked to a local shop that specialize in ls motors and they want to do the build really bad... just waiting on some more cash
Old May 18, 2009 | 10:07 AM
  #1964
Ahsmo's Avatar
Ahsmo
Imakecopies
Put it in the classifieds. I would have the turbo checked out to make sure no bits of engine made it to the turbo.
Old May 18, 2009 | 10:09 AM
  #1965
Ahsmo's Avatar
Ahsmo
Imakecopies
The mechanics of the sway are relatively easy but the electrical is the rub. Did they comment on that?
Old May 18, 2009 | 12:02 PM
  #1966
DudeMan's Avatar
DudeMan
im going to meet with them in a week or so and discus everything... theyre not doing the build im doing it myself except for the custom fab work
Old May 20, 2009 | 12:04 AM
  #1967
DudeMan's Avatar
DudeMan
just out of curiosity do people with osiris spool up quicker? since you can have the tb open to 100% instantly? more air quicker should mean faster spool up right?
Old May 20, 2009 | 08:06 AM
  #1968
Ahsmo's Avatar
Ahsmo
Imakecopies
Spool is related to mass flow and energy. When you go WOT at lower RPM the difference that will make should be marginal.
Mass flow is related to engine RPM and engine load.
Old May 20, 2009 | 08:07 AM
  #1969
goosegoose's Avatar
goosegoose
On that note, are any of us running on Osiris?
Old May 20, 2009 | 10:43 AM
  #1970
DudeMan's Avatar
DudeMan
yea but having wot sooner will increase cfms at lower rpms
more air flow means more fuel which means more exhaust gas which will increase spool
Old May 20, 2009 | 05:53 PM
  #1971
JonnyC's Avatar
JonnyC
Boozt - I'm sorry to hear about that. Sounds like it was probably a tuning issue ?? I would be worried if it was any other issue since it seems like everything else was in check.
Old May 21, 2009 | 04:16 AM
  #1972
Boozt's Avatar
Boozt
The tune was pretty good.....IMO WOT on a big track for 20 to 30 mins straight is what did it in. Car has 73k on it and numerous days at the track. I will be selling the full STS kit soon as I am going forward with my LS2 build.
Old May 24, 2009 | 10:38 AM
  #1973
skn5002's Avatar
skn5002
Default Is the turbo lag really this bad?
Finally finished installing the kit. All the exhaust pipes are wrapped, testpipes were added as well as a magnaflow muffler, and a new clutch/lighter flywheel. I am not scheduled for a tune until next week but I wanted to make sure everything was at least working right and could hold boost. The car started up fine, but after it warmed up the idle became very choppy almost stalling. When taking a cruise, the car would stall when I would put it into neutral. A bit scary. I still need to do an idle air relearn and then I'll have my tuner bump up the idle, which will hopefully solve this issue.
The car had trouble building any type of boost in 1st and 2nd gear. I was afraid to boost it in any of the higher gears and kept rpms under 5k. The car was idled for 10 minutes and driven around the block to warm everything up. I then gave it half throttle around 3200 rpm and let off at around 4500-5000 rpm in 2nd gear and was unable to build any boost. I could hear very faintly the turbo trying to spool and when I let off, there was a very faint chirp from the bov. The sounds were very faint and almost barely audible. I did this a few more times with the same results: no boost. Boost gauge slowly crept to slightly under 0 vacuum. So then I tried going full throttle starting at the same rpm and letting off at the same rpms in 2nd gear as well. Once again, turbo spool sounded very weak and faint. I did get a very slow build to 1 psi before I let off at 5k rpms. The psi build was slow. I'm not sure if it would have continued to build more boost if I had kept the rpms going. The bov sound was a bit more audible and cleaner sounding this time.
So is this normal? It feels like the motor is unable to build boost. I have an Hallman mbc installed but it is closed shut... so I should be getting 4.5 psi off the wastegate. I've read that you guys that are tuned for 8 psi only get around 5 psi or so in 1st and 2nd gears... so I assume that getting only 1-2psi is normal when running off of the wastegate? I expected the turbo spool and bov sounds would be more audible though. I do not suspect I have any leaks, as I was very meticulous with all the work (took me over 2 weeks to install). All exhaust gaskets are brand new and I even applied a thin layer of copper gasket to them. In any case, I will be doing a boost leak test to make sure. I do not think I'll push the motor anymore until I get it tuned, but I hope my time at the dyno will not be spent trying to figure out why the car can't build boost.
Old May 24, 2009 | 10:45 AM
  #1974
DudeMan's Avatar
DudeMan
thats normal to not build boost in 1st and not much in second because youre running wastegate pressure... get an ebc i hit 8psi in 1st gear
Old May 24, 2009 | 01:17 PM
  #1975
skn5002's Avatar
skn5002
I was hoping a good mbc would solve the lag issues, but I had no idea the lag would be this bad. I guess I'll have to bite the bullet and get the ebc. Might as well do it now so I don't have to retune in the future. Besides the solid boost in 1st and 2nd, does the ebc help the spool up times much?
Old May 24, 2009 | 01:44 PM
  #1976
DudeMan's Avatar
DudeMan
yes because with an ebc you can connect to the top port on the wg and it will put air in there and helps keep closed a little longer... thats waste gate duty cycle.. what kind of boost are you trying to run? you can get a bigger wastegate spring which will also help spool
Old May 24, 2009 | 02:38 PM
  #1977
skn5002's Avatar
skn5002
Alright looks like I'll be ordering the HKS evc VI tonight and selling my mbc on ebay...lol. I don't plan on boosting anymore than 8.5 psi. I'd be happy to put down 380 whp after the tune, which I think is achievable with the testpipes and spacer. So if I am tuned for 8.5 psi and want to turn the boost down during daily driving to 6 psi, will I have to get it tuned for the lower boost also?
Old May 25, 2009 | 04:40 PM
  #1978
athenG's Avatar
athenG
boozt, sorry to hear about what happened. I havent been online because of work so I missed a month of drama here. You are probably the one that really drive his car to its potential on this thread. I know you have lots of track miles on that car. Economy is a little tough so good luck.
update...
After fixing my vacuum leak about a month ago, my car felt like new again and no CEL for about a month now and idle and AF has been stable again.
Old May 25, 2009 | 05:09 PM
  #1979
Boozt's Avatar
Boozt
update...
Thanks...I feel like a traitor looking to swap for a 2JZ or LS2 (2JZ is looking better at this point) but it's a matter of budget vs HP and trackable gains. I can stay within my budget and get 500 to 600 HP out of the 2JZ swap and run the hell out of it without significant worries. If I blow the 2JZ motor...I can get a full motor that will handle big HP for $1700.00...they are plentiful. I have high praise for the STS kit....it never failed me...the stock block did. I have big $$$$$ into this car so it makes no sense to dump it....and will prob be a full time track car in 2 years.
Old May 25, 2009 | 05:35 PM
  #1980
athenG's Avatar
athenG
It is your money so you can do what ever you want. I think goosegoose and me are the last two guys from the first batch tester and I pretty much know the limit and what the STS can do. Goosegoose went through all the pain trying to get max HP with this kit and his built motor. STS is good for stock block but for high HP application then a front-mount is much effecient. Down the road when I have the $$$$ for my build, I will ditch the STS and go with a Twin. Good luck.
