How often do Walbro pumps go bad?
Old Aug 18, 2007 | 08:10 AM
moog's Avatar
moog
Default How often do Walbro pumps go bad?
Just installed mine last night and everything works fine. Just wanted a heads up on failure rate of them. Might pick up a spare if I need to.
Old Aug 18, 2007 | 08:13 AM
westpak's Avatar
westpak
SFZCC
3 years 30k miles and still going
Old Aug 18, 2007 | 10:04 AM
Jason333's Avatar
Jason333
hi
I had a bad one shipped to me in my old kit.
Old Aug 18, 2007 | 10:14 AM
moog's Avatar
moog
So yours was bad right out of the box?
Old Aug 18, 2007 | 12:43 PM
Q45tech's Avatar
Q45tech
Read the current [amperes] and the revolution [rpm with your dc amplified amprobe and digital scope] of the pump brand new as they age the speed [rpm] drops and the amperes increase.
Existing wire sizes and lengths may create excessive voltage drop to pump terminals thus rpm and pressure change with at pump voltage.
Always good to make suck brand new measurements [idle cruise and high rpm load] for future diagnosis.
Old Aug 18, 2007 | 12:48 PM
failsafe306's Avatar
failsafe306
Your posts are always WAY over my head, but I'm sure someone on here understands it all
Old Aug 18, 2007 | 01:01 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
20K on mine! No probs
Old Aug 18, 2007 | 02:15 PM
TegraRacer134's Avatar
TegraRacer134
I had 50 miles on mine and I blew the springs out of the top in rush hour traffic. The shop put it back togather and melted plastic on top of the pump where the springs are located and havent had any problems since. 6k miles later
Old Aug 18, 2007 | 03:44 PM
go-fast's Avatar
go-fast
there is no rule for failure,but one grain of sand can seize a close tolerance pump.
Old Aug 18, 2007 | 04:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We've seen about 2-3 bad ones, out of a couple hundred...its pretty rare, IMHO.
Old Aug 19, 2007 | 04:14 AM
silver nismo's Avatar
silver nismo
I had 1 bad out of the box.. with them u can never know... it could last for 3 years and it could last 3 days I installed a fule presure gage because of this..
Old Aug 20, 2007 | 07:24 AM
Q45tech's Avatar
Q45tech
How can such simple engineering of how an electric fuel pump works be over anyone's head? An electric pump has been standard for 20+ years not like it's new technology.
Since low fuel pressure is a significant cause of lean operation and engine stress and failure, might be wise to study up on common failures and test proceedures.
On Q45 since 1989 fuel pump failure has been the NUMBER 1 cause of a Q/J/M get flat bedding back to shop. I suspect G/Z will carry on that tradition in the future. All of this preventable if owners had bothered to do periodic testing and replacement.
Old Aug 20, 2007 | 07:31 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Biggest cause of failure is running the pumps dry. That will burn the plastic housing inside the pump pretty quickly.
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
