GTM tension pulley install DIY...
Old Feb 18, 2008 | 05:40 PM
  #101
clifftrail's Avatar
clifftrail
Don't go to Rio very much, have been to that site a couple of times but not very much, maybe some day we'll cross paths, I think I'm the only 03 DG coupe in town with blacked out tails and ride on Axis Hiro's. Anyway, GL with you Vortech or TT. Later.
Don
Old Feb 18, 2008 | 05:48 PM
  #102
booger's Avatar
booger
Thanks Guys !!!!!!
Old Apr 25, 2008 | 02:30 PM
  #103
teh215's Avatar
teh215
Any more long term reports on this pulley? I am thinking of picking one up.
TIA
Rob
Old Apr 25, 2008 | 05:22 PM
  #104
05Z33's Avatar
05Z33
I have the pulley just haven't installed it yet. I have the revised belt layout from vortech which uses a 79.5 inch belt, and my GTM pulley kit came with a much larger belt, like 93 or 95 inches. I will have to test fit a couple of different belts to find out which one will work best.
Old Apr 26, 2008 | 02:53 PM
  #105
teh215's Avatar
teh215
ttt
Old Apr 28, 2008 | 06:21 AM
  #106
jpc350z's Avatar
jpc350z
TIA
Rob
Pick one up , you won't be disappointed..
Old Apr 28, 2008 | 10:01 PM
  #107
Triji's Avatar
Triji
since install... No slippage, no noise... It was a great investment.
the only thing that bugs me is the rust that likes to build up on the pulley... Need to keep a thin layer of oil on it.
Old Apr 29, 2008 | 09:50 PM
  #108
imalazeeass's Avatar
imalazeeass
just to follow up on my pulley installed by GTM.. so far im getting a little squeaking sound during startup when its really cold outside. My belt is already so tight i can probably play music off of it by flicking it. Other than that no other issues really.
Old Oct 20, 2009 | 03:33 PM
  #109
- bigc -'s Avatar
- bigc -
Quick question: Is the GTM pulley mod required with the revised, non-revup belt layout (79.5" belt) and 2.87 pulley? I don't want to add another pulley to the bracket if the 2.87" pulley won't slip with the revised belt layout.
Old Dec 13, 2009 | 04:00 AM
  #110
binder's Avatar
binder
it will slip. Without the GTM pulley i could sometimes make 11psi if i tightened the belt super tight. With it normal tension it would slip at 10psi.
With the gtm pulley it makes constant boost on my logs all the way to redline. 12psi. I also don't have to tighten the belt near as tight with it.
*those numbers are of no significance for the average vortech setup. I have a built motor with ported heads and cams so my boost pressure could be different. Basically with my setup the belt was slipping enough to lose 2 psi before the gtm pulley mod.
Old Dec 13, 2009 | 09:38 AM
  #111
- bigc -'s Avatar
- bigc -
i installed the gtm pulley and haven't had any belt slip isues
Old Dec 9, 2010 | 10:27 PM
  #112
RetchedOne's Avatar
RetchedOne
Updates on peoples with the GTM pulley?
Old Dec 10, 2010 | 06:32 AM
  #113
str8dum1's Avatar
str8dum1
never slipped using the stock belt config at 17psi.
Old Dec 10, 2010 | 09:10 AM
  #114
jpc350's Avatar
jpc350
Recommend it...Careful with the drilling for the pulley...
Old Jan 15, 2011 | 04:11 PM
  #115
kajuraelai's Avatar
kajuraelai
Did you guys have any rubbing of the serpantine belt on the timing chain cover?
Old Jan 15, 2011 | 06:28 PM
  #116
- bigc -'s Avatar
- bigc -
you have to machine down the cam cover just a tiny bit so the belt doesn't rub against it. use a file if you don't want to deal with pulling the cam cover off.
Old Jan 13, 2014 | 09:49 AM
  #117
Conway_160's Avatar
Conway_160
Bumping a old thread to see if the mod is still needed to help with high boost 15+psi. Also what is preferred adding one pulleys or two pulleys.
Old Jan 30, 2014 | 03:40 PM
  #118
syler0690's Avatar
syler0690
Default Pullys!
Hey peeps, im new at this stuff and was wondering how many of you have performance pulleys and what brand you would recommend? Would love your help
Old Jan 30, 2014 | 04:18 PM
  #119
OldManZ350's Avatar
OldManZ350
What do you mean by "performance pulleys" ?
Old Mar 20, 2014 | 06:40 AM
  #120
Drock's Avatar
Drock
hi there..
ive been running my Vortech V2 setup for 2 summers.. with no issues more or less.
420whp/350wtq on Dynapack Dyno tuned with Uprev.. using 3.12 pulley.. with revised belt setup, according to the Diagram on the GTM website for the Pulley Mod..
the Pulley Mod is something ive had in mind, since installing the SC, but never got around to doing it. most of the time I am reaching the correct boost with the 3.12. but here and there, if pushing hard in 1st/2nd, im pretty sure the belt slips sometimes.
so this spring, I may finally get around to getting the pulley mod. for that final touch.
1st question: should the car be retuned after installing the pulley mod?
2nd question: in this thread I read some people posting, that there is a way, to correct belt slip without the pulley mod, by putting a pulley in one of the existing holes on the bracket? not sure what this is, is this the Timrod belt setup, or something different..?
thanks..
Fixxxercask
Nov 9, 2015 11:10 AM
