*LOW boost Greddy TT 1/4 TIMES!*
Old Sep 30, 2007 | 05:27 PM
  #101
Jtrain's Avatar
Jtrain
if your loosing control and letting of, shouldn't you turn down the boost a pound or two?
Old Sep 30, 2007 | 06:10 PM
  #102
Alberto's Avatar
Alberto
Cranky FI Owner
No, I shouldnt turn it up right now, which is what Im doing. Cant run lower than WG pressure anyway. Figuring out your issues is a much better way IMO to handle this than turning down boost and hiding them. Next step is stock wheels up front. Step after is new alignment and measuring of wheelbase....
Old Sep 30, 2007 | 06:18 PM
  #103
tig488's Avatar
tig488
unless you keep spending money to fix the problem, only to never find out how to fix it.
Old Sep 30, 2007 | 06:29 PM
  #104
Alberto's Avatar
Alberto
Cranky FI Owner
You guys give up on things so easily? How hard is it to put on stock (no cost) wheels? Take a few measurements and realign ($100 max to most-I have a hookup) the rear of your car? Measure roll out after heating up slicks? (again no cost), etc, get real tig
Old Sep 30, 2007 | 06:47 PM
  #105
Julian@MRC's Avatar
Julian@MRC
Berto,
Your issue is the biased ply in the rear with low PSI and the WIDE RADIAL tire in the front.I experienced the same thing as you on the ET Streets, which is why I now run a Drag Radial instead. You said it yourself, the traction difference is minimal if we both can pull a 1.6 60 on both tires.
Old Sep 30, 2007 | 06:53 PM
  #106
Alberto's Avatar
Alberto
Cranky FI Owner
Thats what I feel is the main issue. That is why I'll be running the stock 8" wide front not the 9.5" fronts I run now...
Old Sep 30, 2007 | 07:02 PM
  #107
Julian@MRC's Avatar
Julian@MRC
That will make a minimal difference. You WILL have to run a biased ply front runner in the front,trust me.. Or switch to a Drag Radial tire.
Old Sep 30, 2007 | 07:09 PM
  #108
Alberto's Avatar
Alberto
Cranky FI Owner
Im hard headed and in a sick way enjoy those runs 1" from the cones, I'll give it another shot on the radial/bias ply set-up. Other people have also commented that my car is not square (with exact same WOT/sway left symptoms) and like I posted above I have a plan for that. Skinnies/bias ply needed in front for 10's? Nah Time will prove one of us right...
Old Sep 30, 2007 | 07:11 PM
  #109
Julian@MRC's Avatar
Julian@MRC
No, Skinnies and biased ply to keep from hitting the wall or another car..
Old Sep 30, 2007 | 07:19 PM
  #110
Alberto's Avatar
Alberto
Cranky FI Owner
We shall see, I just wanted to hit my goals with minimal changes you know...
Old Sep 30, 2007 | 07:40 PM
  #111
Julian@MRC's Avatar
Julian@MRC
So go to a Micky Thomson DR, you said it yourself, i pulled a 1.60 on them a few times..With ZERO sway.. 275/50/15
Old Sep 30, 2007 | 07:46 PM
  #112
Alberto's Avatar
Alberto
Cranky FI Owner
I cant run 15" wheels with my Brembo's.
I am not buying another set of wheels/tires. No good 16" DR sizes (255 isnt gonna cut it)
No offense but Im taking advice from the guy who set up and cured the WOT=left pull, decel=right sway on boulderz's 10 sec car. I believe it can be done without skinnies, so do they and so does a MT rep on the phone. Instead of blanketing the issue not seen/experienced on a radial/radial set-up I'll find it, fix it and get it done
Old Sep 30, 2007 | 07:50 PM
  #113
Julian@MRC's Avatar
Julian@MRC
We were running the ET streets n Jasons car a while back..He had no real issues, and he had only an Eibach spring set and a cmber adjustment kit, Zero camber..He also had the Nismo rear at 80% lock up..All of those may have helped. I myself experienced the sway, but not as bad as you did, i almost shat myself watching your video, your 100% more crazy than me.. I aint making my wife a rich widow..
Old Sep 30, 2007 | 07:52 PM
  #114
diwun67's Avatar
diwun67
For what it's worth I nailed a 1.56 60ft on 295/35/18 BFG drag radials
Old Sep 30, 2007 | 07:56 PM
  #115
Julian@MRC's Avatar
Julian@MRC
Yeah but the tracks in Florida are down hill
  #116
Alberto's Avatar
Alberto
Cranky FI Owner
Im not married You bring up yet another point, the stock VLSD is slow to react and can cause the pull as it applies power. A fully locked, or faster reacting LSD can also help keep the car straighter. It was on my list of things to do before the build even, just havent gotten around to it...
Old Sep 30, 2007 | 08:03 PM
  #117
diwun67's Avatar
diwun67
Don't be jealous of our sea level DA's and flat, non-mountainous landscapes!
  #118
Julian@MRC's Avatar
Julian@MRC
I think the LSD is the issue, Jason always cut some sick 60fts...He was going 11.4's all day and night on a stock motor
Old Sep 30, 2007 | 08:04 PM
  #119
Julian@MRC's Avatar
Julian@MRC
Actually, It more the weather Im jealous of. Our nearest track is at sealevel, acutally below a bit,in a valley.
Old Sep 30, 2007 | 08:05 PM
  #120
Alberto's Avatar
Alberto
Cranky FI Owner
What LSD did Jason run?
