APS Oil Pan Plug Thread Stripped!
Old May 26, 2011 | 02:23 PM
  #81
graffkid732's Avatar
graffkid732
Originally Posted by OMERTAITALIA
this garbage just happened to my aps now im gonna go with this fumoto drain 16mm x 1.5, ordered
I have this as well, waiting to lower the car to make sure I am 100% clear
Originally Posted by G35cTT
That sucks, the design of the drain plug area really blows I wonder if everyone who's running these stripped it out?
So far so good for me. Only a hand full of oil changes. Have to be very easy with it. I think some people forget that Aluminum is soft, especially when hot.
Old May 26, 2011 | 02:54 PM
  #82
Cass007's Avatar
Cass007
I got the Fumoto for my setup after reading this thread way back. Mine has some hard scars on it from hitting a few things, but it has help up like a champ and still works fine.
It will go to whomever buys my APS TT setup, yet another added value
Old Jun 5, 2011 | 03:19 PM
  #83
OMERTAITALIA's Avatar
OMERTAITALIA
just popped off the oil pan today, did you use loctite thread sealer on the oil drain tubes?/ nevermind i read the instructions wrong, should be installed with the fumoto this week.
Old Jun 5, 2011 | 04:25 PM
  #84
Dan Garcia's Avatar
Dan Garcia
Default oil change
just waiting for my next oil change
Attached Thumbnails APS Oil Pan Plug Thread Stripped!-f103n-2.jpg   APS Oil Pan Plug Thread Stripped!-imagemagic.jpg
Old Jun 6, 2011 | 09:14 PM
  #85
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Done probably 10 oil changes on mine in the past 6 years and haven't stripped it out. I have no problem with the drain setup, it's doesn't need to be torqued to all hell.
Old Jun 9, 2011 | 08:40 AM
  #86
OMERTAITALIA
couldnt get my oil drain plug out for the life of me just kept spinning free, so i just dropped off my pan and fumoto at the local machine shop yesterday,cant wait to get it back and try her out
Old Jun 11, 2011 | 09:09 PM
  #87
OMERTAITALIA
got it all mounted up and done, i thought my fumoto was broken from the factory but after really really torquing that switch it finaly opened and now it opens easily.
I HAVE A 16MMX1.5 THREADER 10$ SHIPPED LET ME KNOW BY PM HAD TO ORDER ONLINE SINCE OREILLY DIDNT HAVE ONE
Old Jun 4, 2013 | 06:53 AM
  #88
aa2033's Avatar
aa2033
I know I'm bumping an old thread, but I'm trying to find what size to use for a greddy oil pan. Mine is stripped as well. Would I be okay with a 16mm x 1.5 fumoto drain valve like you guys with the aps kit?
Old Jun 4, 2013 | 08:47 AM
  #89
suprasam's Avatar
suprasam
you can if you want but you shouldn't have to go that large.The greddy oil pan thread is 12x1.5. I've been using an oversized 12x1.5 piggyback plug for a while after an oil change shop stripped my drain hole. I have a 14x1.25 fumoto waiting to go on when I freshen up my block.
If you want to go that large because you have it then I wouldn't seen an issue.
350z82
Oct 1, 2015 06:25 PM
