Si TRIM VORTECH.
Old Feb 18, 2008 | 02:41 PM
  #461
str8dum1's Avatar
str8dum1
ya at some point you need to step back and think about whats goin on. its really hard to rationalize modding when for the same price you coulda got a nicer car to begin with.
although having to wait week in and out for stuff to get finished is frustrating!
hope it all gets together soon.
Old Feb 18, 2008 | 03:14 PM
  #462
Hexxum001's Avatar
Hexxum001
I understand being frustrated but just deciding to go T/TT doesn't mean that you aren't gonna run into a whole other set of issues. That's just FI fellas. You gotta take the good with the bad. In the end, I hope it all works out Jet Mech. I'm sure Sam will figure something out and you will be happy.
Old Feb 18, 2008 | 05:51 PM
  #463
warmmilk's Avatar
warmmilk
Originally Posted by JET MECH
just what i need to do at this point drop another $20,000 on a built engine and TT kit. NOT!!!!!!!!!!!!!! might as well drop a LS2 and magna charger in it and call it done. could be worse, i could be making payments on the z. thank god i bought it for cash and all the mod's are paid for.
on the stretch that u do go on the ls2 route, don't do the magna charger, its been proven multiple times on corvetteforum that the certrifugal supercharger makes more power through out the whole rev range, and it runs much cooler
Old Feb 18, 2008 | 05:54 PM
  #464
sentry65's Avatar
sentry65
the burninator
The Si-trim would actually be a good size blower for the LS2
Old Feb 18, 2008 | 06:39 PM
  #465
JonnyC's Avatar
JonnyC
So, am I screwed running the Si-trim with a 3.33 pulley? I know that it will be pushing a lot of air, but what about the power curve? And what about a wastegate setup? I know it hasn't been done very often. But if boost is limited, wouldn't I see a nice midrange power increase over the SC trim while staying safe?
Old Feb 19, 2008 | 06:34 AM
  #466
Quamen's Avatar
Quamen
A wastegate setup would be very nice to have but it can be expensive. 928 Motorsports offers a nice adjustable valve that we have had success with along with our customers. However, since it is adjustable it does take a level of percision adjustment you have to be comfortable with.
Other than that there are some other options out there and more coming in the future for more power without upgrading to the T-trim.
Old Feb 19, 2008 | 08:10 AM
  #467
sentry65's Avatar
sentry65
the burninator
what options are coming out in the future?
Old Feb 19, 2008 | 12:51 PM
  #468
JonnyC's Avatar
JonnyC
I'm sorry, but shouldn't there be some type of relief valve that will relieve pressure over some set level? I know a wastegate is a lot trickier than that, but it seems like there would be something relatively simple that could be utilized.
Old Feb 19, 2008 | 01:43 PM
  #469
jksstar's Avatar
jksstar
you will be fine with the 3.33 pulley.
Old Feb 19, 2008 | 03:19 PM
  #470
str8dum1's Avatar
str8dum1
the bypass dumps at 18psi IIRC. you could probably buy one that dumps earlier.
they assume you;ll use a smaller pulley to control boost levels. you can always use the pressure bleeds as was mentions from the 928 site.
Old Feb 19, 2008 | 04:21 PM
  #471
booger's Avatar
booger
The stock Vortech ByPass valve is made to hold boost to 18psi . It doesnt dump boost . In fact I've put much more than 18psi on it and it held
Old Feb 19, 2008 | 06:50 PM
  #472
JET MECH's Avatar
JET MECH
still waiting. no word back yet.
Old Feb 19, 2008 | 07:13 PM
  #473
JonnyC's Avatar
JonnyC
Oh, duh, i should have checked out the 928 site. Well, if it works as advertised, that would be pretty nice - although I hope it doesn't need constant adjustment once it's set. I could just set the boost fuel cutoff on the UTEC and keep adjusting the valve until i don't hit the cutoff. Anyways, this is off topic...
Hopefully you're the bearer of good news JET
Old Feb 20, 2008 | 05:14 PM
  #474
jksstar's Avatar
jksstar
still waiting? Not even my car and I'm starting to worry, hope everything is ok man
Old Feb 20, 2008 | 05:51 PM
  #475
JET MECH's Avatar
JET MECH
Sam has not called in two days. i am going to wait till friday then give him a call.
Old Feb 21, 2008 | 07:28 AM
  #476
jouvert00's Avatar
jouvert00
I think it's safe to say you have more patience than "JOB" what's your plan B if the numbers aren't satisfactory which i hope not.
Old Feb 21, 2008 | 02:08 PM
  #477
JET MECH's Avatar
JET MECH
Drove down to GTM today to talk to Sam and check on progress, Ok here is the latest. as of last night Sam did a couple of dyno pulls with a new bando serp belt installed and no additional pulleys installed on the serp belt side. after installing the additional pulleys it was noted that it would not work due to the serp belt hitting one of the supercharger mounting plate bolts so we are back the original vortech serp belt pulley setup. on the last pull to 6600 rpm the serp belt stayed intact but the cog belt decided to shread it self apart ( see attached pic ).just before the cog belt shreaded Sam documented some dyno #'s. 430.9 rwhp 380 rwtq at 12 psi. belt started slipping around 6000 rpm probably due to the brand new bando serp belt. Sam stated we need to re-tension the belt before any further pulls. now for the cog belt Sam is going to fabricate some custom pulleys to apply proper tension to the cog belt setup and keep it stable. the reason being remember i am running a non revup cog configuration, gates does not manufacture a proper belt size that will work. the belts are either to long or to short. that is why i had to run the belt over the idler pulley and during hard dyno pulls the belt is shreading. just to let you know the dyno numbers stated above were on a very,very conservative tune and A/F's were fat as hell. timing was pulled back quite a bit, these pulls were not final tuning runs they were done to see if the belts would stay together. Sam stated that when we start doing some final tuning he thinks we will be around 450 to 460 rwhp and hit around 400 rwtq. if we get the serp belt to stop slipping on the high end we may get even more, we will wait and see. Sam stated everything looks solid and the blower is running very cool. I just want to say thanks to Sam and his crew! they are doing a great job trying to iron things out and get this setup to work properly.
Old Feb 21, 2008 | 02:12 PM
  #478
sentry65's Avatar
sentry65
the burninator
nice
those would be some badass numbers if the belt thing can be worked out
Old Feb 21, 2008 | 02:27 PM
  #479
JET MECH's Avatar
JET MECH
this blower seems to be behaving alot like a T-trim in some ways. i noted yesterday that vortech is advertising the Si-trim now but under the v-1 blower, and not the v-2.
Old Feb 21, 2008 | 02:28 PM
  #480
booger's Avatar
booger
You would have thought Vortech would have made the belt setup better for the rev-up . Instead it seems to be less stable than the original . Hope he gets something worked out for you .
Anyone get a SI trim done on a non rev-up yet ?
