Si TRIM VORTECH.
Old Feb 27, 2008 | 09:49 AM
  #501
JET MECH's Avatar
JET MECH
Sam called last night we should have the cog pulley mod done by the end of the week..............HOPEFULLY!!!!!!!!!!
Old Feb 27, 2008 | 11:34 AM
  #502
JET MECH's Avatar
JET MECH
I was just wondering should i start a new thread when i have my dyno numbers and graphs to post?
Old Feb 27, 2008 | 11:35 AM
  #503
iStan's Avatar
iStan
ZR
^Blah. Just edit the first post with the info incase someone misses it.
500+ posts over one product, that's kinda impressive.
Old Mar 1, 2008 | 01:38 PM
  #504
Hexxum001's Avatar
Hexxum001
Bump for an update!
Old Mar 1, 2008 | 02:01 PM
  #505
JET MECH's Avatar
JET MECH
car is still a GTM no word from Sam..............
Old Mar 1, 2008 | 03:58 PM
  #506
Hexxum001's Avatar
Hexxum001
That sux man. Hopefully Sam will call with some good news really soon.
Old Mar 1, 2008 | 05:23 PM
  #507
JET MECH's Avatar
JET MECH
I give it another week at most. If not complete i am pulling out for sure!!!!!!!!!
Old Mar 3, 2008 | 01:43 PM
  #508
Hexxum001's Avatar
Hexxum001
I hope it doesn't come to that. I really wanna see what kind of numbers you put down with the Si trim.
Old Mar 3, 2008 | 02:37 PM
  #509
quangquoclu's Avatar
quangquoclu
Newbie
+1
Old Mar 5, 2008 | 08:44 AM
  #510
jouvert00's Avatar
jouvert00
Just checking in......
Old Mar 5, 2008 | 09:11 AM
  #511
str8dum1's Avatar
str8dum1
ya, if Sharif said my Si was the fastest Vortech hes tuned, I will be interesting to see what Sam says.
I could easily push more HP with a bigger exhaust.
Old Mar 5, 2008 | 10:06 AM
  #512
JET MECH's Avatar
JET MECH
Sam is very interested in this project and he advised me not to have him stop work just yet. He wants to make the cog setup work and see what this thing can push! i have almost been tempted to put the stock rev-up cog configuration back on but i know i would not be able to push the blower to it's full potential with the 34/32 cog setup. the blower would not spin fast enough and boost would come in to late in the rpm band.
Old Mar 5, 2008 | 10:18 AM
  #513
Quamen's Avatar
Quamen
Good luck JET and hopefully things work out for you and you get some really nice numbers!
Old Mar 5, 2008 | 11:19 AM
  #514
str8dum1's Avatar
str8dum1
why dont you think that the rev-up config will work?
Or do you just mean # of cog teeth like a non-revup?
Old Mar 5, 2008 | 01:45 PM
  #515
JET MECH's Avatar
JET MECH
yes # of teeth the non revup has. the revup cog setup spins the blower slower in the lower rpm range, this is due to the revup's higher red line. but we all know most fi setups will not make power up to 7000 rpm without extensive breathing mods ie, cams, head work, etc, etc. most flat line and dip at 6500 to 6600 rpm's. this is why i am so adimit on running the non revup cog config. that way the blower comes up to speed quicker and hits max rpm by 6600 rpm plus the torque curve will be much better. i have noticed most if not all revup vortechs are topping out at around 380 dyno jet rwhp. this is mostly due to this 34/32 cog configuration. i learned this the hardway after many tunes trying to get more power out of the stock revup cog setup. once i ran the 32/28 cog setup i could easily break the 4xxrwhp mark. i just started a new thread to compile some solid info on this theory...........
Old Mar 11, 2008 | 10:45 AM
  #516
Hexxum001's Avatar
Hexxum001
Bump for an update.
Old Mar 11, 2008 | 09:35 PM
  #517
Quamen's Avatar
Quamen
Seems like the Si trim is not to promising based on the lack of updates.
Old Mar 12, 2008 | 06:04 AM
  #518
jouvert00's Avatar
jouvert00
Damm at this point i just hope you get your car back.
Old Mar 12, 2008 | 06:08 AM
  #519
MI 35th's Avatar
MI 35th
OGPremierMafia
Yes bump for updates.
Old Mar 12, 2008 | 06:37 AM
  #520
str8dum1's Avatar
str8dum1
i dunno, basically 400hp on Sharif's DD is pretty promising. I think more flow (heads, etc) to use all that 15psi, VQ's will make even more power.
