Oil cooler/warmer removal.............
Old Sep 14, 2011 | 08:49 AM
  #281
DavesZ#3's Avatar
DavesZ#3
Originally Posted by JasonZ-YA
troof...lol...
either way, my reference is undertray or not ,they get hit and then oil is jetting out everywhere with downward sensors that can easily get hit..
-J
It can still be a problem without sensors. A buddy of mine made an off-read excursion during a track day and even with the undertray in place, the hoses got bumped enough to break one loose spilling oil all over the track.
Old Sep 14, 2011 | 04:54 PM
  #282
rh_334's Avatar
rh_334
Originally Posted by Zume
I have been working on my own custom up the middle V coolant mod for some time now. My question (confusion) is this---
On my 05 nonrev up the rectangular hole/cutout at the front of the engine where the main coolant line passes thru measures only 1 inch by 3 inches. Way to small for the HR pipe.
The above pictures (post #226) shows a black rubber hose passing thru this hole...how is this possible on a DE?
On mine I welded 3 smaller nipples on the modified cast rear return piece that go to 3 smaller hoses that are then able to pass thru the front 1" x 3" hole.
Thats why i used silicone, it oval'ed out enough to get through the hole. I believe accordfreak modified the HR pipe enough to fit through the hole. But with the large supply of silicone hoses Z1 has it was easier to weld a nipped to the Y-pipe and use silicone
As for the joining of hoses, i used SS hose joiners (i believe they are called) that hose is very odd size (same as stock going from hardpipe to rad), i cant remember off the top of my head.
Old Sep 14, 2011 | 09:56 PM
  #283
accordfreak's Avatar
accordfreak
on mine, i cut off the front end of the pipe and welded on a 1.25in straight pipe which is the almost the same diameter as the HR pipe. So the pipe goes through the hole almost perfectly. I say almost because some the rough casting around the hole needed to be sanded down. After sanding, it fit perfectly. A rubber hose from orielys or autozone was used from the pipe to the radiator. I then used a hose clamp from orchard supply along with some left over OEM brackets to bolt on to the timing cover to hold the middle pipe in place.
Old Sep 15, 2011 | 07:24 AM
  #284
Zume's Avatar
Zume
Mine ended up being a little complicated.
After calculating the oem pipe volume I think I ran (3) 3/4" hoses. Starting at the Y pipe up the V and exited thru the 1 x 3 hole. The 3 hoses feed into a new custom fill port / bleeder port at the front of the engine. In addition, I tapped and connected the "Pathfinder" port to one of the lines.
I assume this is all good since it is just like the HR...."system high point" bleeder and convenient fill port.
Old Sep 15, 2011 | 07:33 AM
  #285
Zume's Avatar
Zume
Default oem oil cooler
My idea was to re plumb the the stock oil heater/cooler by removing the plug and opening the port on the right side of the engine. Then run a short hose to the cooler and run a new hose into the rad. return...... This would clean it up a little.
Will probably scrap this idea and the oem cooler but was wondering....
Is is possible to tap into this port or would this screw up the coolant flow dynamics...???
Old Sep 15, 2011 | 08:45 AM
  #286
mw9's Avatar
mw9
Great pictures and write up on page 8 by JasonZ-YA as always
Old Dec 11, 2011 | 03:50 PM
  #287
ocdz's Avatar
ocdz
I plan on doing this mod over the winter. I found 2 different reputable companies making silicone "blanking caps". Any vendor deal with these companies want to step forward so I can order some of these???
http://racebikebitz.com/index.php?ro...product_id=813
Sard also seemed to have one but I couldn't find a link to it.
edit: found
http://www.rhdjapan.com/sard-silicone-cap-24195
Old Dec 12, 2011 | 10:21 AM
  #288
ashtrojan2008's Avatar
ashtrojan2008
I noticed a few people mentioned that 06+ doesn't have the oil warmer/cooler.
I have a revup and it came factory with one.
I left it on with the non thermostatic adapter and will remove it with the mocal.
Old Dec 13, 2011 | 04:37 AM
  #289
Rob@Z1's Avatar
Rob@Z1
I believe they meant 07+ HR and VQ37s (pre 12') do not have one.
Old Dec 14, 2011 | 06:38 AM
  #290
eZg's Avatar
eZg
I had a (un-named) shop install an oil cooler. They didn't "Like" the stainless lines I purchased per Binder's thread a while ago. SO they made their own which they failed to secure. My assumption is there was enough movement caused by air flow that the line flexed for a year in a certain spot eventually breaking.
Oil literally spraying out the front of the car making it as far rear as the trunk lid.
Ironic thing is I still had the less expensive oil line I had purchased and it worked fine to replace the busted one.
A few zip ties and I wouldn't be worried about the potential damage done to my built engine.
Old Dec 14, 2011 | 04:20 PM
  #291
bikinilust's Avatar
bikinilust
What coating is done on the timing cover?
Old Dec 14, 2011 | 04:54 PM
  #292
JasonZ-YA's Avatar
JasonZ-YA
paint......
looks like good ole paint.......excess seal is painted too..
-J
Old Dec 15, 2011 | 04:13 AM
  #293
rh_334's Avatar
rh_334
paint......
-J
Negative, Its PC. And yes the idiot PC'ed the sealant, but it was a free job so i'm not complaining... The color is called something chrome, it was sent to the guy to be polished, he decided he couldn't pull it off so he said he would PC it a "chrome" color for free, in the sunlight it does look polished.
Old Dec 15, 2011 | 04:22 AM
  #294
JasonZ-YA's Avatar
JasonZ-YA
^ interesting, i didnt think it was cause i would have thought the heat involved with pc would have ruined some of the seal....regardless, it looks great...
-J
Old Dec 15, 2011 | 04:27 AM
  #295
rh_334's Avatar
rh_334
-J
Thanks, I guess you could say it did "ruin it". It made the sealant hard as a rock and leaked. So i ended up scraping all that off and resealing.
Old Dec 15, 2011 | 05:49 AM
  #296
Exemption's Avatar
Exemption
wow! excellent mod and write up guys i might have to do this. The engine looks so clean with the powder coat on the pipes as well
Old Jan 4, 2012 | 12:24 PM
  #297
ocdz's Avatar
ocdz
I never heard from any vendors on here so i went straight to a manufacturer. Is anyone else interested in this product to cap off unused radiator coolant lines when removing this?
Venair already makes this product in another size which is used for this exact purpose, and is going to make a small run of reinforced silicone 4 ply blanking plugs for me. If anyone is interested pm me. I'm not sure on price yet, but gauging interest to see how many of these I will have made.
Old Jan 4, 2012 | 12:35 PM
  #298
bikinilust's Avatar
bikinilust
Wouldn't just be easier and better looking if u just took your pipe to be welded?
Old Jan 4, 2012 | 04:46 PM
  #299
ocdz's Avatar
ocdz
not really... I would have to remove it from the vehicle which would not be easier. I dont think these will be noticeable and will be of high enough quality to not deteriorate. It performs the same function and since I do not have a tig welder this is something I can do myself.
Old Jan 4, 2012 | 05:10 PM
  #300
bikinilust's Avatar
bikinilust
u r right...ur way would be easier
