Oil cooler/warmer removal.............
Old Aug 27, 2010 | 01:54 PM
  #201
shiftdrift06's Avatar
shiftdrift06
Damn didn't think it was that much lol. I am gonna check the muffler shops, if not,
I guess I gotta bust out the MIG and get some practice in lol..
Old Aug 27, 2010 | 02:30 PM
  #202
str8dum1's Avatar
str8dum1
+1, thats a lot of fill welding they have to do as well. my buddy had to do mine twice because it was weeping
Originally Posted by QuadCam
that's reasonable. welding doesn't come for cheap! My Lincoln Inverter tig is worth over $3000.
you may be able to get it done for less by checking around though. You never know when you will come across a welder in need of some coin!
Old Aug 27, 2010 | 09:09 PM
  #203
shiftdrift06
I see, This has been brought up before but what are you guys thought on using JB weld to plug the nipples?
Old Aug 29, 2010 | 03:25 PM
  #204
GreenGoblin's Avatar
GreenGoblin
Do it right, no need for jb weld.
Old Aug 29, 2010 | 04:17 PM
  #205
bikinilust's Avatar
bikinilust
Originally Posted by shiftdrift06
Yeahhh, im not to good at welding either..
Do you guys know how much it cost to weld up the three nipples? (2 on the passenger, 1 on the driver?)
I went to welding/radiator shop, they quoted me 50 bucks, i think that is a little steep?
I paid $50 the first time I had this done. Then cheaper the second time around.
Tell your welder to keep an eye on the tube's seam. with all the heat, it tends to want to split open. Plus make sure he grinds off all the slag inside.
when all said and done, pressure test it.
Ghetto/easy way: fill up your bathtub, cap one opening with your hand, and blow hard in the other end. if bubbles come out the weld area, you got a leak.
Old Aug 29, 2010 | 04:21 PM
  #206
bikinilust's Avatar
bikinilust
+1 do it right the first time....Just say NO to JB weld
you dont wanna be driving and all of a sudden your temps sky rocket because the JB weld popped out or cracked and started leaking coolant.
Old Aug 29, 2010 | 06:37 PM
  #207
shiftdrift06
thanks! Gonna get it done tomorrow. also bought 2 1/8 plugs and 3/8.
I got the the 1/8 plugs in but the tapping the thermostat is giving me alittle trouble..
Old Aug 29, 2010 | 07:03 PM
  #208
bikinilust's Avatar
bikinilust
If thinking about punching out nipple, be careful. I did it n it made a hairline crack all the way through.
make sure to use a lube when threading. Lube ALWAYS helps gettin it in
Old Aug 29, 2010 | 07:05 PM
  #209
bikinilust's Avatar
bikinilust
to be honest, the HR thermostat is pretty cheap...
id just buy one of those
$19.89 via courtesy parts
http://www.courtesyparts.com/21200-t...4_715_736_739&
You cab just have you local dealer price match, n save urself some change on the shipping
Old Aug 30, 2010 | 08:45 AM
  #210
J. Dub's Avatar
J. Dub
Aside from cleaning up the engine bay what are other benifts of removing ths? Or is that it?
I didn't read through all 11 pages.
Old Aug 31, 2010 | 07:40 AM
  #211
QuadCam's Avatar
QuadCam
on the thermostat, I used a cutoff wheel to take the nipple off, then I drilled and tapped the t-stat.
If you mess it up, just order a t-stat from an HR motor......it is nippleless!
Old Aug 31, 2010 | 07:43 AM
  #212
QuadCam's Avatar
QuadCam
makes the car easier to work on. alot fewer hoses running all over the place. fewer chances of a leaky hose too.
Old Aug 31, 2010 | 07:50 AM
  #213
J. Dub's Avatar
J. Dub
Makes sense. I'm glad I have a nippleless tstat. I'm dropping my car off at fail safe in November so I'll add this mod to the list for them.
Thanks for the reply
Old Sep 16, 2010 | 06:20 PM
  #214
midz350's Avatar
midz350
Guys, I have the HR and still got the oil cooler!!
Old Sep 17, 2010 | 03:15 AM
  #215
DavesZ#3's Avatar
DavesZ#3
Your car came with the factory oil "cooler"?
Old Sep 17, 2010 | 04:06 AM
  #216
JasonZ-YA's Avatar
JasonZ-YA
read the pages, your missing alot....
oil cooler will clog and become a corrosion junk build up point. better flow/circulation on fluid, etc..
Post 9 gives insight as well:
https://my350z.com/forum/5133260-post9.html
in for results....
-J
Old Sep 17, 2010 | 05:46 AM
  #217
06blueZ's Avatar
06blueZ
Old Sep 17, 2010 | 07:33 AM
  #218
midz350's Avatar
midz350
Yes.
Old Sep 17, 2010 | 07:45 AM
  #219
DavesZ#3's Avatar
DavesZ#3
It didn't come from the factory that way. Somebody added it
Old Sep 17, 2010 | 07:49 AM
  #220
DavesZ#3's Avatar
DavesZ#3
-J
I was at one of the local dealers a few week back and was talking to a buddy who is a tech there. I looked into his parts wash tank and there were several old oil coolers dumped in there. He told me that they clog, corrode and leak. "[you are] better off removing it from the engine" was his take on them.
