Oil cooler/warmer removal.............
Old Mar 7, 2011 | 05:23 PM
  #241
Bigalow's Avatar
Bigalow
Originally Posted by QuadCam
that's reasonable. welding doesn't come for cheap! My Lincoln Inverter tig is worth over $3000.
you may be able to get it done for less by checking around though. You never know when you will come across a welder in need of some coin!
FINALLY DONE READING.
Anyway, +1, check CRAIGSLIST for skilled workers. The economy has hit everywhere and I'm sure you'll be able to find an experienced welder in need of work. As a matter of fact, I just contacted a 'mobile' welder that offered to weld at my place. Thats fantastic as my car is apart and I have other convience mods that I'm interested in.
Old Mar 13, 2011 | 03:44 PM
  #242
Bigalow's Avatar
Bigalow
Alright, I just took out the pipes - Engines in the car.
To remove the stock oil cooler pipes. I had to loosen up the A/C unit to get to the little screw holding pipe -
By far the hardest screw was the (R) lower one holding up the stock rear coolant pipe. I had to use various extensions/different positions to find room to torque my ratchet.
PIPES w/ Pathfinder at top.
There was a sensor (BLUE) attached to the stock piece. I imagine that I can re-locate it to the pathfinder pipe (to the left of the big openning)
Old Mar 20, 2011 | 10:37 AM
  #243
Bigalow's Avatar
Bigalow
Update:
Removing the coolant pipes weren't as big as a hassle as getting the pathfinder’s by-pass unit in place.
After hours of fiddling around, I decided to simply loosen up my fuel lines and remove my intake manifold. To my surprise my intake gaskets were blown. I'll have to get a replacement from Nissan tomorrow.
Intake mani w/ blown gaskets. I could smell fluid and see residue built up in the air cylinders. I'm not sure why the black material started rubbing off and coating the cylinder walls.
Rear Coolant location exposed (GREEN). Notice the filth the intake gaskets left on the intake cylinder walls.
PF coolant pipe installed.
Another problem I encountered was getting the stock water temp sensor secured. I suggest anyone utilizing the PF's location ensure that the sensor is perpendicular to the pipe (i.e. with the clip point face away from the (R) engine head as shown).
Old Mar 20, 2011 | 02:55 PM
  #244
accordfreak's Avatar
accordfreak
I also removed all the oil cooler/warmer lines and install my version of the HR setup.
Old Mar 20, 2011 | 08:48 PM
  #245
skakemokid's Avatar
skakemokid
^PART NUMBERS please!!!!
That looks reallly cool..
Old Mar 20, 2011 | 08:55 PM
  #246
phunk's Avatar
phunk
CJ Motorsports
I wanted to go thru there also with the HR rear pipe, but I wasn't sure if it would clear my front throttle body setup.
Old Mar 21, 2011 | 04:06 AM
  #247
Bigalow's Avatar
Bigalow
If I would've known how this worked and operated then I would've gone that route. I like how you can still connect the heater.
It doesn't look like you're accessing the pathfinder rear cylinder by-pass location. I suppose it doesn't matter since you're flowing coolant directly from the heads to the RAD anyways. Great setup!
Old Mar 21, 2011 | 04:35 AM
  #248
Cass007's Avatar
Cass007
I thought the whole idea behind the PF mod was to get coolant to flow directly to the rear of the heads through the passage under the intake. I'm not sure how this mod helps that
Old Mar 21, 2011 | 06:08 AM
  #249
Bigalow's Avatar
Bigalow
That's a common misconception. The fact of the matter is that hot coolant escapes the block quicker. The PF mod within itself is useless IMO. You have to also eliminate a lot of those by-pass lines that this thread basically talking about. Does it help NA cars? Probably a little. Does it help F/I? Yeah.
Old Mar 21, 2011 | 07:17 AM
  #250
str8dum1's Avatar
str8dum1
You sound like you have taken accurate temperature measurements. Can you share them to show conclusively that this helps?
I never measured my temps before, so please post your definitive data.
Old Mar 21, 2011 | 07:22 AM
  #251
Bigalow's Avatar
Bigalow
No 'accurate' temps have been taken, bud. My pic above indicate that I haven't finished with this mod.
Old Mar 21, 2011 | 07:39 AM
  #252
rh_334's Avatar
rh_334
I really like this setup, im going to have to look into this for my build.
What all did you have to delete from that stock hardline? i know the oil warmer, anything else. My only problem is im not sure where i could feed my pass side turbo from, it has a Tee Fitting where the stock bleeder used to be right now.
Old Mar 21, 2011 | 10:48 AM
  #253
accordfreak
I did the HR setup because i wanted to utilize wasted space in the middle of the motor. It would also be easier to work on the passenger side, manifold, turbo etc if i had to without removing any coolant lines.
here's a 5 year old draw up of what i had planned
you need to cut the HR rear pipe in half ,bolt on the two halves on the block and reweld it since it is wider. Also, the pipe that goes down the middle, the end piece needs to be cut off and a 1 1/2 in straight pipe needs to be welded to go through the hole.
I also sanded the rough casting of the engine block hole to be smooth so it doesn't make a hole in the coolant pipe.
Attached Thumbnails Oil cooler/warmer removal.............-new-coolant-setup1.jpg
Old Apr 19, 2011 | 02:47 AM
  #254
Bigalow's Avatar
Bigalow
Hey, I forgot to mention, for those of you doing this mod.
You'll have to cut either your pathfinder log or the stock coolant pipe to make it fit poperly (I cut the stock gold coolant pipe). Also, I choose the HR thermastat so if anyone is using the HR stat then USE THE HR BOLTS. Avoid using the DE bolts as mentioned above.
Old May 3, 2011 | 07:14 PM
  #255
omsin523's Avatar
omsin523
Originally Posted by DavesZ#3
I believe a engine would be fine without it. Remember that this oil cooler/warmer is only on the 03-05 models - Nissan dropped it from the 06+ cars.
Just want to verify, that the factory oil cooler/warmer is on 03-06 and not on 07+. My car is an 06 and has it. But not sure if the 06 rev-up has it or not im assuming it does though.
Old May 3, 2011 | 07:48 PM
  #256
rcdash's Avatar
rcdash
So how do you know what's a common misconception and what isn't when you have no data? Just asking...
Old May 13, 2011 | 02:02 PM
  #257
Bigalow's Avatar
Bigalow
this:
Old Jun 11, 2011 | 09:43 PM
  #258
lemmiwinkz's Avatar
lemmiwinkz
^^ after reading through this whole thread, this makes no sense. from what i understand there is no exit for coolant at the back of the block so they came up with the pathfinder mod, correct? how does the HR mod fix this? just because the coolant gets hot means that it can flow backwards against the stream? i would think that the more efficient way to get the coolant out would be to have an actual exit but maybe thats just me. please explain more
Old Jun 12, 2011 | 11:03 AM
  #259
bikinilust's Avatar
bikinilust
There is a coolant exit at the back of the engine on both passenger side and driver side [either on the head or the block/i forget]
pathfinder mod is a means to release hot coolant via the rear cylinders
Nissan prob implemented the center exit coolant pipe on the HR because the of the dual TB
DE guys are doing this for either aesthetics and/or to have more room on the passenger side of the engine for turbos and what not
No
Old Jun 12, 2011 | 11:04 AM
  #260
bikinilust's Avatar
bikinilust
if you are still having trouble understanding the paths which the coolant flows, somewhere in this thread there is a coolant flow chart
