weird idle question
Old Jun 29, 2008 | 12:39 PM
SlowZster's Avatar
SlowZster
Default weird idle question
well, when I start my car after driving it for a while, and the motor is warm, sometimes my idle drops to like 600-700rpm, and my af gauge starts to read anywhere from 15.9-18.9. As soon as I give it gas, and start to drive it goes back to normal. Was wondering what could be causing this (im sure it can be many things). Current setup can be found at https://my350z.com/forum/north-west/361284-hin-august-seattle-link-inside-6.html. Only thing I could be thinking is I may have screwed up the pcv valve since I still have my home made catch can installed in the same place as i did when I was NA. Could be wrong though as I don't know too much about AF ratios, and things like that.
Old Jun 29, 2008 | 08:28 PM
3.6z's Avatar
3.6z
need more fuel at idle..
Old Jun 30, 2008 | 06:57 AM
XKR's Avatar
XKR
What plenum do you have? It sounds like you need an ECU re-flash.
Old Jun 30, 2008 | 09:00 AM
SlowZster's Avatar
SlowZster
running the aps plenum, and mrev2. Don't think my ecu got reflashed when tuned (i know nothing about tuning). I think they only worked on the utec, and not the normal computer.
Old Jun 30, 2008 | 09:22 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would definitely raise up your idle. using either a consult2 or cipher. then mess with it. these cars like to idle a little higher...
Old Jun 30, 2008 | 09:43 AM
SpoilsofWar's Avatar
SpoilsofWar
I idle at about 650rpm without issue, A/F is between 14.7 and 15.4 at idle. Also using a utec. Also have homemade catch can.
Old Jun 30, 2008 | 11:14 AM
SlowZster's Avatar
SlowZster
ok, made an appointment with nissan to get the idle changed to a little bit higher. Thanks for the info. Hopefully this helps a little bit.
spoilsofwar: do I need to move the tubing for the catch can when boosted?
Old Jun 30, 2008 | 12:02 PM
SpoilsofWar
I am still running the catch can inline from the passenger side valve cover to the plenum. There are a lot of FI people doing it this way. Some say its bad for the PCV valve. I dunno. If it worries you, move it, or install a one way check valve between the catch can and the plenum.
Old Jun 30, 2008 | 02:40 PM
XKR's Avatar
XKR
After Sharif installed the Cosworth plenum...the idle was drop below 600 rpm...it was stall sometimes. I had to get a reflash with 900-1000rpm's.
Idles real nice now.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
