Can i drive home?
Old Jul 14, 2008 | 10:40 AM
y0shi's Avatar
y0shi
Default Can i drive home?
I just had a vortech supercharger installed w/ cjm stage 1 return fuel, walbro and 440cc injectors and utec w/ map sensor put in. I have scheduled for a tune later this week. In the mean time, i need to get the car home. Can i drive the car home, with the cog belt off, so i don't go into boost and Driving it very easy.
Thanks!
Old Jul 14, 2008 | 10:47 AM
Hoooper's Avatar
Hoooper
you could even drive with the belt on. as long as you dont get into boost its fine. dont expect great mileage though, but as long as you keep it in closed loop it shouldnt be too bad (mileage)
Old Jul 14, 2008 | 10:50 AM
JZurita's Avatar
JZurita
yes
Old Jul 14, 2008 | 11:16 AM
y0shi's Avatar
y0shi
My car/utec isn't tuned and set to Map 0. The drive home is about 20 miles. So it would be fine to drive home?
Old Jul 14, 2008 | 11:20 AM
Spork's Avatar
Spork
IIRC, the base map is good only to get your car home and/or to a shop for a tune. Just keep the rpms low and don't hit boost.
Old Jul 14, 2008 | 11:47 AM
rcdash's Avatar
rcdash
Map 0 is running off the stock ECU, as though the UTEC is not connected at all. Without any air being forced into your engine, you should be fine.
Old Jul 14, 2008 | 12:01 PM
SpoilsofWar's Avatar
SpoilsofWar
The UTEC manual says you cannot use map 0 if you have larger then stock injectors.
But I dont see why not, it will probably just run pig rich.
Old Jul 14, 2008 | 12:35 PM
rcdash's Avatar
rcdash
Oops forgot about that little issue. If you have cats, running rich will burn them up. If you have test pipes, you'll just be really stinky. In a week, I don't think you'll damage your plugs...
Old Jul 14, 2008 | 12:38 PM
Everybodywildou's Avatar
Everybodywildou
Load the turbonetics map temporarily. Thats what I did.
Old Jul 14, 2008 | 12:42 PM
zulator03's Avatar
zulator03
ya pretty sure it wll be Dont go ino boost or else
Old Jul 14, 2008 | 01:21 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, but still don't get into boost
Old Jul 14, 2008 | 03:30 PM
superchargedg's Avatar
superchargedg
Damn Noobs
You will be fine just driving home and to the shop who tunes it.Just dont get into any boost as that is what i was told after i installed my greddy twins.I will say it was a slow drive to my tuner but afterwords it was all smiles.
Old Jul 15, 2008 | 09:23 AM
gothchick's Avatar
gothchick
If the belt is still connected, how can the OP avoid boost on a SC? It's RPM driven. Take the belt off if ya wanna stay outta boost.
Old Jul 15, 2008 | 09:38 AM
Everybodywildou
It doesn't build boost unless you really get on it.
Old Jul 15, 2008 | 10:54 AM
05Z33's Avatar
05Z33
Yea, when I'm on the highway at 80mph I'm in vacume unless I floor it.
Old Jul 16, 2008 | 10:16 AM
SteveZ's Avatar
SteveZ
our you can get flames out the pipes, too...nice effect, but not if you like having cats...
Old Jul 16, 2008 | 11:40 AM
Hoooper's Avatar
Hoooper
youre a little confused on it. youre right that it is RPM dependent, but its only RPM dependent under high throttle conditions. under partial throttle, the boost is more load dependent
Old Jul 16, 2008 | 11:45 AM
y0shi's Avatar
y0shi
i got home just fine with the belts on. Thanks everyone!
Old Jul 16, 2008 | 11:50 AM
Hoooper's Avatar
Hoooper
glad to hear it. now go get it tuned!
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
