Did detonation cause this? UPDATED PICS Pg: 5
Old Oct 7, 2008 | 07:35 PM
  #101
Sylvan Lake V35's Avatar
Sylvan Lake V35
Where the pieces in the cylinder or did they go through the turbo?
Old Oct 7, 2008 | 07:43 PM
  #102
350 Rookie's Avatar
350 Rookie
Originally Posted by thom000001
Check the turbo too, those pieces had to go somewhere.
well i took off the turbo today, obviously and it seems fine. shaft spins nice and free and absolutly no play and something that usually happens with TN turbos didnt happen, no oil came from the hot side of turbo. I was suprised. LOL
Old Oct 7, 2008 | 07:45 PM
  #103
350 Rookie's Avatar
350 Rookie
Nothin in the cylinder. Might have gone through the valve and got stuck somewhere in the pipe or maybe wastegate or maybe somehow GOD felt bad for me and just let the peices just flow right past the turbine blades.
Old Oct 7, 2008 | 07:47 PM
  #104
Blackbird CPV35's Avatar
Blackbird CPV35
Originally Posted by 350 Rookie
well actually, ever since my turbokit went on the car, ive been hearing some very light knocking noises but i NEVER figured out what it was. mostly at idle. other than that, no
hmm i have that too, i need to check my pulley
Old Oct 7, 2008 | 07:50 PM
  #105
350 Rookie's Avatar
350 Rookie
Check for oil leak around it. If theres oil leakin, then you might have a bad seal there or its cracked.
Old Oct 7, 2008 | 08:01 PM
  #106
SpoilsofWar's Avatar
SpoilsofWar
If you have a built engine with forged pistons, it could be piston slap. My engine is somewhat noisy at idle when cold, but it goes away when it is warmed up. I also attribute some of the idle noise to solid motor mounts.
Old Oct 7, 2008 | 08:35 PM
  #107
Blackbird CPV35
def not piston slap, this happens when it is hot and its totally intermittant, it also goes away when i rev the engine.
Old Oct 8, 2008 | 06:37 AM
  #108
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I heard your noise when you came to my shop....it' valvetrain, IMHO. Valve lash is probably a little off.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
