APS ST started today :)
Old Feb 2, 2009 | 07:20 AM
  #121
Smitty??'s Avatar
Smitty??
I dont remember anyone asking this before but who did you purchase your kit from? I've got some info for you if we bought from the same people.
Old Feb 14, 2009 | 10:56 AM
  #122
nightcrawler_8's Avatar
nightcrawler_8
Update:
today i got the APS ST turbo exhaust installed .
and the result is
boost is 0.4 all the way to redline.
double checked the clamps and hoses... no leaks.
actuator is tightened to the max.. still no boost spike.
before with the blitz exhaust . boost use to go up sometimes ( 0.7 then drop back to 0.4 )
with the APS exhaust, its constantly 0.4 all the way to redline without any drop...
now what???i have tried everything.... shall i jump from Dubai burj????!!!!!
Old Feb 14, 2009 | 11:02 AM
  #123
Zivman's Avatar
Zivman
Originally Posted by nightcrawler_8
now what???
Get it tuned
Old Feb 14, 2009 | 11:04 AM
  #124
thom000001's Avatar
thom000001
Sounds like you had a problem before and now its fixed to me.
You were overboosting before now its controlled. What are the size differences between the 2 exhausts and what spring pressure is the wastegate running?
tom
Update:
and the result is
Old Feb 14, 2009 | 05:31 PM
  #125
tig488's Avatar
tig488
the signal from the elect boost controller hooked up to the unichip?
Old Feb 14, 2009 | 09:39 PM
  #126
nightcrawler_8
Originally Posted by Zivman
Get it tuned
i thought you guys said that the tune on the APS unichip is already solid enough to get some nice power !!!!!!
tom
max was 0.7bar which is around 9psi( normal boost for APS st) and goes back to 0.3bar. now its all the time stuck on 0.3~0.4 Bar.
Blitz: single 2.75"
APS ST: Dual 2.5" ( APS claim that its a Zero back pressure )
No Electrical Boost controller. disconnected it, am using the Unichip boost solenoid.
any thoughts!!!!????
Old Feb 15, 2009 | 01:21 AM
  #127
GTM's Avatar
GTM
Vendor - Former Vendor
If you are having constant boost pressure to redline without spikes thats a good thing.
Either get the Unichip tuned and increase boost via the unichip or get an electronic boost controller. Sounds like you are just running off waste gate pressure to me.
-George
GT Motorsports
Old Feb 15, 2009 | 02:14 AM
  #128
SmallTuner's Avatar
SmallTuner
is your car is boosting without any power??
if that is the problem, i say go and check the flywheel installation.
Old Feb 15, 2009 | 07:30 AM
  #129
Zivman's Avatar
Zivman
my tune was good... now that I see the results from the exhaust, I think you have something related to the boost control solenoid that needs to be addressed. IMHO you are running entirely on spring pressure and the exhaust is keeping it very stable which is a good thing. I don't think you have it hooked up properly which is kind of what I thought from the start. That said, the proper exhaust is very important.
Blitz: single 2.75"
From what my tuner claims, the APS duals for the twins has zero back pressure up to 14 psi... I would assume the APS single exhaust would be zero back pressure to 12-13, or possibly the same 14 psi as the duals
My thoughts are throw it on the dyno, have your tuner try to adjust boost and confirm whether or not your boost control solenoid is working, or even hooked up properly. I would bet it isn't working the way it is supposed to. How many eyes have looked over the installation?
Old Feb 15, 2009 | 07:54 AM
  #130
nightcrawler_8
2 eyes,
i dont have much of an option in here.. its just 2 shops that knows about Turbo Z's in here.. and both checked the installation and confirmed that everything is ok..
is there a way i can check my self ??? How can i check that the boost solenoid is not right ??
Old Feb 15, 2009 | 08:02 AM
  #131
frankie945's Avatar
frankie945
Can't you just unplug the boost solenoid and just run off wastegate spring and see what you get.
Old Feb 15, 2009 | 08:10 AM
  #132
Zivman's Avatar
Zivman
2 eyes,
two ways to check things out.
unplug the solenoid and see what you get as frankie stated. I will bet you see the same boost levels you are seeing now, futher confirming I don't think something is hooked up right (or not working)
also, get a small vise grip and pinch the vacuum line going from the solenoid to the wastegate. BE VERY CAREFUL with this one. Doing this will basically max out the boost level of the turbo. I say try this and watch your boost gauge closely and see if you can make more than .4 bar with your current setup. This will help narrow down the problem area. If you can't make any more boost, there is an issue from the turbo side of things... maybe a boost leak, bad turbo, ect. If you can, it is clearly a boost control issue
Old Feb 15, 2009 | 08:12 AM
  #133
frankie945's Avatar
frankie945
I can tell you one thing about the exhaust. I was running the TN kit with a custom y to mate to Borla exhaust which is 2.5'' and with no resonators I could only boost to 7.2psi. Then went with a full custom 3" with a resonator only, Sounds good but loud and was boosting to 9.5 psi off the 7psi spring. Went back to the muffler shop and put a Vibrant can on. Now I am boosting at 8psi and love the sound. I spent almost 2k just getting my exhaust right.
Old Feb 15, 2009 | 08:21 AM
  #134
Zivman's Avatar
Zivman
he has the proper exhaust on now. That is not of any concern now. The APS single exhaust is the best exhaust for his application.
Old Feb 15, 2009 | 08:26 AM
  #135
frankie945's Avatar
frankie945
I thought he was running some 2.5" duals.
Old Feb 15, 2009 | 11:00 AM
  #136
Zivman's Avatar
Zivman
he is running the APS single turbo exhaust specifically designed for his turbo kit... it is a y-pipe splitting into dual 2.5". You can reference APS' site if you are curious what it looks like
Old Feb 15, 2009 | 01:15 PM
  #137
VeilsideZ33Mass's Avatar
VeilsideZ33Mass
my problem is different ..
usually my tank can handle up to 500KM.
so lets say i refill it to "FULL" teh indecator will show full.. but after drivign it for some time.lets say 50KM only... then the light comes on " EMPTY" .. then again goes to middle.. then EMpty ,,, then middle again..
so its acting wierd .. hope it will be solved.
Yeah I dt know anything about my crossover pipe leaking, but mine has only 5K miles on it. I am currently replacing the whole wastegate setup aps has with an external 44mm tial that has a flex pipe in it, with an extermal dump. I cant imagine breaking the crossover pipe unless you kit the turbo which is under the K member... so I dunno. when you do install the cross over pipe one of the studs is EXTREMELY close to the turbo mount/merge Id replace it with a bolt. as for the level sender, yeah nissans are kinda screwey with it but its usable. I dunno, I think its a great kit, and its been very good to me, but some things like the WG setup sucks, and id put an inline oil filter to the turbo (Force Performance sells em.). Just my 2 cents...
Old Feb 15, 2009 | 03:47 PM
  #138
tig488's Avatar
tig488
thats the one im talking about. like Zivman said above. make sure the red wire from the solenoid is going to the unichip. when mine wasnt i boosted to 5psi and that was it, and it did hold 5 to redline.
Old Feb 16, 2009 | 01:47 PM
  #139
wirelessdude04's Avatar
wirelessdude04
dam
Old Feb 17, 2009 | 07:33 AM
  #140
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Yup, that's the easiest to overlook. You need to hook up the red wire to an empty slot of the unichip plug. If I remember correctly, it's not shown in the instruction diagram, but the instruction is written in the manual. If your mechanic installed everything just by looking at the diagrams provided by APS, he probably missed it.
