Is there a way to send ECU a MAF voltage from Haltech?
Old Mar 16, 2009 | 01:05 PM
down_shift's Avatar
down_shift
Default Is there a way to send ECU a MAF voltage from Haltech?
The Fcon can send the ECU a false voltage for the MAF.. Can the Haltech do this? If so, is there any documentation? The manual doesn't have much info.
Old Mar 16, 2009 | 01:16 PM
Jeremy@Altered's Avatar
Jeremy@Altered
Just bypass the haltech with it if you want it to have that maf signal
Old Mar 16, 2009 | 01:18 PM
rcdash's Avatar
rcdash
It is my understanding that the Haltech can modify the MAF and pass it on, but it cannot de novo generate a signal (like a MAP to MAF conversion, for example). So if you have no MAF sensor anymore, then the Haltech would be stuck. I would check with Hal for latest updates on this though...
Old Mar 16, 2009 | 01:24 PM
down_shift's Avatar
down_shift
I have my MAF still hooked into its harness, but it's not in the charge pipe.. just sitting in my engine bay.
My AIT sensor is spliced into my MAF wiring.
How do I know if the MAF signal is being modified and sent to the ECU to keep it happy? I am getting a low voltage CEL for my MAF
edit- Anyone know if there is any documentation for this?
Old Mar 16, 2009 | 02:12 PM
frankie945's Avatar
frankie945
I wonder if you can delete the maf code with a flash. Kinda like you have to do to get rid of the others that come you get like the o2 sensor codes. Are your vdc, slip light still on? I talked to a guy at the dealership today he said if the maf goes out it is sometimes the vdc slip will stay on in some cases. I don't understand the some cases part, but that's what the tech told me.
Old Mar 16, 2009 | 03:19 PM
down_shift's Avatar
down_shift
That's a negative. I'm avoiding the whole reflash thing for now since it only turns the lights off. It won't pass emissions if it's scanned.
I just overnighted a MAF flange from Turbotim@SFR lol.. I need this fixed before Friday..
Old Mar 17, 2009 | 12:25 AM
accordfreak's Avatar
accordfreak
it looks like the MAF signal can be emulated to prevent cel
https://my350z.com/forum/4543871-post12.html
Old Mar 17, 2009 | 04:32 AM
rcdash's Avatar
rcdash
^ I think that was what was supposed to happen, but I don't think it works that way (yet).
Old Mar 17, 2009 | 05:30 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
From your other post on same topic: https://my350z.com/forum/tuning/4230...ge-to-maf.html
Haltech is setup to limit the MAF values, but is not currently setup to output a MAF value from nothing. What is happening that you describe as 'limp mode'? What year is your car, and is it auto or 6spd?
Old Mar 17, 2009 | 09:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
on a manual transmission car you CAN completely eliminate the factory MAF sensor - doing so WILL cause a CEL, which can only be eliminated through a re-flash. Do completely eliminate the MAF, you need to wire in the AIT sensor as well as use a MAP sensor.
This only works on manual transmission cars, does not work for auto's
Old Mar 17, 2009 | 09:51 AM
down_shift's Avatar
down_shift
I have my MAF plugged in but not in the charge pipe.
MAP and AIT are both good.
Getting a low voltage CEL from ECU.
I'm playing around with the the Haltech app right now. There's the MAF chart in the setup window and the MAF calibration screen. Is the MAF Calibration screen suppose to be "0" value?
Old Mar 17, 2009 | 09:56 AM
Dynosty's Avatar
Dynosty
Also what CEL code are you getting... what is the number (for example P9999) ?
Old Mar 17, 2009 | 09:58 AM
down_shift's Avatar
down_shift
Hey Hal, tried to call you today haha. You're a busy man!
p201, p202, vdc+slip
Getting rough idle and stalls if I don't rev it
Old Mar 17, 2009 | 10:02 AM
Dynosty's Avatar
Dynosty
Old Mar 17, 2009 | 10:04 AM
down_shift's Avatar
down_shift
Whoops sorry bout that.. 2004 G35 coupe 6MT
It's Matt. I spoke with you over the phone a few times about emissions in Boston haha
hulkout
Tuning
Sep 30, 2015 12:33 PM
