what do you think I need for making high hp?
Old Sep 18, 2009 | 12:25 PM
  #101
ttg35fort's Avatar
ttg35fort
Professional
I have looked for data on the Brian Crower cams to do a more thorough analyis on them. However, the only information posted on their website is the duration, adv. duration and lift. Does anybody have data on the lobe separation angles for the BC cams that they can share??? If so, I'll compute the rest of the cam parameters and post them.
Old Sep 18, 2009 | 12:29 PM
  #102
ttg35fort's Avatar
ttg35fort
Professional
[QUOTE=RudeG_v2.0;7759094]LOL At the rate you are going... you will surpass Scott in no time!
What is that supposed to mean???
Old Sep 18, 2009 | 12:39 PM
  #103
go-fast's Avatar
go-fast
you can't calculate ramp rate without mapping the the actual cam personally.without this info the rest is just about useless against another cam.
  #104
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
That's because you would't even understand what he was even talking about.
You have no idea who you are talking to. He is an OG in this industry and way out of your league.
Old Sep 18, 2009 | 12:49 PM
  #105
ttg35fort's Avatar
ttg35fort
Professional
I agree.
I disagree.
Knowing the lobe separation angle and amouint of valve overlap still can be informative and help someone to select the approprate cam for them. For example, generally speaking, a 272 deg. cam with 30 degrees of valve overlap at TDC is going to idle better than a 272 deg. cam with 40 degrees of valve overlap. However, the cam with the greater overlap likely will provide better high end performance, assuming reversion does not become an issue.
Old Sep 18, 2009 | 12:57 PM
  #106
go-fast's Avatar
go-fast
I agree.
I disagree.
what if i told you that you can design a camshaft that measures .485 lift but achieves an actual .520 lift?where does your "advertised" math get you now?
Old Sep 18, 2009 | 12:58 PM
  #107
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
spring dynamics are not something exclusive to jw.check and see if he winds his own springs,because this is the only way for him to provide some top secret formula.....even if he did (which he doesn't,he buy's them like you and me) he's following the same rules of metalurgy as everyone else.
so,now you tell me how he manufactures camblanks that only function with propietary springs and i'll give you a biscuit.
Old Sep 18, 2009 | 01:00 PM
  #108
ttg35fort's Avatar
ttg35fort
Professional
More lift, I presume. Where are you going with this? It's unclear what you are trying to say.
Old Sep 18, 2009 | 01:02 PM
  #109
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by RudeG_v2.0
Don't think so.
He is selecting springs in which the spring harmonics work well with his cam profiles. In other words, he has done the analysis to know which spring profile and spring rate works well accross his product line. If you randomly select some other spring without doing this analysis, you may get it right, you may get it wrong. Why is that so hard to understand???
Old Sep 18, 2009 | 01:14 PM
  #110
go-fast's Avatar
go-fast
no not more lift,that's my whole point about ramp rate.i'm trying to tell you advertised math does not speak to the nature of the camshaft.call it ballpark info at best.
Old Sep 18, 2009 | 01:19 PM
  #111
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I thought it was pretty clear what I meant.
Maybe you don't realize it... But you have been coming across lately as a huge JWT fanboy/nutswinger. Sorry if that offends you. I thought it was worth pointing out that not everybody (including some of the top shops in this community) are convinced of JWT's superiority and that some of us have a problem with Jim's shady business associations (and therefore won't buy or support his products).
Old Sep 18, 2009 | 01:20 PM
  #112
go-fast's Avatar
go-fast
Don't think so.
i think if you understood how narrow the range of choices there where it would be easier to understand that jim wolf and his "harmonics" are blowing smoke up your @ss.this is all i was trying to say,i have no idea why you make calling bs on jw personal.
you should be angry with him for trying to sell you magic beans
Old Sep 18, 2009 | 01:27 PM
  #113
ttg35fort's Avatar
ttg35fort
Professional
You said "a camshaft that measures .485 lift but achieves an actual .520 lift?"
Is .520 lift not greater than .485 lift????????
Well, ballpark information is better than nothing.
Maybe you don't care about these parameters. That's fine.
But go outside our little VQ community, and yes, there is A LOT of evidence that valve overlap and valve separation angle do make a difference on a motors performance, even when all other things are equal. The guys who really know their **** take all of this into consideration when building a motor.
Old Sep 18, 2009 | 01:31 PM
  #114
ttg35fort's Avatar
ttg35fort
Professional
The reason I have pointed out the JWT cams is because:
1. He publishes alot of information about his cams, which others don't.
2. For the same duration, those cams typically provide greater lift. Lift is important.
3. I always note that they are limited to about 7500 rpm and that if you want something to go beyond that, look at GTM and BC cams.
4. Other than JWT cams and an oil spacer, I don't have anything else that is JWT. In fact, I have a GTM motor and a GTM turbo kit. I probably use the term GTM in this forum alot more than JWT.
Old Sep 18, 2009 | 01:40 PM
  #115
go-fast's Avatar
go-fast
yes .520 is greater lift....this is my ramp rate point....your starting to get it.
Old Sep 18, 2009 | 01:43 PM
  #116
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Don't think so.
Let's see...
You are an attorney by trade IIRC and go-fast is a renowned engine builder beyond just the VQ platform with a waiting list of customers. Now who should we listen to and believe? I tried to warn you about continuing to argue with go-fast. Keep arguing with an expert in this industry and dig that hole deeper.
Old Sep 18, 2009 | 01:48 PM
  #117
go-fast's Avatar
go-fast
Let's see...
he's not arguing,he just doesn't understand.jw sold him a speech about magic beans need magic soil or some crap like that and he's finally coming around
Old Sep 18, 2009 | 01:49 PM
  #118
rcdash's Avatar
rcdash
Hi Raj, you didn't look good enough.
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
In the lower right hand boxes for each of the C2, C8, C9 and C1HR cams, it states: "MUST USE JWT SPRINGS". The box for the S2 cams does not state ths.
I spoke with Jim Wolf months ago about the C8 cams. I asked him whether it would be worthwhile to use stiffer springs with the cams to get more RPM out of them. He specifically told me not to because his springs were designed to be harmonically balance with his cams. He said using other springs probably would be counter-productive.
Terry the point is that there is no written documentation that states that you should NOT use anything other than XXX springs with YYY cams.
For S2 cams, it does not say that they REQUIRE stock cams nor does it say that you cannot use JWT springs.
I am dubious that the springs are part of the design for eliminating unwanted harmonics. As long as the spring helps the entire valvetrain to stay in contact with one another, I think they are serving their purpose - no more, no less. I respect what Jim Wolf has to say, but I won't believe it just because he feels it is "probably" true especially when he has a product to sell.
Here is a well written site on cam analysis and cam springs:
http://www.tildentechnologies.com/Te...CamBasics.html
http://www.tildentechnologies.com/Te...amSprings.html
Here is what they have to say about valve springs in relation to cams with higher lift:
Higher engine speeds require stiffer springs, but higher lifts lead to higher spring forces, so weaker springs can be used.
If I were building a high revving motor (above 7500 rpms), I would use BC valve springs regardless of the cam I selected, JWT or otherwise. If you find hard data that argues against this, always happy to take a fresh look.
Old Sep 18, 2009 | 01:51 PM
  #119
ttg35fort's Avatar
ttg35fort
Professional
That is one more reason why selecting the right spring is important. You don't want the lifter (or in our case the bucket), launching off the end of the lobe.
Although a spring has a spring constant K, under dynamic conditions the spring is not so constant. E.g.,
http://www.youtube.com/watch?v=i_Npz...om=PL&index=16
If there is a spring harmonic which causes the spring to compress right about the time the top of the lobe is coming across the bucket, you are going to have a problem.
Old Sep 18, 2009 | 01:52 PM
  #120
ttg35fort's Avatar
ttg35fort
Professional
Let's see...
I was an engineer for alot of years...
