20g potential
Old Mar 26, 2010 | 11:00 AM
  #221
thom000001's Avatar
thom000001
yea, 25psi was 690rwhp (believe that was same timing as 30psi)
and 20psi was like 600rwhp even.
Tom
Originally Posted by str8dum1
That a solid pump gas tune RR at 18psi. 20gs are actually not that small, you you should be able to run high 20 psi's at close to 800 hp with appropriate timing , I'd guess
I cant wait to see how solidly the 128 box interpolates between pump and E85.
Will you guys dyno a mixture scenario to double check AFR's? I know I'd want that verified before heading 800 miles away.
Tom did you ever do a dyno at say 25-28 psi to see when you started to just blow hot air?
Old Mar 26, 2010 | 11:10 AM
  #222
str8dum1's Avatar
str8dum1
so seems like your turbos were still doin ok at 30psi as you were still making almost 20hp/psi between 25-30.
You could probably make 650 on pump right now (if you had an EMS with active knock control ))
Old Mar 26, 2010 | 11:27 AM
  #223
thom000001's Avatar
thom000001
Ha,
on 18psi as it sits its probably right at 600rwhp (that would be the limit with current tune on 93 octane).
No reason to push it too hard......cams will certainly help out a lot for that as well....
I'm getting antsy to see what it does. Ordered cams/springs yesterday so things are in motion.
Tom
Old Mar 27, 2010 | 10:14 AM
  #224
rrmedicx's Avatar
rrmedicx
Damn you Thom! Always trying to +1 huh? lol
Tickets purchased to arrive in Chi-town 2pm. Will spend afternoon going over car with Larry and de-bugging if I can find anything to de-bug, then heading home wednesday.
Open to any friendly reminders of "what not to forget to ask" before heading out 800 miles away. Thanks everyone for the comments so far.
Old Mar 27, 2010 | 10:16 AM
  #225
rrmedicx's Avatar
rrmedicx
Hey Thom, your 769 hp was on 116 right? So I am no way going to even come close to eclipsing that #. You're lucky...for now. Haha. Hey maybe we can finally meet. You free Tuesday. Pick me up at the airport man!
Old Mar 27, 2010 | 10:39 AM
  #226
thom000001's Avatar
thom000001
769rwhp was on 110 leaded gas. We never did any C16 pulls.
Lemme check my schedule for tuesday (my car will be at shop, gets dropped off monday!)
Tom
Old Mar 27, 2010 | 05:15 PM
  #227
str8dum1's Avatar
str8dum1
Like I said, I wouldnt leave without verification of E85 interpolation for various percentages of ethanol.
Old Mar 27, 2010 | 06:37 PM
  #228
rrmedicx's Avatar
rrmedicx
Will do. And I will try to obtain dyno plots for all of the runs made thus far.
I wish i could see where the car makes power. But I am going to guess its late and probably acts more like a single Turbo than a twin...Mainly because the turbos are slightly larger than stock 18G's and because of the bigger cams (272's). This will probably help road manners a bit...we'll see. Just 3 more days.
Oh the wait is killing me.
Old Mar 28, 2010 | 05:49 AM
  #229
str8dum1's Avatar
str8dum1
nah, it shouldnt look like a single. XKRs looks pretty TT standard and he has aggro cams and bigger turbos.
not SPs drag twin 6262 car looks like a single
Old Mar 28, 2010 | 06:30 AM
  #230
thom000001's Avatar
thom000001
I saw the graph, looks pretty normal (except where it spun tires on dyno lol...well on that pull)
so are those 18G, 20G, or 20g wheels stuffed into a 18G housing?
Tom
Old Mar 28, 2010 | 06:58 AM
  #231
rrmedicx's Avatar
rrmedicx
Option C. 20G wheels stuffed into an enlarged 18G housing. Supposedly Forced Performance opened up the compressor housings on my Greddy 18G turbos. Originally we sent them just the cores of the turbo's to rebuild and upgrade...come to find out, they also needed the comp housing to machine those out to accommodate the larger wheels. But I am not sure I am truly convinced that the modified 18G-->20G's would be actually on par with a factory 20G turbo direct from Greddy.
I guess time will tell.
Old Mar 28, 2010 | 07:12 AM
  #232
phunk's Avatar
phunk
CJ Motorsports
the greddy 20g's have a larger turbine outlet also... do you know if FP opened that up on your turbine housings too or if you have the same diameter outlet?
Old Mar 28, 2010 | 07:17 AM
  #233
rrmedicx's Avatar
rrmedicx
Well FP never gave me a breakdown of what they did. I just told them I wanted the 20G upgrade and shipped them the parts. They took care of everything else. The only snag in the process was that originally the shop failed to send the compressor housings.
I needed to rebuild the turbos anyway, and the difference in just rebuilding them to 18G's and upgrading them to 20G's was like $200 IIRC.
Old Mar 28, 2010 | 07:34 AM
  #234
04G35tt's Avatar
04G35tt
nice numbers! Do you know which upgrade they did to your turbos? I believe they had 3 different "stages" for the upgrade. I got the 76 Comp, 67 Turb.
For reference this is the stock 18g turbo gasket that came with the Greddy TT kit. After I got my turbos back from Forced performance I had to take a significant amount of material away from the gasket to match the turbine housing. I also will have to modify my downpipe.
Old Mar 28, 2010 | 07:50 AM
  #235
rrmedicx's Avatar
rrmedicx
Can't tell you anything more than that.
Old Mar 28, 2010 | 07:58 AM
  #236
phunk's Avatar
phunk
CJ Motorsports
that picture in your post, thats exactly like the difference in size for the greddy 18g and greddys 20g
Old Mar 28, 2010 | 08:12 AM
  #237
04G35tt's Avatar
04G35tt
oops, sorry rr didn't catch that earlier.
I was going to try and use a 20g gasket but the bolt spacing is different. I think the ID of the turbine outlet measured 61-62mm, just the right size for a 2.5" to 3" reducer for my downpipes.
Old Mar 29, 2010 | 09:02 PM
  #238
Reid@SP's Avatar
Reid@SP
Hey guys, I'm late to the party on this one!
I am working on a little teaser video right now with Randy's dyno graph for the pump gas numbers he made. It was very impressive and sounds mean as hell! I even had to sit in the trunk to make full pulls on this bad boy. Those 275 tires were holding on for dear life!!
Regarding the questions about E85, the ProEFI 128 has a built in feature to read the ethanol percentage and allow for boost accordingly. We can run it with a full tank of E85, a full tank of pump 93, or a mixture and the ProEFI will change the maps accordingly to give the safest boost level based on the fuel content.
Reid
Old Mar 29, 2010 | 10:08 PM
  #239
Reid@SP's Avatar
Reid@SP
Old Mar 29, 2010 | 10:27 PM
  #240
CAB350z's Avatar
CAB350z
Very nice SP very nice
