vq35hr block with de heads
Old Oct 29, 2009 | 01:36 AM
racer59's Avatar
racer59
Smile vq35hr block with de heads
hi guys is it possible to fit de heads to a hr block as we run a autronic sm4 and it will not run the ex cam on the hr motor. thanks
Old Oct 29, 2009 | 05:28 AM
Cass007's Avatar
Cass007
I know you can put HR heads on a DE, but I don't know about the other way around. Swap the Autronic for a ViPEC and you could control both sets of cams I believe.
Have you been running an HR motor w/o the variable cams already?
Old Oct 29, 2009 | 05:48 AM
Glex25's Avatar
Glex25
I wonder if a revup would be able to control that since there is sensor for exhaust cams and intake cams.
Old Oct 29, 2009 | 01:14 PM
racer59's Avatar
racer59
hi we are running a forged vq35de with a gt4094 was looking at the the hr for the stronger bottom end and more revs u could run, the engine is only used in a racecar
Old Oct 29, 2009 | 01:47 PM
Nathan's Avatar
Nathan
As this is a race motor I asume you are using new cams. Just lock up the exhaust cam in the degree position that gives the most power on the dyno in your intended rev range. It will throw a CEL but no problems on a racecar
Old Oct 29, 2009 | 06:41 PM
Resmarted's Avatar
Resmarted
in for the knowleggg
what tranny is the car running?
Old Oct 29, 2009 | 09:02 PM
racer59's Avatar
racer59
we are running a tko600 tremec that leaks a lot of oil the car is a space frame toyota levin jdm the vq35 is mid mounted
Old Nov 18, 2009 | 05:09 PM
thawk408's Avatar
thawk408
Anyone ever find this out?
Pleask
Dec 21, 2021 03:17 PM
sherm
Apr 11, 2020 05:21 PM
Workshop12
Mar 23, 2020 01:45 PM
