my 2011 and Beyond! build thread.
Old Aug 15, 2011 | 06:36 AM
  #361
Ruthless18x's Avatar
Ruthless18x
Ricer.
Old Aug 15, 2011 | 06:38 AM
  #362
Alberto's Avatar
Alberto
Cranky FI Owner
Seriously, Im not usually a fan of body kits and the such, but your car is cleeeean. Good work.
Old Aug 15, 2011 | 07:08 AM
  #363
Flo-ridaZ33's Avatar
Flo-ridaZ33
I can have chips and dip on mine.
Old Aug 15, 2011 | 07:23 AM
  #364
dikspiel's Avatar
dikspiel
Chestons Toilet
Thanks, I also have an APR splitter for the front thats been custom made by APR to fit the ings bumper but I have yet to put it on.
  #365
dikspiel's Avatar
dikspiel
Chestons Toilet
wh0rederbs
Old Aug 15, 2011 | 07:49 AM
  #366
f150intally's Avatar
f150intally
SICK!
Old Aug 15, 2011 | 09:37 AM
  #367
dikspiel's Avatar
dikspiel
Chestons Toilet
May have a blown headgasket...car has a nice little puff of white smoke at idle and its sipping on coolant.
Motor is still under warranty so I have 2 options.
Pull turbo kit, install stock manifolds, stock cats, put on stock plenum, and have motor replaced under warranty.
Or.
Do a mild build of the engine:
Cosworth 8.8:1 Pistons .10mm over (i already bought these just in case)
Cosworth Piston Rings
Carillo H-beam Rods (should i get tapered or straight)
APR L19 Main Studs
Cosworth Main Bearing Set
Cosworth Head Gasket
any other suggestions for parts? technosquare thinks it will be around $4000 in labor/machining for a simple engine build. That seems reasonable but if anyone has any other suggestions for shops, let me know.
Old Aug 15, 2011 | 09:42 AM
  #368
Ruthless18x
Damn that was quick. I thought you weren't driving it until the Haltech was fixed?
Might as well do both. Since you would have to pull the motor for the build anyway, might be worth just getting the new motor at the same time.
Old Aug 15, 2011 | 09:48 AM
  #369
dikspiel's Avatar
dikspiel
Chestons Toilet
i've driven it 500-600 miles since the turbo installed. The engine only has 10,000 miles on it since i had it replaced under oil consumption originally so i dont really see the point of getting the new motor just to rebuild using that.
Old Aug 15, 2011 | 09:50 AM
  #370
str8dum1's Avatar
str8dum1
build the motor and heads
Old Aug 15, 2011 | 10:55 AM
  #371
Ruthless18x
Word. I didnt realize it was that new.
Old Aug 16, 2011 | 04:27 PM
  #372
dikspiel's Avatar
dikspiel
Chestons Toilet
Whether or not I have a headgasket issue or not I've decided to build the motor. I do not care how much horsepower I make, what I care about is making power as reliably as I can in a built motor. I am well aware the words reliable and power do not belong in the same sentence but I have been offered to have my engine built and tuned with a warranty.
The shop that will be doing the build is Gearheinz Power Service in Duarte, CA. The lead mechanic was also the lead mechanic for the Rockstar Drift Team.
Here is what I am thinking for the engine build.
Cosworth 8:8.1 Pistons +10mm over
CP Piston Rings (it seems that cosworth doesn't make +10mm over piston rings)
Carrillo H-Beam Rods (NI-Q35>-65676H-0)
ARP L19 Main Studs
ARP L19 Head Studs
Cosworth Head Gasket (not sure which thickness i need)
Cosworth Main Bearing Set (not sure which size i need)
Cosworth Rod Bearing Set (not sure if needed, please advise)
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
Do I need anything else? Any suggestions? If I don't care about making more power from the heads should I not do anything other then headgasket and l19 studs? Should I have it redecked, valve job, etc..?
Currently I have 850cc injectors, cosworth fuel rails, and a single walbro lph255 fuel pump. I plan on completing the return fuel system by buying the needed parts from CJM but should I upgrade the fuel pump to a DW lph300?
Let me know what you guys think, thanks!
P.S. I should mention my stock block only has 10k miles on it.
Old Aug 16, 2011 | 04:42 PM
  #373
gabe3d's Avatar
gabe3d
I'm sure you've seen this but it's a killer deal for DE heads, if mine weren't done already I'd be all over this. https://my350z.com/forum/engine/5318...are-block.html
Old Aug 16, 2011 | 04:47 PM
  #374
dikspiel's Avatar
dikspiel
Chestons Toilet
The cosworth pistons I plan on using are 95.75mm not 96mm so I am not sure it would work with darton sleeves. That seems like a great deal but probably overkill for my goals. I want to keep it simple.
Old Aug 16, 2011 | 04:52 PM
  #375
gabe3d's Avatar
gabe3d
Just talking about the heads that are listed for 2800. I don't think i'll ever recommend doing sleeves given the experience i've had with them.
Old Aug 16, 2011 | 04:57 PM
  #376
Ruthless18x
Sounds awesome dik. Good luck with it.
Old Aug 16, 2011 | 05:15 PM
  #377
dikspiel's Avatar
dikspiel
Chestons Toilet
ahh, im not looking to add cams.
Old Aug 17, 2011 | 05:18 PM
  #378
dikspiel's Avatar
dikspiel
Chestons Toilet
Ive been advised I could run nissan bearings if I wish and that nissan piston rings are the same as cosworth so I could use those as well.
Old Aug 18, 2011 | 06:38 AM
  #379
str8dum1's Avatar
str8dum1
do whatever your builder says. i thought rings came with the pistons, at least mine did
Old Aug 18, 2011 | 06:44 AM
  #380
blue350zed's Avatar
blue350zed
Does anyone else make the bearings? I went with the Nissan bearings on mine as well. Build looks good bro. Good luck with it all.
