my 2011 and Beyond! build thread.
Old May 12, 2012 | 03:52 PM
  #821
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck bro as you deserve it.
Old May 12, 2012 | 06:07 PM
  #822
djamps's Avatar
djamps
Are we being nice now? LOL good luck man
Old May 12, 2012 | 06:14 PM
  #823
GreenGoblin's Avatar
GreenGoblin
Good luck
Old May 15, 2012 | 05:16 PM
  #824
dikspiel's Avatar
dikspiel
Chestons Toilet
Car made 523whp / 470 tq at a little over 10psi of boost on the haltech. The GT-R injectors are running at 95% so that was the limiting factor. Will upgrade injectors once I've put a few miles on the new block. Will have dyno sheet up later but the car feels very smooth and it is scary to drive compared to the prius
Big thanks to GearHeinz for the excellent job on my new motor and being a reliable mechanic.
Old May 15, 2012 | 05:30 PM
  #825
Crom's Avatar
Crom
WOOT.....
Old May 15, 2012 | 06:04 PM
  #826
Kwame's Avatar
Kwame
Congrats.
Old May 15, 2012 | 06:17 PM
  #827
gabe3d's Avatar
gabe3d
The pigeon finally takes flight , I meant Phoenix. Glad to hear everything turned up well. Congrats!
Old May 15, 2012 | 06:23 PM
  #828
Ruthless18x's Avatar
Ruthless18x
Congrats.
Old May 15, 2012 | 09:38 PM
  #829
dikspiel's Avatar
dikspiel
Chestons Toilet
sorry its so blurry ill scan them tomorrow:
Old May 15, 2012 | 09:41 PM
  #830
Alberto's Avatar
Alberto
Cranky FI Owner
Im sorry to see that car is still weak sauce. Building a car with those numbers (especially on that dyno) is like having a kid with Downs, sure you love the b@stard, but in the back of your head, you wished things were different.
Well done.
Old May 15, 2012 | 09:43 PM
  #831
dikspiel's Avatar
dikspiel
Chestons Toilet
I promise to make you proud when I am running proper injectors Alberto and ill post non dynapak numbers.
Old May 15, 2012 | 10:05 PM
  #832
ace32x's Avatar
ace32x
Well done.
lols
Old May 16, 2012 | 12:06 PM
  #833
Highway Riding's Avatar
Highway Riding
Glad to see thing ***** come together...
Old May 17, 2012 | 02:45 PM
  #834
dikspiel's Avatar
dikspiel
Chestons Toilet
Old May 17, 2012 | 02:58 PM
  #835
BornSlippyZ's Avatar
BornSlippyZ
Good to see your Z finally breathing a sign of life!
Old May 17, 2012 | 04:17 PM
  #836
BAUSauto's Avatar
BAUSauto
Vendor - Former Vendor
Nice!
- Ben
626-688-1218
Old May 17, 2012 | 06:45 PM
  #837
Flo-ridaZ33's Avatar
Flo-ridaZ33
Congrats
Old May 27, 2012 | 09:31 PM
  #838
dikspiel's Avatar
dikspiel
Chestons Toilet
trying to figure out what i should do next.
Obviously I need to upgrade my injectors.. to what size is the question though. If i stick with 91 octane I won't need more then 850cc or maybe 1000cc if i decided to get bigger turbos in the future.
However I am contemplating doing e85 for the knock protection/nice bump in hp potential.
My fuel setup is currently an aeromotive 340lph fuel pump with the cjm stage 0 + cosworth fuel rail kit. Minus the fuel pump, is this setup sufficient for 600-650whp (dynapak) on e85? I could either keep the 340lph pump and add an inline a1000 or i could ditch the stock tank all together and do an a1000 external pump with an atl fuel cell with an external fuel sump.
Thoughts?
Should mention I'd probably run 1600cc or even 2000cc injectors if i run e85
Old May 28, 2012 | 07:15 AM
  #839
binder's Avatar
binder
well, another user is getting pretty good power out of the 340 on e85. You could always try it and see what power output you get from it.
Even if you upgrade your pump you will not need 2000cc injectors. Calculating fuel twin walbros will run out just under 6 1400cc 100% duty cycle so even 1600cc injectors would have more to offer than the dual walbro. I was thinking id 2000's as well until i did the math and realized i'll waste 600cc of injector only to deal with having huge injectors. I'm hitting max 72% duty cycle at 652hp with my HKS 1000cc injectors and dual walbro setup.
you could get mid-high 500's with larger injectors, e85 and your current pump. once you hit 600hp the street fun starts to decline. I think trying it out that way is a cheap way to increase some significant power. Your suggested plan is quite an expensive upgrade so start with injectors (since you need them anyways) and see what you get. You might be satisfied without spending tons of money.
also, what's up with that tq curve? is the clutch slipping or something?
Old May 28, 2012 | 07:21 AM
  #840
binder's Avatar
binder
Originally Posted by Highway Riding
Alot of SR guys say DW sux and to stay away something about rom tunes not liking them at all. JWT, Enthalpy etc...
from Zilvia:
Detchworks injectors are pure junk. Best thing you can do is get rid of them and get some good injectors. After the 3rd time I had a car come through (for me to tune) with detchworks and I was unable to get the cars to run right I decided that it had to be the detchworks injectors. I now refuse to tune cars with detchworks injectors now..
What Im trying to say is if you send your ecu off to get it reprogrammed for detchworks latency, chances are it still is going to run bad and then your going to need different injectors and to pay to get retuned again
That's funny because many people have great results. My car drove better than stock when Hal tuned it on dw 800's. It was amazing. Once i switched to hks 1000's it all went to ****.
Originally Posted by str8dum1
I've got my 2000cc injectors starting and idling just fine, almost as well as my PTE1200s.
I;d just get the ID1000s. If your tuner is really worth the money you are paying him, they should behave like stock.
+1 if i didn't mind spending extra money i would get rid of my hks 1000's for id1000's in a heartbeat. I just don't feel like spending money and re-tuning again. I ran my 1000's on pumpgas just fine and i'm running them at 650hp with e85 just fine. I never had a problem idling at 14.7 either fuel.
