No boost/ Car stalling upon start up
Old Apr 14, 2010 | 01:35 PM
CAB350z's Avatar
CAB350z
Default No boost/ Car stalling upon start up
After finishing up the car I decided to take it for a drive around the block, 3 miles 5ish Kilo...Car ran fine except for no boost, runs a perfect vacuum till I press the gas then it hits an invisible wall just at about -1. So i pulled back in front of my house. Turned the car off, thought i had fixed it... when i went to turn the car back on it turns on then shuts off immediately. The only thing i changed was a better vacuum line.
Car is also not pulling any codes
Help
Old Apr 14, 2010 | 01:44 PM
Vas_Z33's Avatar
Vas_Z33
check ur intake piping.. you probably have a hugeee leak somewhere
Old Apr 14, 2010 | 01:46 PM
CAB350z's Avatar
CAB350z
From the intercooler up, or too the turbos? - Found why the car wont start, there is an issue with the scavenger pump.. its leaking car cant build oil preasure
Old Apr 14, 2010 | 02:22 PM
Vas_Z33's Avatar
Vas_Z33
hmm.. thats weird.. which turbo kit do u have? if its not starting at all could be something else.. hope some1 will chim in
Old Apr 14, 2010 | 02:40 PM
CAB350z's Avatar
CAB350z
I got it to start, added more oil :S, the savanger pump basically leaked almost all of the oil in the car. Poured more in, basically enough to move it to the garage :S
Old Apr 14, 2010 | 03:09 PM
Vas_Z33's Avatar
Vas_Z33
ALL THE OIL in the car???! all of 6 qts? jesuss
Old Apr 15, 2010 | 03:03 AM
marra23's Avatar
marra23
Hopefully you didn't pick up serious damage.
Old Apr 15, 2010 | 05:21 AM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
How?
Was the line from the reservoir to the pump not connected? Or maybe the line from pump back to motor?
That doesn't add up.
Old Apr 15, 2010 | 06:54 AM
str8dum1's Avatar
str8dum1
maybe he forgot that the reservoir and the lines add an addtional 1 qt to the system
i didnt have any of those problems
pslamp32
Feb 8, 2017 09:07 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
