my SC Setup
Old May 31, 2010 | 04:19 PM
  #121
maXmood's Avatar
maXmood
Under Boost!
HPX MAF is a direct replacement, correct?
mainly:
1- disconnect the negative lead (battery)
2- remove the stock maf
3- install hpx maf
4- put the negatove lead back on
Old May 31, 2010 | 04:28 PM
  #122
Chef-J's Avatar
Chef-J
Booooosstt!!
^ for that Question. Yes, it fits perfect with stock housing.
Old May 31, 2010 | 04:41 PM
  #123
- bigc -'s Avatar
- bigc -
+1 it fits the OEM bung fine. As others have said, your car need to be tuned to use it though.
Old May 31, 2010 | 08:18 PM
  #124
nightcrawler_8's Avatar
nightcrawler_8
im interested in the maf as well.. let me know when u fix it.
i hope all go as planned.
Old May 31, 2010 | 10:17 PM
  #125
GT-ER's Avatar
GT-ER
Originally Posted by maXmood
there you go.. info about Bahrain http://en.wikipedia.org/wiki/Bahrain
and our fuel is PON.. R+M/2 = PON
Hmmm...interesting...91 isn't that bad then. No enough to cause yours numbers to be THAT low.
Old Jun 1, 2010 | 12:23 AM
  #126
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by Chef-J
Edit: Bigger housing or Modif sensor needs new tune. Even N/A.
Id would remove the cog belt if you are worry about getting on boost.
i might end up doing this..
Old Jun 1, 2010 | 12:25 AM
  #127
maXmood's Avatar
maXmood
Under Boost!
Thanks guys.!
i'll update you on how it goes.
Old Jun 1, 2010 | 01:00 AM
  #128
maXmood's Avatar
maXmood
Under Boost!
o btw, ECU threw a SES "P2A00".. it's to do with the O2 sensor, but not sure if the sensor itself is malfunctioning or something else triggering it.
Old Jun 1, 2010 | 01:20 PM
  #129
maXmood's Avatar
maXmood
Under Boost!
another SES....
P0300 now.
Old Jun 1, 2010 | 01:38 PM
  #130
- bigc -'s Avatar
- bigc -
the good ole' random misfire code
Old Jun 1, 2010 | 04:12 PM
  #131
Chef-J's Avatar
Chef-J
Booooosstt!!
Hold on...So your tuner tuned your car without MAF sensor? So which just tune with osiris? If that it is...i take it back about huge leak...I have feeling that it is the sensor.
And code, if tuner knows how to fully control osiris, you shouldn't have any problem after retune.
Old Jun 1, 2010 | 10:04 PM
  #132
maXmood's Avatar
maXmood
Under Boost!
so, what's next??? what should i do about this?
sorry Chef, i didn't understand what you're saying.. can you rephrase please?
thanks
Old Jun 2, 2010 | 12:30 AM
  #133
maXmood's Avatar
maXmood
Under Boost!
SES P0300 went away by itself this morning!.. when i started the car it wasn't there!?
Old Jun 2, 2010 | 01:20 AM
  #134
Chef-J's Avatar
Chef-J
Booooosstt!!
Opps, sorry I was little rush when I wrote last post. First dyno tuned, you mention you making really low whp I was asking if that's done without HPX sensor.
Old Jun 2, 2010 | 02:54 AM
  #135
maXmood's Avatar
maXmood
Under Boost!
we didn't do dyno tune.. but we did a dyno run without HPX sensor. and yes, i was getting low HP (15whp max).
but again, the MAF maxed out @ 5400 rpm, and i don't think 15whp is good for just to 5400 rpm.
i'm waiting for Vince to send me the HPX.. hopefully i get it by end of this week so i can start tuning the car again.
Old Jun 2, 2010 | 03:08 AM
  #136
Chef-J's Avatar
Chef-J
Booooosstt!!
Ok I hear ya. Humm interesting.
Old Jun 3, 2010 | 11:54 AM
  #137
maXmood's Avatar
maXmood
Under Boost!
Update...
mechanic done a boost leak test, and it was holding upto 13psi. (i wasn't present to witness).
he also replaced the belt with a shorter one.
on my way back home, i noticed the boost looks ready at half throttle.. i stepped on the gas and saw upto 4psi at 4500 rpm on 3rd gear. i didn't wanna shift past 5000 rpm because that's where the MAF max out.
i'm not sure if i should notice any difference before a tune.
thoughts?
Old Jun 3, 2010 | 12:27 PM
  #138
str8dum1's Avatar
str8dum1
you wont notice any difference in boost levels before or after the tune.
Old Jun 3, 2010 | 12:44 PM
  #139
maXmood's Avatar
maXmood
Under Boost!
hmmm.... shouldn't i see a greater psi with the correct belt size and being tighter?
Old Jun 3, 2010 | 01:47 PM
  #140
binder's Avatar
binder
4 psi at 4500 rpm sounds normal
