Jtran Studios Presents turbo kits (fabrication thread)
Old Nov 17, 2010 | 10:17 AM
  #261
lugrug's Avatar
lugrug
huh?
Old Nov 17, 2010 | 10:44 AM
  #262
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
The motor didnt grenade, so there shouldnt be to much material in the oil passages, we are currently waiting on time to pull the motor for a visual inspection to see whats going on. Upon tearing it down and after inspection we will be sending the motor to the machine shop for further machine work. Here at Jtran we strive on customer satisfaction and realibility on our customers cars.
Old Nov 17, 2010 | 10:54 AM
  #263
CRIDDA's Avatar
CRIDDA
That's what we like to hear. Wish you guys the best in getting this up and running.
Old Nov 17, 2010 | 11:01 AM
  #264
Jtran Studios
Thank you
Old Nov 18, 2010 | 12:57 PM
  #265
bldg250z's Avatar
bldg250z
Hope for the best JT.... hopefully you can have that out before the thanksgiving break!
Old Nov 23, 2010 | 08:04 PM
  #266
Resmarted's Avatar
Resmarted
How much are we looking at for a manifold? I'm considering getting one (when I eventually do go FI, which is taking a lot longer than I had imagined lol...) and would it fit on an A/T? (I'm fine with getting this info via pm if that helps )
Old Nov 24, 2010 | 03:57 AM
  #267
Cass007's Avatar
Cass007
Originally Posted by binder
nobody cares about that, at least not on these forums.
and not just turbo, heads, cams, oil squirters into the cylinders. Talk about abrasive.
- I keep seeing it over and over, people spin a bearing and think the block is the big loss. Its when you lose cams, turbos, headwork, oil pump, timing chains and guides, custom valve covers.... etc etc.
Old Nov 24, 2010 | 08:11 PM
  #268
Resmarted's Avatar
Resmarted
+1
Block is one of the cheapest parts to replace (although admittedly a pita to replace). And usually a spun bearing can be fixed with some good old machining of the crank.
Old Jan 10, 2011 | 03:25 PM
  #269
woRthy's Avatar
woRthy
sell me this setup!
Old Feb 14, 2011 | 09:20 AM
  #270
bldg250z's Avatar
bldg250z
good news.... got the new block and heads back from the machine shop now just waiting on JT to put it back together, hopefully get this kit and motor back up and running!... finally! hope for the best once again!
Old Feb 14, 2011 | 09:55 AM
  #271
binder's Avatar
binder
good to hear. I'm in the same boat. Getting ready to tear down and take my block to get some work done.
Old Mar 4, 2011 | 09:29 AM
  #272
bldg250z's Avatar
bldg250z
This baby is almost done! hopefully she will be out next week!
Old Mar 4, 2011 | 10:45 AM
  #273
Jtran Studios
just got off the dyno with the break in process. low boost with only 9.7 psi logged tuned afr with no meth did 492whp and 452 wtq. low timing also.
Old Mar 27, 2011 | 12:59 PM
  #274
bldg250z's Avatar
bldg250z
After a week and 1000 miles later on the new motor its time to go back to see Johnny and start on final tune ... got to drive the car all week and man does it feel great to have my car back!.... turbo sounds spectacular and drive-ability of the car is great!
Old Mar 29, 2011 | 08:40 AM
  #275
car8oy281's Avatar
car8oy281
update! tires will not hold on the dyno! 21 psi dwindling to 20 psi by redline! toyot r888's 305s! will post videos soon! numbers will be released along with track slips by the owner soon! We want to thank alex for the patience he has had since the beginning of this build! This build is done!
Johnny Tran
Jtran Studios
281.893.5858
Old Mar 29, 2011 | 09:01 AM
  #276
str8dum1's Avatar
str8dum1
restrap and try again. they dyno 1300whp supras without tire slip.
Old Mar 29, 2011 | 10:33 AM
  #277
binder's Avatar
binder
my thoughts also.....
sure the boost isn't dropping because the wastegate spring is too small and the boost controller can't keep up?
Old Mar 31, 2011 | 09:36 PM
  #278
Jtran Studios
9lb wastegate spring def aint keep up. 21 dwindling to 20 by redline is basically where we wanna be at.
Old Apr 1, 2011 | 10:25 AM
  #279
str8dum1's Avatar
str8dum1
Do you have the wastegate plumbed like diagram 2? I controlled 35+psi on 1 bar springs that way. Simple fix if you dont.
Old Apr 2, 2011 | 12:21 AM
  #280
bldg250z's Avatar
bldg250z
Did a trial run tonight ... one of my axles didnt hold on my second run but I will be going back to the track sometime next week hopefully to be able to get a clean run....
I made one pass but let off after a vacuum line popped loose ... basically ran a 12.11 coasting a third of the 1/4 mile(more or less) and a 7.9 at the 1/8, i spun the tires of the two step but managed a 1.9 60'... ill post time slips ltr... again wasnt a full run and for the first time handling this power and not being at the track in over a yr its not to bad IMO!
side note this was on low boost set up at about 15 psi...
thanks JT for keeping me focused tonight!
