Jtran Studios Presents turbo kits (fabrication thread)
Old Jul 7, 2010 | 09:45 AM
  #181
XKR's Avatar
XKR
Originally Posted by Jtran Studios
wow and you arent too bright. as far as bolts in the turbo, we took that one off to finalize fitment of the actual bracing for the turbo. those are water spots on the pipe from hurricane alex idiot. why are you such a smart ***? we are adjusting the turbo drain and making sure everything is broken down and cleaned up before giving the car back to the customer.
Old Jul 7, 2010 | 09:47 AM
  #182
str8dum1's Avatar
str8dum1
he doesnt have an standard exhaust alignment though. He'd have to chop up a MD exhaust to just basically use the resonator.
Tough to say if that would eliminate the drone since the "Y pipe" is essentially the turbo. A 6" magnaflow canister muffler before the tip would help though.
Originally Posted by rcdash
The motordyne 3" shockwave v2 eliminates the drone and is still straight through. A different fitting and I think you could rotate the turbo a little more down - great job working in that tiny space though - props. Congrats bldg250z!
Old Jul 7, 2010 | 10:45 AM
  #183
ColecatZ's Avatar
ColecatZ
I'm trying to figure out the best solution for a dual exit exhaust on this set up... I love hearing the turbo spinning freely as you blip around the parking lot, but I'm too OCD to have a straight through, single exit, pipe. I gotta have dual exit...
Old Jul 7, 2010 | 10:57 AM
  #184
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Jtran with the
Old Jul 7, 2010 | 12:15 PM
  #185
binder's Avatar
binder
It's petty simple , reverse y pipe and add a second exhaust pipe...
Old Jul 7, 2010 | 12:24 PM
  #186
rcdash's Avatar
rcdash
Why not just put a vband at the right spot and just use one of the axle back "mufflers"? No reverse Y needed. Then you can use any of the Motordyne mufflers from there... Unless you need the flow of dual 3"...
Old Jul 7, 2010 | 01:27 PM
  #187
binder's Avatar
binder
that works too. I was just looking at cost. Just another run of piping is cheap to weld up to the current one.
Old Jul 26, 2010 | 08:43 AM
  #188
ColecatZ's Avatar
ColecatZ
What's the latest on this? was a seperate thread created for the car/results?
bump for resurection...
Old Jul 27, 2010 | 07:42 AM
  #189
Jtran Studios's Avatar
Jtran Studios
car did 580whp and 541 wtq with it breaking loose on the dyno at 19 psi. injectors are maxed out. we are gonna be upgrading the injectors and see what this thing can do!
Old Jul 27, 2010 | 07:48 AM
  #190
str8dum1's Avatar
str8dum1
^pump gas? very nice
Old Jul 27, 2010 | 08:15 AM
  #191
bldg250z's Avatar
bldg250z
yup pump gas .... awesome Johnny Im stoked about the numbers!!!! thanks
Old Jul 27, 2010 | 08:25 AM
  #192
biggersNISMO's Avatar
biggersNISMO
very bueno numbers!!!!!!!!
Old Jul 27, 2010 | 08:26 AM
  #193
bottlefedZ's Avatar
bottlefedZ
Nice...congrats Alex pretty good numbers for pump gas
Old Jul 27, 2010 | 07:00 PM
  #194
lazyduster's Avatar
lazyduster
any dyno vids?
Old Jul 27, 2010 | 07:10 PM
  #195
Elperuano's Avatar
Elperuano
noooice!
Old Jul 29, 2010 | 07:32 AM
  #196
ColecatZ's Avatar
ColecatZ
I want this kit.... use it to terrorize my stock block.
Old Jul 29, 2010 | 07:51 AM
  #197
lugrug's Avatar
lugrug
You want to try to push 580whp though your stock block?!?!?!?!?
........prays for the soul of ColecatZ's block
Old Jul 29, 2010 | 08:51 AM
  #198
ColecatZ's Avatar
ColecatZ
nah, I just want a conservative 380-400rw for the time being, with an end goal down the road of 480-500 solid
Old Jul 29, 2010 | 10:16 AM
  #199
str8dum1's Avatar
str8dum1
might as well get a powerlab kit then as there's no reason for a such a fabrication heavy kit (ie $$$$$) for those goals.
Old Jul 29, 2010 | 11:36 AM
  #200
binder's Avatar
binder
ya, turbo is way too big for those power goals. You're sacrificing 1000rpm of spool time for no reason.
